What’s it called? Flippy lever bolt thing.
no704
This is on a drill press. I would like to find something similar for my milling vise stop. The cap screw and loose allen wrench *****! Thread is 10-24. Thx
Blueshound_GJ
I would call it a quick release or cam release. Bicycles use them for wheels and seatposts but those are much smaller. I've never seen an M10.
dscheidt
It's some variety of adjustable handle, but I've never seen that variety for sale or listed in a catalog, just on tools. The commonly available kind use a bolt, and the handle is a wrench. spring tension keeps it engaged, but you can pull back to change which flats it's engaged on. should be available from your favorite industrial supplier.
dscheidt
They're not a cam, it's just a folding lever attached to screw threads. Folding lets you turn it fully, even if it's too close to an obstruction, and you can easily spin it for large adjustments.
N
no704
Might have to build some. Id much rather find something off the shelf. Ive seen them smaller but don’t know where? Drill press is the only example i have on hand.
545_days
Texas
My Jet drill press uses the same part. I would assume you could order a replacement as a spare part from Jet, Grizzly, or some other tool seller.
Edit to add: In a 10-24 thread? That is way smaller than the handle on my drill press, so ordering a spare in that size is unlikely unless you can find a tool with a similar handle that small.
larry_g
oregon
search for an eye bolt or a cam bolt clamp. With a machined eyebolt you could make the handle.
whateg01
doo dah, kansas, usa
Not sure I've seen them that small. Maybe I have but not exactly like that. The ones I've seen that were small have a sheet metal "lever". I think I would shoot for a thumbscrew vs something with a lever. It would **** breaking off a #10 screw in a vise jaw.
N
no704
The # 10 screw is the vice screw co to speak. Its just a vice stop. Its basically a cap screw with an extended cap with a handle on it.
N
no704
Perhaps the actual handle would be 1/4”. I know i have seen this elsewhere just not sure what to call it for s earch
N
no704
Might because a project for my inturnrs! Lots of setups to be learned.
whateg01
Yeah I get that. I'm just saying that having that extra leverage means it'll be easier to break it off and that would ****.
I've never seen screws that size in the style you asked for. They usually look more like this.
OccupantRJ
Eastern North Carolina
Search Reid Supply. They supply tooling clamps and such.
N
no704
This is what im looking for! What is it called?
rjn2649
Il, A little west of Chicago
I think this is more what you're looking for.
Yeah, I think it's one of those things the manufacture name became the generic name, sorta like "Kleenex" but I can't think of it.
As far as a cam lock I don't think you will find one that small, as I believe someone else said, at 10-24, or even 1/4' taking a lot of material out of the stud for the cam.
whateg01
I wish I knew. I've made a few of them over the years. Not hard to do if you have access to the right machinery. They are common enough that it's hard to believe each is custom made for the application. Nothing I've searched has come up with it though. In the time I've spent looking just now, I could have made one.
N
no704
Likewise! Lol. I’ll just make some!
rjn2649
I should have been clearer, a cam lock AS PICTURED. With the cam being a piece metal that sits IN the stud the stud would have a lot of material removed.
This is more like a bicycle skewer
But out of all that, the OP didn't show a cam lock, or what ever you want to call it. He showed a stud with a handle. while I'm sure there is a name for it, I can't think of it.
N
no704
not looking for a cam lock. Just a stud with a shoulder and a a handle.
Blueshound_GJ
Metric doesn't use threads per inch for thread pitch. It's simply the spacing of the threads so a M10x1.5 would be 10mm diameter with 1.5mm space between adjacent threads.
Here's a chart to help you.
Thank you! Has been a while and I mixed up metric and and standard.
bugnut
Central Ohio
A quick search yielded the results below this does not have the floppy handle but the spring loaded style providing much more leverage. Example below is metric but also plenty available in sae. Keyword search is "spring loaded clamping lever"
Example products​
  • Morton M6X1.0 Adjustable Clamping Lever
  • RS PRO Adjustable Clamping Lever M10
Also if you really want the cam lever style Carr Lane sells them in various thread pitches:devilish:
tarbellb
Oregon
Has GJ been stumped?
I don't see a direct replacement, good alternatives yeah. But no 1:1???
Anybody have a direct link to this exact style of lever? I'm truly curious at this point.
mike93lx
Richmond, VA
tarbellb
Oregon
whateg01
Nice work
So it's a "lock handle", very elusive name
seems to only exist as a drill press table direct replacement and not a more universal piece of hardware? Makes sense I guess, not a terribly great design.
Same style is used on a couple of my drill press vises, so it's not completely unique to the drill press itself. The one like I posted a pic of I've seen in a few places, like on an xy table, funny enough, for the drill press. Ok, maybe it's unique to "drill press use" items.
