fishwatcher
- Joined
- Jan 26, 2023
- Messages
- 762
Awesome set up! It’s very clean. The 8” Yost looks great. I have a 6” Capri that is similar.I recently put together a new workbench for my new garage.
Started with this Lowe's Kobalt worktable what I snagged on sale back around Thanksgiving: https://www.lowes.com/pd/Kobalt-Kobalt-72-in-Work-Table/5000045517
And this Yukon 46 inch 9-drawer toolbox. You know the one. Also purchased on sale earlier this year: https://www.harborfreight.com/46-in...-cabinet-with-solid-wood-top-black-56613.html
They're both fine, not industrial quality but totally suitable for heavy residential use.
I pulled the jointed wood top off of both and used/reserved those for other projects. The Kobalt top became the top for my wife's workbench and the Yukon will eventually crown the cabinet we're building to hide our hydronic heat hardware.
I replaced the pilfered tops with cheap box store 3/4" ply; I used a double layer for the main table and a single layer for the toolbox. I cheated the top forward on the table so that the legs would be nearly flush with the wall in the back.
Then I applied some 1950's style boomerang Formica laminate, routed the edges, bolted on a big vise, and replaced the toolbox casters with lower ones that swivel at all 4 corners.
In normal use the box stows under the workbench with enough frontal overhang to allow plenty of room for feet and knees:
When I want more work surface the box easily pulls out and can be parked wherever needed:
The Formica top turned out very nice and is a great work surface so far - very hard and smooth. My wife and friends didn't think I'd actually follow through with the boomerangs; they should know better by now.
I've never done Formica work before but install was a simple as brushing both surfaces with contact cement, putting the laminate on top, and then encouraging both parts to bond with a soft hammer. It would have been much harder if I had needed the edges to line up exactly, but that's why I planned to hit it with the router.
I was a bit concerned that the 8 inch vise would be too big; so far it's been very handy and also does double duty as a respectable shop press:
The last step was to run a 5/8 structural screw through the frame of the table into a wall stud just to keep the whole thing from rocking or moving when I get medieval with the vise.
It's all very solid, I couldn't ask for a better bench.
Behind the bench.. you could take advantage of the wall space with a peg board or shelves.. but then it won’t be as clean looking.
