Found some old wood chisels
Ohio Andy
Columbus, Ohio
@Ohio Andy : Here's the jig I'm using: https://www.amazon.com/dp/B0BZGHZ79R?tag=atomicindus08-20
I just turned it upside-down in a drill press vise so I can use the narrow WE paddles.
Here's all the goodies, getting ready to flatten the back of the 3/4" Crafty:
Since these chisels haven never been used or sharpened, the hardest part is flattening the back--they sure don't come flat fro the factory. The bevel isn't particularly straight, either, but that takes less metal removal than initial flattening.
Oh, nice!
and yes, flattening the back is always annoying for me. It is why I was excited to try the Tormek wheel side to do this. I failed to hold it flat and I ended up with a gauge on the back. I had a similar problem trying this with a sand paper based version that has a spinning wheel. The name escapes me. I spent a lot of money on that system and it worked, but I gave it away after I received my Tormek.
Beerhippie
Far NE Oregon
Whew!
Four Crafty chisels--done. It sure didn't help that the chisels were chromed AFTER the coarse sharpening, so I had to first remove the chrome--much harder than steel. Thank geology (and lab rats) for diamonds! The chrome of the 1/4" peeled off the last inch of the chisel as I was flattening the back, which sped that one up some.
The sharpening jig I use doesn't quite grip a 1/4" chisel. I tried using some beer can for a shim, but that made it impossible to get the chisel flat in the clamp. I ended up just doing that one by hand, meaning I have a convex bevel. But then I got thinking, how often do I use a 1/4" chisel? The answer was NEVER. Maybe now that I have a nice sharp one, I might.
Probably 90% of what I use a chisel for is cutting the inlets for door hardware--and I just finished most of the door work I'll be doing for quite a while. I hope....
Beerhippie
Far NE Oregon
Don't know anything about the CBN. I vaguely remember that maybe a diamond version did, but, I don't own one so never paid much attention to it.
CBN (properly c-BN) is Cubic Boron Nitride. It isn't quite as hard as diamonds, but more heat resistant and a better conductor of heat, meaning that when bonded to an aluminum wheel, it keeps your work cooler. Supposedly, it can be used dry in conditions where a diamond wheel would "burn" the work.
Check it out on Ytube. There must be a thousand videos on it.
I think it's also the abrasive used in 3-M Cubitron II products, which I use the hell out of.
Found these Buck Bros. Chisels at a Tahoe yard sale yesterday morning. They badly needed sharpening. IMG_6398.jpeg
I finally found a Buck Bros wood chisel at a moving sale on Saturday that didn’t need sharpening. IMG_3065.jpeg
Here are a pair of chisels in a brand I’m not familiar with. They are from Petko Industries in CA and they were made in Sheffield, England. The smaller one has a little nick out of the blade and will need sharpening. Has anyone run across this brand? I found mention of a concrete finishing tool on ToolTalk and some Kwikset style keys on eBay IMG_5536.jpegIMG_5537.jpeg
From this distance, those look like Scandinavian chisel handles. Berg is my favorite, and only one I can spell freehand. Screwing around on the phone, will look at big pics later, see if I can help
Cripe, I thought you meant Canada. The made in Sheffield made sense. Now seeing Culver City, I gotta rethink this. Looking up Petko in google books, couple of different names.
1948 Sales Company
1949- 53 Industries
1955 Hardware
Maybe these guys were assemblers, where the chisel blade came from Sheffield, and the wood from Scandinavia. Or they saw Berg chisels, and asked for the handles to be made to look like this:
Image borrowed from Jim Bode, where you can see lots of them
I found this on ToolTalk. It is from Internet Archive but I couldn’t find it. This seems to refer to the concrete finishing tools Petko supplied. No reference to wood chisels. I don’t know if it’s even the same company. IMG_9399.jpeg
I did find an ad for concrete tools also, and that address matches the other things I found, so yes, probably same company.
Shergar
Found in a larger lot of tools today was this Sheffield F Woodcock chisel - well whats left of it (I think it should have an 8 sided handle). Intriguingly it has a British army broad arrow and 1941 stamped in. I’ve not touched it, but somehow theres no corrosion so these must have been a quality steel way back when. Now what to do with it!
