A tire shop i use broke so many of those the store stopped honoring the warranty. He is dirt cheap on everything he does there and you can tell by the sound of the impacts he has the compressors turned WAY up so that probably had a lot to do with it.One of the well known members here blew up the Koken extended version and got the run around about warranty on it too.
As I stated previously, consider all these consumables, especially if used heavily. Some of mine have a 400ftlb max torque warning etched on them.
I don't normally recommend HF but the lifetime warranty might save some hassle and the Pittsburgh Pro set comes recommended.
https://www.harborfreight.com/12-in...lug-nut-impact-socket-set-11-piece-69829.html
Pretty sure a greater wall thickness of ANYTHING is stronger and less prone to cracks, all else equal.Last, as I’ve written recently, I think thin walled impacts perform worse than heavy wall impacts. I think they don’t deliver as much torque and are more prone to cracking, though I’d have to think about exactly why that’s true.
Anti-seize has to change suggested torque value spec’s? Someone smarter than me will know better.I ignore manufacturer instructions and put anti-seize compound on my lug nuts, under them, and between the wheel and the hub.
I’d have to think about this, could be wrong, but I think a 1400ftlb impact gun doesn’t deliver 1400ftlbs the second you pull the trigger. So if your lugs will come off with, let’s say 200ftlbs of reverse torque, I think that’s all they’ll see ish.
Now I DO believe the initial trigger pull of a 1000ftlbs gun delivers more wallop than a 500ftlbs gun.
So here are my thoughts for you:
- If you don’t lube your lugs, you might need more torque to remove them than a thin walled socket was designed for.
- When you know a bolt isn’t frozen, and you want to use thin walled sockets or chrome ones, use a lower torque gun. The monster guns really aren’t a great idea for all the time use. That said, I don’t believe a single burp or two delivers their max torque.
Snap on is pretty good about describing the application. In this case it says:How about these Snap-on sockets designed for lug nuts? There's no plastic sleeve but just take your time and don't hit the wheels...
Snap-on Store
shop.snapon.com
This is a long story involving the definition of "dry torque". Long story short, I apply anti-sieze and don't change the torque spec. On paper, I'm over stretching the lug bolts. In reality, I'm probably closer to factory "dry torque".Anti-seize has to change suggested torque value spec’s? Someone smarter than me will know better.
It absolutely does and is generally not recommended for wheel lugnuts/bolts.Anti-seize has to change suggested torque value spec’s? Someone smarter than me will know better.
Merry Christmas.@AEAdam
Its not just about over-torqued lugnuts and wheel bolts. Think about what they are clamping. The steel wheels of yesterday would take a lot of abuse that will damage todays aluminum and magnesium wheels.
Not so sure I am buying the aerospace engineer degree when reading posts like above. Getting burnt out on following specs? Career fatigue? I tease...![]()
From my Ram's FSM:If you don’t want to apply anti-seize, you really should do something to restore the condition of the hardware to its factory new condition inorder to use their torque numbers reliably. At a minimum, threads should be clean, mating surfaces clean and deburred and a light machine oil like 3 in 1 sparingly applied.
Three out of four are still OK. You may get lucky. Or not. Cross your fingers.Well, I ordered a Titan 22mm.
Only $15. I'll see how well it holds up. Wish I had seen your review first.
I’m not sure what we do at work. I can find out. But we would do whatever is best.I can't be doing with the mess of anti-seize, I don't use it at all on anything and I've been in this game 40 odd years. If it doesn't come factory installed you don't need it!!!!
In my experience it just attracts grit and brake dust and messes up fasteners/threads/clothing/tool handles.
Automotive would do whatever was cheapest. It’s sad but I think new car customers in the US hold on to their cars for about 5 yrs. It’s possible those vehicles will only have their wheels off twice in that time. Once for brake pads and once for tires.
So it doesn’t make any sense for the factory to commit any resources or time to solve a problem for some future owner who is not their customer. Automotive really fights for every penny. I wouldn’t read anything into the corners they cut but that.
The Kia I just did brakes on was a 2016 with 120k miles. The brakes were all rusted. One lug was broken on the drivers side and we broke one on the passenger side (4 lug wheels). Clearly no one put any sort of anything on the lugs, hub, calipers, nothing. Doing nothing is clearly not what engineering intended. Whatever they did at the factory, didn’t hold up and I wouldn't expect it to. I think (obviously) doing nothing is not the right answer.
It’s kind of a **** box, to be honest. I haven’t seen a car that age with that many miles looking so bad in a long time. All our other vehicles are older and in much better shape. My F150 is a 2013 with 205k trouble free miles. It’s my first pick up truck and I’m very impressed by it.It held up for nine years and 120k miles, then KIA want you to buy another one![]()
Socket, Wheel-Protecting Lug Nut
Thin wall sockets for access in tight work areas .Plastic sleeves and inserts protect wheel finish .Large size markings on each socket sleeve for quick identification .High visibility red sleeves help prevent lost toolswww.mactools.com
I think the key is the term "decorative caps". I'm assuming those are plastic wheel covers, not alloy rims.
- Deeper hex geometry allows socket to fit further onto lug nuts, making them less likely to damage or break decorative caps
- Saves technician time and helps prevent potential customer complaints from marred or damaged caps
Interesting. I didn’t get that from the description. I think I’ve never owned a car fancy enough for lug nut covers! Here’s what they said in application:No, their product description has nothing to do with plastic wheel covers vs. alloy rims.
When they mention "decorative caps" they are talking about OEM lug nuts that are often two-piece (chrome cap over steel).
I've chiseled off a few hundred of those. Also had the Snapon 4 socket flip's with half sizes just for those. I was the only tech within 500 miles that used them. LMAONo, their product description has nothing to do with plastic wheel covers vs. alloy rims.
I think the Ko-Ken 4300PMZ.65-22 is non-impact, for those looking for that.Got it! Haven’t used it yet. But, it is now on hand for the next time I remove my wheels.
I don’t intend to use this on an impact gun. I will use a breaker bar, so it “should” hold
up nicely. Even with a breaker bar I still prefer this type of socket to protect the painted aluminum rims.
If the Titan turns out to not work so well, I will give that a look for sure!I think the Ko-Ken 4300PMZ.65-22 is non-impact, for those looking for that.
Are all of these plastic covered thin walled sockets non impact? I think my Bluepoint set say non impact.I think the Ko-Ken 4300PMZ.65-22 is non-impact, for those looking for that.
Ko-Ken calls the ones with the built in extension "Thin Wall Impact Wheel Nut Sockets" and shows a video of them using an impact on them.Are all of these plastic covered thin walled sockets non impact? I think my Bluepoint set say non impact.
Does this stop anyone from using these on their impact guns?
Just guessing- if I were designing sockets, I might design my impact sockets for 10^9 cycles. Chrome, I would size for strength, not fatigue.
I personally ignore the warnings and use these all the time on my impact gun. I know eventually they will go bad, and could, possibly shatter. Knowing this, I ALWAYS wear eye pro when using my impact gun. I probably yank tires off cars a dozen times a year. So could be quite a lot of time before I need a new set. But I think those of you using these more often, should splash out on a new set every so often.
On my high dollar forged wheels I use a standard thin walled socket with heat shrink applied to the OD. Works great for the two sizes I use. No need for a special set.
No. They're anodized impact sockets. Sunex has a 15mm and 1" that are clear anodized though.Are all of these plastic covered thin walled sockets non impact?
