Snap-On Counselor II MT3000A Okidat Printer Model OL600e
Ohjai
I just purchased an Okidata OL600e for my MT3000. The onlt selection for a parallel printr is the Snap On printer. I select this printef\r, says my Okidata is on line and out of paper. I put in paper, select print and the Okidata starts wiring and twerling but no paper comes thjroug. The MT3000 says printer error, consult printer manual.
Is there a method for me tro add the printer drivers for my printer?
Revlimiting
Counselor II user manual does not indicate that OL600e is compatible with it. Then how do you even know that the printer you purchased is even functional? Drivers for the printer are pre set on the the eeprom on the communications board, there is nothing you can do there, other than use what snap on wants you to use.
this is what is says on other printers:
Other Graphics Printers The scope's 72 and 75 DPI (dots per inch) settings are intended for use with other parallel printers. For example: • HP Laserjet and Deskjet printers accept the 75 DPI graphics format. • Some Epson printers accept the 72 DPI graphics format (05 hex). • Other printers may emulate HP 72 or Epson 75 modes. ✓ Some Epson printers use the 05 hex graphics mode. If your printer does not use 05 hex, it cannot be used with the scope. Refer to the printer's instruction manual to determine if it will accept 72 or 75 DPI format. If it does, you can use the printer with the scope. Setup 1. 2. 3. 4. 5. 88-14 Follow the setup instructions included with the printer to select the graphics mode or emulation mode that allows the 72 or 75 DPI operation. Use the EAW0072C00A Parallel Printer Cable to connect the printer to the scope. Turn the tester on. To access the Communication Setup function: Press the Option Menu key, -- Press Scope Setup (F2), and Press Comm Port Setup (F4). A flashing cursor appears over the Port A option. Select the appropriate graphics format (72 or 75 DPI). Press ENTER to complete the Communication Setup. If the Communication Setup function is exited by pressing any key other than ENTER, the new setup is not saved.
  • Like
Reactions: RTM
O
Ohjai
The Okidata OL 600e is listed in the service manual for the MT3000A but it does not show up on a MT3000 screen choice. I purchased a MT 1670 Scribe, got it today and hooked it up.
Shows paper jam, probably because there is no paper in it.
Revlimiting
It won't show it as an option, only the 1670 and scribe 2 3010 is there . Weren't you looking for for mt3100 4 gas internal unit to the cabinet? There is one on ebay now.
NightSky
Southwest OH
Have you checked that the printer can emulate the HP 72 or Epson 75 modes and, if so, then check the setup menu on your printer to see if it is set to do the emulation?
