Mike65
Horse Pasture, Va.
In preparation of the upcoming snowstorm I moved whatever was on the r/s of the Mustang to the left side to make room in the garage so we moved my wife's two motorcycles so we could get her Bronco Sport in the garage once it comes back from the dealership tomorrow. We moved the trike in front of my Mustang & put the Kawasaki next to the Mustang with plenty of room for her Bronco Sport. My F150 will go in the carport.
Hal
Vermont
Last of three days nibbling away at a batch of waste oil I got off Facebook marketplace. I really like it when someone has a barrel to give me, even if it’s not full. This batch was an old accumulation of five gallon pails and one gallon/five quart jugs. Five pails and thirty jugs. So I get to empty everything, rinse them with some bad gas someone else gave me, crush them and put them in the dumpster.
Most of the jugs were pretty good, but a couple had real sludge in the bottom. The pails, on the other hand were a trip. One was antifreeze, with a little oil floating on it. One was a solid block of ice, and two of the others had chunks of ice in them. At least in this weather, there was no liquid water.
I wound up with about forty five gallons of useable oil. I’m going to have to clean up the antifreeze and test it. I’ve got a tractor that will use it. The ice will melt some day, and I can float the residual oil off it. IMG_4430.jpegNot on the list of approved fuels.
larry4406
Northern Virginia
I assume you run a waste oil heater?
Mezz2006
Clintonville, WI
My Harley would just fit through the front door of my apartment if I wiggled the handlebars right.
Not sure the layout of your house, but the living room would keep the bikes nice and toasty and make more room in the garage :)
Buddy in college parked his dirt bike in the living room of his house over the winter. He was known to be found sitting on it making dirt bike noises with his mouth when it was really cold out. Every once in a while he would even start it up.
evildky
Louisville, KY
Kinda... didn't drill well, too hard. Got a starter hole drilled and carbide burr, hand filed real close. Final fit 320 grit wrapped on a sharpie.
For the Icon G1 1/4 drive flex head ONLY, Tekton small body, $9ea. 3 kits yields free shipping. I only used the toothed square drive out of the kits.
Can still see chrome layer on lower half, gray raw steel upper half.
Was some work but I got what I wanted.
Quick release, soft handle, small body flex head.
why not just get Tekton ratchets? I recently pick up a couple because they have the release button, replacing a couple of snap ons that don't have the release. My biggest complaint is the directional switch on the Tekton is just too low profile to easily switch directions on the fly.
WisJim
Menomonie, WI
I used to keep my BSA Victor (441cc single) in the kitchen of the little house I lived in so that it was possible to start it in below zero Wisconsin winters, so I could ride to visit my folks. I only dropped it once on the ice in the winter, on black ice on a city street.
niget2002
Josephine, TX
Dad likes to tell a story of riding his Yamaha 650 across Texas one winter. Stopped at a hotel. Next morning he woke up and the bike had ice all over it frozen solid. He pushed it into the hotel room and used the blow dryer to melt the ice onto the floor so he could get it to start.
Crazyjake8493
Upstate NY
I was snowblowing a dog path around the yard and when I adjusted the chute something felt off, but I didn't think anything of it and carried on. On my final pass coming back up to the garage I went to adjust the chute deflector and the handle was gone. The screw must've been loose and backed out.
Covered all my tracks with a flashlight and at the very far end, the handle sat right in the middle of the path. I was sure it'd gone through the impeller and into the woods. Screw was gone but I cut down another 8-32 stainless screw and put it back together, this time with a little blue Loctite.
kaymccampbell
Upstate New York
Drilled n countersunk the fixed hold downs. Installed them in the burner. Tested. Shimmed n reinstalled. Tried to clean up the magnetic hold downs. Wound up soaking them in acetone and salvaging the magnets. Checked n relit the boiler pilot. Cleaned out the burner cabinet. Remixed and printing the magnetic hold downs with little retainer bumps for the magnets. Remeasured for the potential doors around the boiler, etc.
Edit: printing is done. And the burner is ready to go.
GRN96WS6
SOMD
Replaced this in the old Ferd before the potential incoming storm (I'll believe it when I see it) and got to use my new HF magnetic mat, that thing holds some weight!
Also those blasted trans cooler lines are the worst, rust and grit builds up around them and they don't spin so easy, you have to soak them in penetrant and hope and pray!
vwpieces
Hills, PA
Seen the ratchet thread for modifying them? Most are re-handling them.
Thanks.
I want to keep it small. Jokingly said electrical tape, but that or a sleeve of adhesive lines heat shrink tube is all the bulk i would want. Mini 3/8 ratchet in 1/4 drive body. Koken comes close but $175 and a little shorter. Think I have $70 in both with conversion kits.
bugnut
Central Ohio
I have mentioned here a couple times in the “what did you do in your yard” about filing deer feeders. I currently have 4 in the field. One of the recurring issues is the feeder motors only last a couple years. Critters, ants, wear, rotted batteries etc lead to failure. To change them out one has to drain all the remaining corn out of the feeder, make repairs and then refill the feeder. Because none of these are in my back yard and require a drive-it sometimes necessitates 2 trips, either from the vehicle or from home. I do take extra batteries and misc parts in a 5 gal bucket, but if it is more than that I have to get barrel sized containers and drain the corn. Then effect the repairs and refill. So I recently decided to change all of that and make a quick attach feeder motor assy.
