Black and Decker bench grinder wiring help
Sawmill7
Iron River Mi
Doing a resto on vintage black and decker 1 h.p bench grinder. It does work but after disassembling it wiring does not look correct. Previous owner had been replaced some wiring and just does not look correct.
Capacitor has only 2 spades but has 3 wires, 2 on a spade and 1 on the other spade.
The drawing in the picture is how it's wired now
But want to replace wires correctly.
Also no markings on capacitor so need to know correct size to replace it. Thanks for any help with my project. Bill
PCustoms
VT
The "hot" wire should be switched, not the neutral
Pictures of the actual wiring may be helpful
Sawmill7
Iron River Mi
Here is how it was wired. I know the black should go to and from switch. As I stated it did work but old wiring is mess.hope this pic helps
justsam
Penngrove, California
I see no issue other than would look more professional if black to black and white to white. as has been mentioned, and switch black lead. The single lead, small white from motor, on the capacitor is one side of the start winding. The two leads on the capacitor should be power and one side of run winding from motor.
Sawmill7
Iron River Mi
So I do need 2 wires to one side of capicator?
Do you have any thoughts on specs for a new capicator? Want to replace as long as I have it apart. Thanks
justsam
If the grinder is currently starting OK, I am not sure why you want to replace the capacitor. Can you see any markings on it? Since a grinder application typically does not start under load, I would guess the value to be around 100 uFd. Not too critical as if it does it's job by starting the motor it is out of the circuit once running. The capacitor lug with two wires is just a convenient tie point. If electrically one side of the capacitor, one leg of power and one motor lead are connected together it does not matter how you got there. The single wire on the capacitor is one side of the motor start winding. If you do change the capacitor it must be for motor start application as it requires a non polarized capacitor and a typical electrolytic will not work here.
