vdotmatrix
Exactly true….The closer I look at that bolt the more it looks like the threads are fine (?) but just packed with aluminum from the stripped hole it came out of.
Except the valve cover bolt is dedicated to this application.You may very well be able to tap the hole for an M6.5; rather than Helicoil or Timesert, both of which will leave less parent material.
I am the original owner of this 1980 cx-500c.In my opinion, repairing the first time with a Heli-coil allows future option for a repair with a solid insert. Most of us don't keep stuff long enough to see iteration #2 but it is a nice "defense in depth" option.
Could have been slightly over tightened each time and finally fully pulled the threads outI am the original owner of this 1980 cx-500c.
Boots or bolt?Why do those boots have such a sharp point?
Would that be a stripper bolt?Boots or bolt?
Aluminum head with steel bolts? Galvanic corrosion.I went back and re-read every post so far. This head has never leaked oil. The two bolts only go in so far before they tighten and can go no further. I wonder if I used a driver to put the bolts back and had it on an unnecessarily high torque setting by mistake. Anyway, this is a very low torque application. I will have to research how much meat I need for each flavor of repair: helicoil or Timesert. This is stressing me out. If it were a muffler or kick stand, I wouldn't care, but this is in a 45 year old bike‘s cylinder head where one more fkup will be a big headache.
Really? The helicoil is stainless isn’t?Aluminum head with steel bolts? Galvanic corrosion.
Pretty sure he meant bolts because I had the same question when I saw them. Maybe the bolts puncture a new gasket for better sealing?Boots or bolt?
Boots or bolt?
I was referring to the existing bolt.Really? The helicoil is stainless isn’t?
More than likely, its a cost saving step by the manufacturer... Thread forming bolt...Why do those bolts have such a sharp point?
I thought about that, and if that's the case this is likely the cause of the OP issue.
6.25 is preferable for aluminum.M6 x 1 Helicoil will require a 6.3mm drill.
Typical thread shearing off. This didn't happen upon tightening. Thermal expansion of dissimilar metals combined with what was likely an overtightened fastener did.Oh yes….but it shave the aluminum so evenly….
Not my experience.I used to think that, until I did some testing to discover that I had better luck with the Helicoil's in general. I used to build a lot of 2-stroke and VW engines and did a lot of in-house side by side comparisons back in the 90's and I had multiple Timeserts pull out where the Helicoil's continued to hold well past their "normal" fastener size torque applications.
Honda uses chrome plated steel bolts in valve covers a lotI was referring to the existing bolt.
So, you could get two diameters (12mm) of threads engaged, and be quite a bit stronger than the original threads.....which lasted a long time.This kit arrives today. I suppose there isn't much of a rush now since there is snow on the ground, wo if i need a high quality kit, i have time. The helicoil brand was not available, that i could find in Amazon, without a long wait. This had decent reviews.
I measured everything so I could plan for every contingency.
I was just reading your post earlier. Interesting. There is only 14mm of usable thread….i have to see what i get with this inexpensive kit I ordered from amazon…So, you could get two diameters (12mm) of threads engaged, and be quite a bit stronger than the original threads.....which lasted a long time.
Ye, i cannot afford to mess this up and i am already seeing who carries the Helicoil brand. I don’t want to say , “you get what you paid for in this case”.My only beef with the Amazon kits like that is the tang doesn't always like to break of easily like on a real helicoil. Otherwise, they seem to work ok for me.
I wouldn't personally use that Amazon kit.Ye, i cannot afford to mess this up and i am already seeing who carries the Helicoil brand. I don’t want to say , “you get what you paid for in this case”.
I have spent a lot of time reading reviews, one common issue with the helicoil brand is the tang breaks off…it does not come with a drill bit matched to the kit scary…. Thank s for helping…fretting!I wouldn't personally use that Amazon kit.
If you can't source Helicoil brand then the Fix-A-Thred inserts and tooling (Howmet Aerospace brand) available at auto parts stores are good quality.
https://www.hfsindustrial.com/us/fix-a-thred-repair-kit.html
I've only had the tang break off on a helicoil brand once. The good thing is you can use a pick to pull the top of the wire out and grab it with needle nose pliers and just pull it out. The Amazon one has the opposite problem. It usually pulls the bottom turn out of the tapped thread before it breaks off. Pretty easy to use a pick to put it back but I can see where sometimes it might not be.I have spent a lot of time reading reviews, one common issue with the helicoil brand is the tang breaks off…
You can look up the drill size.it does not come with a drill bit matched to the kit scary…. Thank s for helping…fretting!![]()
$30. I guess i can use a 6.3mm bit or a 1/4” bit.I've only had the tang break off on a helicoil brand once. The good thing is you can use a pick to pull the top of the wire out and grab it with needle nose pliers and just pull it out. The Amazon one has the opposite problem. It usually pulls the bottom turn out of the tapped thread before it breaks off. Pretty easy to use a pick to put it back but I can see where sometimes it might not be.
I was going to ask if you ran it on/ off with electric impact/ ratchet tools. They do have an effect on fasteners coming out of aluminum, learned that myself even after reading the precautions from MagHytec on a transmission pan. Didn't think a 12 volt Milwaukee non Fuel ratchet spun with enough speed or force, but sure enough it cost me 2 holes on an E4OD transmission. They would hold just tight enough not to fall out or leak.I went back and re-read every post so far. This head has never leaked oil. The two bolts only go in so far before they tighten and can go no further. I wonder if I used a driver to put the bolts back and had it on an unnecessarily high torque setting by mistake. Anyway, this is a very low torque application. I will have to research how much meat I need for each flavor of repair: helicoil or Timesert. This is stressing me out. If it were a muffler or kick stand, I wouldn't care, but this is in a 45 year old bike‘s cylinder head where one more fkup will be a big headache.
Looking at the original photo, I count eight or nine threads pulled out. Nine threads at 1.0 mm, makes one and one half diameters engaged. In steel, that woulda been OK, in aluminum the longer the better.
It depends on the depth (i.e. percentage) of thread engagement.How much thread engagement do you need for an 18-8 SST or grade 2 equivalent M6 screw threaded into 6061-T6 so that the screw breaks before the threads strip?
