Who's the go-to for impact bits these days?
P
pcrov
Ontario, CA
zimman
Mark Twain National Forest
I've recommended Makita Gold bits elsewhere. They're advertized as impact, though I've never used them that way. For my use the fit is great and they seem to hold up well.
A standard flat screw bit and "impact" can't be used in the same sentence. LMAO
Pretty much the same with a Phillips. Now a manual impact driver for screws is a different animal. I threw mine in the trash and bought a torch. Ahahahahha.
Zim
Steel_Rain
I second the Makita impact gold bits. Still plenty available even from the Orange Box:
I have tons of these, made in Japan. 👍
KnurledNut
n/a
Just need some decent phillips and flats that won't snap when I sneeze on them.
This is pretty vague.
Are you using them in a powered impact driver?
If so, are you wanting insert bits for use with a bit holder or power bits for direct connection? General DIY use or pro use? Any specific application?
P
pcrov
Ontario, CA
Well now I want to know the recommendations for all of them. Like is someone out there making killer insert bits but their power bits are garbage?
Nobody-named-Olli
Wera makes decent impact bits, I run them in a Ko-Ken 3/8” square to 1/4” hex adapter on my 3/8” Snap-On impact wrench without any issues. I’m still on the predecessor of this set, so while they are consumables, they last a fair amount of time.
Example: https://www.weratools.com/en-us/tools/bit-check-6-impaktor-1-sb
Wera won’t give you the slotted/ flat bits though. I personally have used regular tough-hard flat bits in a Wera torsion (3/8” square) bit holder - with that same impact wrench - on the occasion that I needed it.
(Don’t dismiss the idea of a slotted/ flat bit in an impact wrench/ driver before you tried it - in some instances it works wonders, especially considering removal … .)
Kind regards,
Olli
KnurledNut
n/a
The members here are a huge knowledgeable sounding board. When you want to be serious, I’ll play. No point wasting time on someone combative. Good luck.
P
pcrov
Ontario, CA
My local home depot ***** so I ended up at amazon, of course. I picked up a small kit of the successor to that gold line, XPS:
The case is tough plastic, doesn't feel cheap at all. The bit holder holds firm as it has both a magnet and retaining ring. We'll have to see about the rest of it, fingers crossed.
Thanks for the recommendations!
Retired dozer fixer
Leesburg Indiana
Who the hell still uses slotted driver and phillips bits for diy use??? Hard enough to properly drive them with hand tools let alone power tools. You didn’t specify usage
Etchase
Hawaii
Apex is still making good impact bits. I think they are still made in the USA. Makita, Dewalt, and Bosch are good too. They are what I use if there are lots of fasteners to deal with. I say hand impact if I mean a hand impact, and Vessel makes good 5/16 bits for those.
Ohio Andy
Columbus, Ohio
When I want an impact bit.....
Vessel, I have the IMPACT BALL Torsion Bit 52PCS SET
Felo Impact 19 SQ Bit Set in Box - PH/SQ/TX, 19 Pieces. A very tight fit into the holder if you want to use their driver.
Makita gold was recommended and they are apparently no longer available. I have these two sets
https://www.amazon.com/dp/B07X993KTF?tag=atomicindus08-20 (Makita E-00038 Impactx 100 Pc. Driver Bit Set)
https://www.amazon.com/dp/B085DVVW29?tag=atomicindus08-20 (Makita E-01650 Impact XPS™ 45 Pc. Impact Bit Set)
I also own some Apex and Milwaukee impact rated bits.
Wera was recommended and although I do own a few Wera bits, none of them are Impact rated. For Wera, that means "Impaktor". I would buy them from either KC Tools or DRPD, both well known and trusted companies here. They have both treated me very well.
P
pcrov
Ontario, CA
I did but that post disappeared. I use them with an impact wrench and adapter to remove stuck and stubborn fasteners. They're great for disassembly.
TailGunner3000
New Jersey
In truth you can't really go wrong with any of the big boy brands. This time of year, they all have deals on large quantity bit sets. As a plus, you can end up with a bunch of hard cases for essentially no cost.
