The VISES of Garage Journal
KMScott
I would have thought Bonney contracted the whole vise out to Parker. They were a hand tool Co, not vises and anvils.
If so then Parker didn’t design it. They might have cast it and had their Toolmakers machine it but it isn’t a Parker design. Most of these Bonney Rapid Transit vises have the anvil area broken. Thin wall construction.
akasrick
south jersey
Building a set of jaws for my Bonney 160. Jaws are 5-1/4” wide. Parker style jaws. I tell you what, these jaws are identical to ones I’ve made for Parker’s. Pretty close to a negative 20 degrees undercut.
Thinking Parker supplied or actually cut the jaws and jaw supports. Only difference is Bonney used three pins per jaw instead of 2 pins. Pretty cool vise. Gotta figure out with Royce’s help on how to repair anvil area. Seems Bonny skimped on wall thickness around the horn. I’ll post finished pics next year.
Heck of a project Kevin. The 1886 catalog only mentions the jaws as being interchangeable and of cast steel. No detail of the jaw profile in the catalog cut.
akasrick
edited
I thought Bonney started out as a vise manufacturer before starting the hand tool line.
Pre. they had something to do with carriage working/blacksmithing.
akasrick
Didn't know that. Must have got out of casting and into forging at some point, or why involve Parker? Maybe the cast iron plant burned down as so many did back then, and was never rebuilt.
Looks like it was voluntary if you can trust AI:
History of Bonney Vise & Tool Works
  • 1876: Charles S. Bonney founded the company in Philadelphia, Pennsylvania, initially making hardware for horse-drawn wagons.
  • 1877: The company started producing vises and tools.
  • 1909: The company moved to Allentown, Pennsylvania, and expanded its operations, focusing on drop-forged wrenches.
  • 1921: The name was changed to Bonney Forge & Tool Works to reflect its focus on drop forging.
  • 1922: The company introduced the first full line of alloy steel wrenches.
  • 1930s-1950s: Bonney expanded its product line to include a full range of mechanics' hand tools.
  • 1953: The company was purchased by Miller Manufacturing Company.
  • 1964: The tool division was sold to Kelsey-Hayes Corp..
  • 1984: The remaining operations were sold to its president, John Leone, and the company continues today as Bonney Forge, a manufacturer of pipe fittings and valves.
akasrick
south jersey
Looks like it was voluntary o=if you can trust AI:
Looks like they skipped making the blacksmith leg vises, at least I've not seen any advertised.
akasrick
682bear
West GA
I began machining a new screw retaining plate for my big Parker 208 vise the other day... the original was missing and had been replaced with a flat piece of scrap steel.
I'm done with what needs to be done on the rotary table... I need to set my mill vise back on the mill to finish the plate.
While I had the rotary table set up, I decided to make a part for another old vise...
Back in June, I had picked up an old unmarked oval slide vise from a junk store...
The slide was seized and the screw retaining plate and nut was missing. I clamped a piece of mild steel on the rotary table and machined a replacement plate...
Now I need to figure out a fix for the missing nut. The screw is 7/8"- 4 threads per inch... I haven't been able to find a nut that will fit that.
-Bear
micahd1997
Wow, that’s a rare beauty, Kevin! I can’t say I’ve seen more than a couple of those. Looking forward to seeing the jaws finished
micahd1997
Following a 6-month dry spell, I scooped up an Athol 618 and a Prentiss 58.
I’ve been looking for a 58 without a cracked slide for some time now, so this one will be my new user. The 618 is frozen and has a thin crack in the side of the slide. However, it is usable otherwise, and will ultimately be up for sale.
Happy Thanksgiving!
ChefRex
Found this one at an estate sale a while back...missing the swivel base unless the wood base is a rare option. It's a Reed 204 1/2 in decent shape.
I could be wrong but I remember when I picked up my 204 1/2 with a meatball it's an early example.
GX460DIYguy
Texas
My father in law has this old Reed 3C in his back yard. How hard are they to find parts for? I’d love to restore it for him as much as I can. He bought it at an equipment auction where he worked and that was probably at least 30-40 years ago so it’s seen some use. It’ll probably never be like new, but it would be nice to get all the rust off of it and maybe get a better set of jaws on it.
Reed is still in business, and I think still make these vises, so parts likely available. What are you missing? It looks complete.
Shiftless
East Bay SFO
O
Outlaw is right. I’ll second the opinion that it looks complete to me. It has a nice looking set of pipe jaws which are sometimes missing. I have 2 Reed 1C’s in my collection and I used to own a 4C. They are just about the best combination vise ever built.
Sometimes worn out looking jaws can be refreshed to become useable just by wire brushing the crud out of the grooves.
GX460DIYguy
Texas
O
Yeah it’s complete and still gets used. Just figured it might be a good idea to replace some of the old stuff. Planned to take a wire wheel to it and clean it up and repaint it and clean up the insides.
Shiftless
East Bay SFO
Old stuff when it comes to Reed vises is plenty good now. A 75 or so year old Reed vise once is is cleaned up, lubricated and adjusted will outperform just about any new vise on the market today. I can’t say enough good things about the entire line of Reed vises with the C series at the top of the heap.
Take it apart and clean the crusty dirty old grease out of the nut and main screw. Get all the sliding surfaces clean and smooth. Lube it up and put that great old vise back to work.
just my lousy two cents, but...
wire wheel will remove any patina on the metal.
fine brass brush and WD-40 will remove the rust and leave the original finish. (lots of work)
Simple Green (straight) will remove paint and not change the finish of the metal one iota.
pics
then just wipe it down with BLO.
again, just my lousy two cents.
PeterPeter
Newburyport
Here’s one i haven’t found in the catalogs, but there is an open spot in the spreadsheet for this no. 71 C.Parker that I spied in the wild today. IMG_0056.jpeg
Another Parker, missing the screw retaining ring as usual.
Still has the chain holding the key that locks the swivel jaw.
peterpeter
1Bad55Chevy
Ya impossible to fix... Definitely not worth your time... my time is basically worthless so it would be best to give it to me!
Super cool vise man!
@PeterPeter -
^ You're above my pay grade there.... I don't know anything about vises. One of the other members might better provide some insight on that.
if you meant THIS:
"* note that the 1928 Francke Hardware Co. catalog shows a swivel attachment for a model 71."
That little widget also fit other models of their vises.
Ultradog MN
Twin Cities
Well,
Since the Holidays are approaching I thought I would display my vises in the form of a Christmas tree.
From bottom to top is a 6" Wilton C3 bullet, an 8" Cardinal 8B Speedvise, a vintage 6" Bridgeport machinist vise, a pair of 6" Heinrich 6SV drill vises, a 4" Floatlock and a little 2-1/2"Craftsman machinist vise.
There's also a 5" blacksmith vise on my grinding stand outside - and a couple of other small ones around here that were too shy to get in the photo (or I couldn't find at the moment.)
rocksnstumps
^^^ Would have liked to pick up a nice bigger Morgan vise cheap but did get a deal on this Craftsman 5191 in decent shape. Bit of dirt binding it up but no cracks in any parts. Just took it apart to clean the insides at this point. Still looking to get a deal on something like a Heinrich 6SV drill vise above in the Christmas "tree". My recent addition of a 20" Clausing looks bare without a decent drill press vise on the table.
