pancho400cid
It all started with Christmas Lights. To add an outlet in the soffit out by my main 16' garage door, I intentionally knocked a sizeable hole in my garage ceiling. The plan for yesterday was to cut out the damaged sheet of drywall and replace it. Unfortunately, when I removed the damaged sheet of drywall, it revealed two cracked 2 x 6 beams in the roof/ceiling framing!
The pics below show the basic issues. "BEAM A" runs across the garage "side-to-side" and has 2 x 4 "nailers" (not sure that's the right term) for the ceiling laid flat and attached at 24" intervals. "BEAM B" runs lengthwise through the garage. Beam B sits on top of BEAM A and is joined via nailed vertical short piece of 2 x 6. I "think" BEAM B is acting as a collar tie for the rafter it is nailed to, but there is a dizzying array of beams up there and I'm not clear of the the intent of all of them.
I'm not sure when or how the damage was done. We did some extensive remodeling about 10 years ago and I had two 8' doors replaced by a single 16' door - requiring the installation of a LVL header beam over the door. Moving/jacking for that to get done may have been when the damage happened.
I am planning to repair BEAM A by sistering a new beam in as below:
1 - Jack up under the damage with bottle jack on a 4 x 4 to get it high enough, with a slab of lumber to spread the load (I don't think it will take much force - needs to come up an inch or two I think).
2 - Trim the 2 x 4 nailers 1.5" back on one side of the beam to make room for a new beam.
3 - Cut a new 2 x 6 beam long enough to be at least 2' on either side of the damage. Pre-drill it 1/4" for 5/16" lag bolts. Maybe 4 bolts either side and 4 in the cracked area = 12 total?
4 - Shoot high strength construction adhesive into the crack and onto the new beam. Clamp the new beam in place.
5 - Drive lag bolts through the new beam and into the broken one
6 - Attach the 2 x 4 nailers to the new beam by toe-nailing or similar.
I would basically do something similar to repair BEAM A. Then I'd be back at the original starting point with drywall repairs.
Any comments, corrections, concerns?
Thanks!
Thanks!
