Garage with no exit door
908Jim
I've seen several 1940s and 1950s Capes with attached garages and no secondary egress because there were no automatic openers in use when built. Just manually latched and locked garage doors, all done from the outside. I'm willing to bet OPs garage was retrofitted with an opener later and somebody just assumed it would never be an issue.
firebirdparts
Kingsport, TN
I live in a cape that was built in the 70's with no man door into the house. The first thing I did when we bought the place was cut a door.
rpcraft
Waco
FWIW Garage doors that are automatic have am emergency release handle. It's not convenient but if the motor stops working you walk in your front door and then into the garage and pull the release and slide it up. It's what grandpa and grandma used to do back in the day before motors, lol!
kbuhagiar
Escondido, CA
That doesn't help if you dont have a front door to walk in to.
pima67
Tucson, AZ
Just for fun:
We lived in a house in UT built in 1952. The garage door was wood (Crawford I think) and wide enought for 2 cars (1950s cars anyway). One night there was a very loud bang. Our bedroom was over the garage, and I had thoughts of someone shooting at us. Any way it was the door spring breaking. That door was very hard to raise without the spring. My wife could never have done it. Did have a man door from the house for access. Before that I had tried to add an opener but there wasn't enough head room for the opener.
Schurkey
Beemer
Northeast
I would think so. I'm really shocked that it's built like this.
And it was part of the original construction (not a half assed addition) and there are other homes in the neighborhood that seem to have this weird flaw. I have no idea how they got a certificate of occupancy.
Building Inspectors around here tend to make their own Code interpretations and they can be wrong.
I've seen several instances where professional design opinions needed to be escalated to the State Building Inspector to get a reasonable solution.
On another note, I suspect that there are places that do not use the national building code and also I believe that our state did not have a building code until the early 1970s so anything was possible.
billconner
Thousand Islands NYS
Maybe I'm wrong, but don't building codes require at least 2 ways in and out?
Based on IRC, not for a garage intended for basically storage, in US. In Canada, I've been told a man door is required. And an overhead door is never considered "a way out", or "means of egress" in code language. You find a lot of these in multi family projects, a long building with just a bunch of overhead doors each serving a storage area. These might be against a property line and have no other access. Not garaged like the garage-mahals focused on here. :)
Local jurisdictions might amend this.
Spikes
Arkansas
Easy / cheap just replace the opener with a battery backup model and forget about it. Doors are super easy to frame in, too.
rpcraft
Waco
Took me a bit to recall this but I remembered but apartments that have garages they have to have a provision to open garage doors in an emergency (or if the battery died on the fob). They usually have a keylock just around head height or up a little higher that allows them to unlock and once it does a cylinder pops out with a cable that attaches to the ememergency release from the outside. As I said It allows them to enter garages that do not have a door for fire, emergency or dead batteries and power outages. It's been about 10 years since I lived in an apartment but when I did I had a couple garages for my various shops and they all had that now that I recall. Kind of gives you the ability to have the emergency release but not have it where the casual criminal can use it. Here is a link to one I found at the Despot!!! - https://www.homedepot.com/p/Prime-L...Kit-Diecast-Brushed-Chrome-GD-52143/202633678.
Lorydr
Piqua, oHIo
They offer keys that mount in the door which releases the trolley allowing you to open the door from the outside in the event of loss of power.
One such device
When I worked for a garage door company, I was told that crooks only needed a coat hanger to slip in at the top of the door, then fish for the trolley disconnect rope. That could work for an emergency. Meanwhile use the remote, have another to keep in the house.
carcruse
SE Michigan
Yep, see the video I posted (#75) on page 2.
CGT80
IE, SoCal, USA
Geez a permit to put in a door? I know of a house built within the last 2 years that didn't have a single permit. Nobody really cares.
If you want the door, just put in the door.
You must not be very smart, or just happen to live in every neighborhood in the country or even world to know that nobody cares, or did you just not clarify you are only talking about your area when you said no one cares? Blanket statements are dumb if that was one. Sorry, but one of my pet peeves is people who assume things that can vary wildly and those who miss the important detail in what they state or read.
25+ years ago, my city wanted a permit just to install a mercury vapor light over a residential driveway.
There are certainly regulations and people who do care in plenty of areas. You may be lucky enough to live where no one cares. What is required and what you can get away with can be different things.
A person only needs to be able to crawl in or out of the garage for a door failure. A utility door mounted low and between the studs would be easier and less visible while serving the purpose and it can be more of a DIY job.
A man door makes sense and can vary in installation difficult depending on the structure, but there are many pros out there like me and even others who could saw cut a thick concrete wall if it happened to be that extreme. A straight forward install could be done in a day, but sometimes issues arise, especially with old work. Location of course matters, especially if Murphy rode in the back seat and decides to mess things up.
CGT80
IE, SoCal, USA
Hmmmm. With that kind of luck......
What is that supposed to mean?
People often don't get to choose all the aspects of where they live, or even location, and have to deal with obstacles with projects like this.
Some cities have code enforcement driving around looking for any work going on.