Parts required:
Dollar store plastic trash can & wire trash can
3d printed blast gate
3-20mm neodymium magnets
3d printed backer ring-acts a stiffener for the magnets
1 steel ring 6” od x 4”id x .12 thk
Moultrie or other feeder motor
Misc hardware
When assembled as shown the four outermost bolt holes in the blast gate secure the assembly to the barrel/feeder. When affixed I can now close the blast gate, remove the motor assembly in it’s entirety, because of the magnets and replace it with another unit.
Another benefit of this setup is it has been keeping, *****, squirrels and birds out of the feeder motor and assembly. The upside down trash can focuses the throw into a smaller area also.
Thanks for looking!
2001ZR2
Kansas City
Like many others I have trying to complete needed outdoor and garage activities before the forecast storm...not sure about the snow predicted but they got the temperature right. 16 F and falling as I type this.
I replaced the throttle body and gasket on my wife's truck which should fix the cold induce throttle position errors we have been getting. Also moved the Sam's run up from Saturday to last night as I was topping off her fuel.
Hohn
Diesel Central, Indiana
Changed oil for someone I didn't know except by text. Through our church, I donate oil changes to those who need them and aren't able to for financial or other reasons.
Car was a somewhat rare Accord 6speed with leather, 2017. Sweet little ride. K24 purring as expected after 110k.
It's a win-win. I get some help undoing the massive (and embarrassing) stash of premium oils I have accumulated (all full syn) and filters.
I have motor oil ADHD (as part of general ADHD) and have a lot more oil than a person should have in his garage given the rate of consumption. So I'm trying to step up the rate of oil change donation (and slow the rate of acquisition) to drain the inventory down a bit.
jshillin
PA
You have a lot of the same toys that I have!! I use them a lot, then they sit unused for some time.
LanceMc
Texas
It's been busy getting ready for the cold and winter weather coming.
WInterized our Airstream, the hose bibs around the house and the shop and got the generator out. I still have pretty low confidence in the Texas grid. When we built this house we chose a really nice fireplace, more of a wood heater. So, as long as we have wood, we won't freeze. I built a box out of polyiso insulation to protect our olive tree. Last year when it got really cold for a few days it froze the olive tree even though I had it covered up with blankets. Hopefully it doesn't get frozen.
IMG_5930.jpegI only have enough generator to run the fridge, the internet modem and the fan on the fireplace so in the event the electricity goes out the well won't be running so I bought some water storage capacity. 440 liters total so about 116 gallons. These were used to ship garlic stuffed olives from Greece. I think the terracotta color is more appealing than the blue barrels. Makes it feel like more Roman lol.
I did manage to do more socket drawer organizing. I added two sets of new sockets. 1/2" 6pt deep metric and 3/8 6pt shallow-both Craftsman V-Series. I like the Ernst socket rails but the trays take up too much space for my needs. I have a few used Craftsman USA sockets on the way to fill the holes thanks to the good people of this forum.
kaymccampbell
Upstate New York
Well, it's like everything, I have many toys because I have many interests. You can't do them every day, or they'd be work. So they get used while I'm engaged, then left til the next enthusiasm in their direction. Sometimes I lose the inspiration to do things in a specific line for years, but then suddenly the desire comes back again. It's been my life.
The nice part about enlarging my tool and skill sets is that when I go to do something adjacent that peaks my interest, I've already got the major part of the tools and skills, so I don't suffer that expensive hobby start or lengthy and disheartening learning curve. It also doesn't hurt so much to drop a hobby after a project or two, because I have the experience to know that although that particular thing didn't interest me, I understand that what I added to the tools and skills will be applicable to the next interesting thing.
evildky
Louisville, KY
Show the one with...
Standard length
or long ?
Beerhippie
Far NE Oregon
Descaling a Rinnai, again. Setting up for some food photography this afternoon.
Got a couple of coats of Rusto Gloss Black on the transaxle mount for the Brick, despite the miserable weather:
Should be ready to go into the oven later today. My trick for painting outside on a 25F day with heavy ice fog is to heat the parts up to a little more than warm to the touch and warm the paint can up to about 80F. Works pretty well, but not something I'd do where I really care about the appearance. This is for rust prevention, and it'll be fine for that.
Hoping some parts and supplies come in today so I can get on with things this weekend.
larry4406
Northern Virginia
Man this seems like a frequent occurrence for you!
I recall you saying that you have these set up to heat brewery water to mash and sparge temperatures vs residential "hot water".
Sounds like your water source is quite hard.
How do you assess the frequency of cleaning? Temperature rate of rise falls off?
Beerhippie
Far NE Oregon
True, all.
Our water has about 200 ppm of carbonate hardness--the bad kind. It depends on which water source the city is using at the time--we have springs and several wells. Surprisingly, the springs are harder than the wells.
I don't know why the well water being softer than the spring water surprises me, but it does.
I clean them when the tell me to--by code. Usually code 14. This time of year, I'm descaling about every other week on one of the them that does the heavy heating and monthly on the one I'm doing today.
And, yes, our usage is totally off-label. It's the recirculation heating of water in the tank that really clogs 'em up.
kaymccampbell
Upstate New York
True, all.
Can't run it through a softener and salt filter?
