YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 502
I have a 2019 Honda Odyssey with the 3.5 L J35Y6 V6, rust belt. I got the car as a used car, and it has 70k miles on it, so likely the first itme the crank bolt will have come out since it was installed at the factory. I have a older Milwaukee high torque impact that I got a few years back at Home Depot, 2663-20. The nut busting torque is advertised as 640 ft lb. I know this is nothing compared to modern day stuff, and likely equivalent to a modern day mid torque impact. I was also planing on pairing it with an Astro Drum Socket, #71019
Will this be enough to get the bolt out? I'm a bit scared of trying to maually unfasten the bolt, and sheering off the head of the bolt, given my bad luck. So I'd rather use an impact if possible.
Anyone have any experience getting honda crank bolts out with modern day mid torque impacts? If you didn't have success on getting the bolt out, what impact and socket were you using?
I'm debating on if I should bite the bullet and get a modern high torque impact. I'd hate to start this project and not be able to get the bolt out.
