I knocked out quite a bit of work on the Subie last night before dinner and we got a visit from our kids and grandson.
Cleaning is the worst part of this job, but I learned many, many years ago that cleaning and preparation is one of the most important steps in the process. I see all too often people rush during the teardown just to get to the reassembly, but skimp or do the most important part half-assed. If the surface isn't cleaned of all remaining sealants and/or debris you are pretty much guaranteed a leak. Areas to focus on in particular are the areas where two components meet and create a corner or change in direction, but the gaskets struggle to seal in these areas and therefore most every manufacturer recommends some form of sealant in these corners. Unfortunately, access on this particular vehicle is less than optimum with only having a couple of inches between the frame rail and the head surface of the cam cover. The upper half isn't terribly bad, but the bottom half is another story.
I purchased this extra long scraper about 30 years ago and although it doesn't come out of the toolbox very often these days, when the situation calls, it's priceless for reaching those difficult areas.
The plastic razor blades also prevent gouging of the aluminum surface or scratching the cam lobes, neither of which are desirable outcomes.
Once I have removed all of the material with the scraper, I run over the surface with some Scotchbrite to ensure nothing is remaining. Then I will give everything a wipe with a clean towel and some brake wash just before assembling the cover.
With the surface cleaning completed, I moved on to cleaning out the spark plug wells and then removing the spark plugs.
New plugs ready to be installed.
New plugs being installed. I have this old rubber install tool from several decades ago but I still like using it. A piece of fuel line works just as good, but it doesn't have the same sentimental feeling as an old and reliable tool does.
With the plugs installed and snugged, they can be torqued to spec.
New gaskets opened up. The correct spark plug tube seals were selected.
and installed.
At that point the engine side of things is ready for reassembly.
More to come.
