What is this hydraulic jack valve?
tpolley
kansas city
It's a Vestil hydraulic lift table. Vestil wants $618 for a new foot pump assembly. Their parts catalogue doesn't go that far in depth.
I'm thinking if I can find this part I might be able to fix it. My google-fu has failed me. I don't even know what it's called. I've tried all manner of terminology. Valve, check valve, I've tried searching McMaster for a through hole set screw or grub screw.
It's M8 x 1. I can buy M8 x 1.25 all day long.
There there is a needle valve in the other one, should this one have one, too?
whateg01
doo dah, kansas, usa
Are you referring to the thing in your hand that looks like set screw with a hole through it? Did the check ball seat against that? Why is it not round?
T
tpolley
kansas city
Aye. It looks like a set screw with a hole in it. It was laying in the bottom of that reservoir for lack of a proper term. I didn't see a spring or a ball anywhere when i disassembled it. I thought maybe there should have been, but I don't know where it would have gone, it's sealed. I assume it worked itself loose, fell out and was crushed.
We just replaced it last summer. It had been working fine then all of a sudden it quit raising
whateg01
Is that the pump removed? I would have to see a schematic to be sure but I would expect there to be a check ball that seats against the screw
T
tpolley
kansas city
I think that's the check ball. I think it is embedded in the bottom of that reservoir. I don't think that's supposed to be there.
I'm thinking the assembly is toast
I was thinking that was your check ball. I would imagine you could dislodge it from the base with a prying tool, and at least get a dimension on the mostly round part, might help finding a screw to mate with it.
If it’s just a rate setting valve, maybe no checkvalve, but I’m no expert.
Maybe @Hiball should be summoned.
