closet light swith
rlwhitetr3b
East Central Illinois
We have a closet where the door fits so tightly you can't tell if the light is on when the door is closed. I want a switch that shows when the light is on. Having one that is lit when off would mean that we would have to remember to notice something that is missing.
What type of switch do I need?
BillK
Beautiful Southern Maryland
The problem with lighted switches is that they usually need a neutral. Most switch runs just break the hot wire going to the light. You need to pull the switch that you have now and look to see how it is wired and if there is a neutral in the box.
PCustoms
VT
The jamb switches I have installed are a PIA to notch the trim, the adjacent stud, etc. Granted, these were retrofits.
I could see that. Typically installing any switch receptacle after the fact is more involved
OP could also do a timer or occupancy/motion bulb or switch.
That red indicator would look too out of place for me
mike93lx
Richmond, VA
OP could also dona timer or occupancy/motion bulb or switch.
And with an LED light, the cost of letting the light stay on won't outweigh the cost of the switch until you get into a year+ of runtime
PCustoms
VT
I was thinking that too, unless its an infrequently used closet I'd probably just leave it alone
danfromsyr
Cicero, NY
in my garage and basement I have a Motion sensor LED bulb,
it just screws into the socket and I leave the circuit on
it's really quite handy. I put them at the far side from the entrance.
there are 2 types a 'radar' and 'infrared'
the radar can see me through the door so it's on before I get there..
you wouldn't want one of those.
R
rlwhitetr3b
Also our house is already finished so I would have to open the wall where the current switch is and the inside of the close to run wires from the light to the jam switch.
R
rlwhitetr3b
From what I just watched on line, a code change in 2010 required a neutral in the switch box. I house was built in 2008, but our electrician seems to have run power to the switch box and then to the light. I checked and I'm good to go.
JohnX14
Boston 'burbs
For a simple closet light switch in a bedroom, can you just look and see if it is on or off? We used indicator light switches for attics, etc, back in the 80's and prior. With all due respect, up is on, down is off. For a simple closet light....
rawen2
High Desert of CO
If it's a standard toggle style switch you could color the bottom side of the toggle with red sharpie or nail polish. It will be visible when the switch is up and be hidden when the switch is down. Won't work as well with a decora style switch although you could color the thin side edges of the toggle.
