Steel_Rain
- Joined
- Apr 23, 2024
- Messages
- 1,378
I don't know the differences. But both the A2 and B2 are the current versions. The A and B are obsolete.
You too?Are those compatible with Xcelite?
| Series Letter | Approx. Logic | Design Focus |
| P (PA 14mm) | Early 2000s | The "Speed" Era: Light springs, shallow teeth, buttery smooth. |
| Q (QA 8mm) | Mid 2000s | The "Hybrid" Era: Still smooth, but starting to tighten tolerances. |
| T (TB 15mm) | Late 2000s | The "Strength" Revision: Orange ring introduced. Teeth cut deeper. |
| W (WB 7mm) | 2010s+ | The "Final Tightening" Spec: Maximum spring tension. Highest backdrag. |
Useful for much other than sheet metal bending?But these Tsunoda are superb in every respect, and reasonably priced too. These live in my aircraft tools box.
Oh yes, very useful.Useful for much other than sheet metal bending?
With a 6x3mm tip they're not much off a normal needle nose in that respect. Spec: https://www.tsunoda-japan.com/EN/itempage/DBP-200.html
They are actually the default pliers I reach for most often unless I need a specialty tool. Dollar per use, this might be the best tool I have ever bought.Useful for much other than sheet metal bending?
Those are Wilkinsons flat nose pliers. Decent tools. Not flashy, but very nicely ground, and thin jaws. Sadly I can’t give a part number as Wilkinsons didn’t always put one on the tool, and the packing is long gone.What is the part # or link for the pliers above holding the fuse?
awful parallel flat nose pliers. I wish I knew where to find nice ones.
www.maunindustries.com
Their flat nose range is quite difficult to discover. Aside from models that only come in mini sizes:One modern manufacturer of similar pliers is Knipex. Their part number would be 20 01 160.
I have some Maun ones too, but they don't seem to make ones with this long, slim shape. I used them just yesterday to hold the side of a small nut in a space with tight clearance. Maybe there's some Japanese thing that does this job better.Parallel Pliers: UK-made Parallel-Action Pliers for Grip - Maun
Equip yourself with Maun parallel pliers, for precise & reliable gripping/bending. UK-made parallel-action pliers, ideal for professionals, DIY'ers & hobbyists.www.maunindustries.com
"fingertip" wrench might be a solution.to hold the side of a small nut in a space with tight clearance. Maybe there's some Japanese thing that does this job better.
Spotted new Tsunoda mini water pump plier, with button
株式会社ツノダ
プロフェッショナルの作業現場からホビーや暮らしのメンテナンスまで、日常の様々なシーンで活躍するペンチ・ニッパー・ラジオペンチ・プライヤー等の作業工具の企画開発、製造、販売。工具メーカーツノダwww.tsunoda-japan.com
Looks just like the Knipex Cobra XS. Great find, would be curious if someone that has both would do a side by side comparison.These are made in China, so if anyone wants a cheap Knipex mimic, might as well get the WorkPro version, unless the Tsunoda logo is cooler or something.
That's aircraft spec socket. I believe... the aerospace spec is a looser tolerance on their sockets because it needs to grip painted fasteners. ?Ko-ken RSAS2405A, got the set for 74 NZD (~43 USD). Better polish and chrome, and a few thou smaller OD compared to the standard sockets.
I’m by no means convinced that’s the case.That's aircraft spec socket. I believe... the aerospace spec is a looser tolerance on their sockets because it needs to grip painted fasteners. ?
Please do give us your reviews. I have the sae Eight set through 3/8". I used it quite a bit in the garage a few days ago tearing into an older planer. I was very pleased.
Also very interested for reading more about these. How are the coatings? I have a set of Vessel, which has a durable coating but I find it a bit too thick and uneven - the eight looks better from the photo in that regard, more like some sort of anodization than paint (but probably less durable?).
I used my Eight set tearing into an old planer a few days ago. I was pleased working with them. Several screws had rather shallow broaching which they handled well. The ad verbiage for my sae Eight and color-coded metric Wise sets say the technology/engineering on the ball ends makes them good enough for final tightening but I won't ever use the ball ends for that. I know better than to tempt fate.I'll put together a more in depth review this weekend, but so I'm very pleased with the performance both of them. A notch above PB Swiss, I'd say.
F-22, you are correct with the Eights bening anodized instead of painted. It is very thin, so would suit your preferences, but I highly doubt it is durable...there were small chips in it straight out of the packaging. It's my one gripe with them.
Looks like an old Oxwall set I once had.
