pcrov
Just need some decent phillips and flats that won't snap when I sneeze on them.
A standard flat screw bit and "impact" can't be used in the same sentence. LMAOI've recommended Makita Gold bits elsewhere. They're advertized as impact, though I've never used them that way. For my use the fit is great and they seem to hold up well.
This is pretty vague.Just need some decent phillips and flats that won't snap when I sneeze on them.
Well now I want to know the recommendations for all of them. Like is someone out there making killer insert bits but their power bits are garbage?This is pretty vague.
Are you using them in a powered impact driver?
If so, are you wanting insert bits for use with a bit holder or power bits for direct connection? General DIY use or pro use? Any specific application?
The members here are a huge knowledgeable sounding board. When you want to be serious, I’ll play. No point wasting time on someone combative. Good luck.Well now I want to know the recommendations for all of them. Like is someone out there making killer insert bits but their power bits are garbage?
I did but that post disappeared. I use them with an impact wrench and adapter to remove stuck and stubborn fasteners. They're great for disassembly.Who the hell still uses slotted driver and phillips bits for diy use??? Hard enough to properly drive them with hand tools let alone power tools. You didn’t specify usage
