Grinder recommendation
tmshort
Central IN
Looking for a bench grinder to run a 6" deburring wheel. I use it for airplane parts for a kit I am building. These are often long / bulky.
I'm trying to find a grinder with the smallest diameter body, as this is often what interferes with deburring.
Any recommendations?
I have an old Delta variable speed one which works ok, but was hoping to pick up a second to use with additional wheels and wanted one that is slimmer.
GeoBruin
If clearance is an issue, and if deburring is the primary use case, consider a buffer which has longer shafts and no guards.
T
tmshort
Central IN
Thanks. I’d thought about that but it seems like buffers (for whatever reason) are much more $$$, especially with variable speed (the fixed ones just run too fast for my use).
Any recommendations for a decent buffer?
GeoBruin
What kind of SFM are you shooting for? Dayton offers this one if both a 3450 RPM and 1750 RPM. Here's the slower speed model:
Dayton Bench Buffer, 1750 Max. rpm, 1 Phase, 60 Hz 499F67 | Zoro https://share.google/HTiOVXRSmAGBUAiVG
As you mentioned, the variable speed models are more expensive.
Harbor Freight has a variable speed grinder in both Bauer and Hercules flavors for pretty cheap. Not the same long shafts as a buffer but you could still remove the guards to get some more access.
8 in. Variable-Speed Bench Grinder with LED Work Light https://share.google/PtpSjTJs7oXKDjNeI
T
tmshort
Central IN
My old Delta shows 2000-3400 rpm, I run it middle to low end so probably mid 2000’s. Which is right in between the dual speed options I have found.
What is it that makes a variable speed one cost >500$??
I guess I can try some different speeds and see how it works, maybe I could go with one of the slower models.
