Gopherboy6956
- Joined
- Dec 19, 2021
- Messages
- 147
Hey Everyone - I'm getting ready to frame up and get my loft trusses built - just going through adding it to my sketchup model to try to head off any issues -
When i'm framing the headers for the trusses to land on around the stairs - what's the best way to support the wall end of the headers?
I did each side of the stairs here differently to get opinions. On both ends I extended the headers into the wall (I haven't insulated or covered the framing yet IRL) as i figure that's the best way in general - but supporting it is where i'm torn.
Each header really wont be supporting THAT much weight - the header on the low end is a 2x8, the one on the high end is a 2x10 beacause it also has to support the stairs. The headers are set below the top plates because the trusses have double top plates at the end and will hang off these headers.
Low end - land the header on a board in the wall, then just nail some support boards to the studs to support that.
High end - land the header on a board in the wall, but then run a 2x4 or 2x6 all the way to the bottom plate.
Thoughts? Something better i'm not even considering?
Thanks!
Then this is the overall truss layout, just incase anyone was curious. This will cover just about half of my shop.
Thanks!
