I hope everyone had a nice weekend.
Friday night I worked late to get the Subaru completed as the couple was leaving on vacation Saturday so I wanted to have it completed so they could pick it up early Saturday morning, so that meant getting it completed and a thorough road test on Friday night.
I pulled the plug on the transmission and got quite a bit more than I expected even just pulling the fill plug, but then again, it hadn't been running for a few days. The oil was quite dark and definitely needed to be replaced.
With the oil draining from the transmission I cleaned the belly cover as it was oil soaked from the leak.
It cleaned up pretty nicely.
New gaskets/seals for all of the drain plugs ready to go back on once the plugs are thoroughly cleaned in the solvent tank.
This is for Cody, aka
@madison069 as he asked me to measure exactly how much came out of the transmission and how much I would put back in. I have a gallon just full and the mix-ratio cup has 16 oz in it, so here is 4.5 qts.
Here is another 16 oz. so now 5 qts.
And about another 3.4 oz, so all in all just over 5 quarts is what I got out of the transmission.
With the drain plug back in the transmission, I pulled the drain plug on the front differential and it actually looked much better than I expected.
Nothing on the magnet either.
Drain plug cleaned and new gasket installed, ready to be reinstalled and torqued to spec.
Stay tuned for more.
