DocsMachine
- Joined
- Sep 16, 2006
- Messages
- 1,938
As we were talking about big boring bars earlier, during one such conversation, I idly checked eBay and almost immediately ran across a combo deal in my price range.
A Kennametal CNMG 1-1/4" diameter boring bar, with a hard-to-find Aloris CXA tool block that takes 1-1/4" bars. (Aloris only sells CXA blocks for 1" bars, today.) It was rusty and well used, but the seller was asking right about what the tool block itself usually goes for.
Even though finances aren't as flush as I'd like them to be, and I have no plans to do any heavy turning like that again in the near future... well, I'm still a tool geek at heart so I hit the BIN button.
Here's what I got:
It's not as bad as it looks. It's light surface rust, and only on the upper surfaces, so that tells me this spent some time in an unheated shop for a while- and overall, likely hasn't been used in many years.
So first, I hit the mounting dovetail with some Scotchbrite and WD-40...
... So that I could mount it in the toolpost and break the clamping bolts loose. But first, I also scrubbed the rust off the shank of the bar...
And once the locks were loose, she slid right out.
A little more scrubbing and wire brushing got almost all the rest of the rust off, and a similar scrubbing on the tool block cleaned it up, too. Neither will ever look "new" again, but that's all right.
... Maybe I'll degrease 'em and try some gun blue.
The nose of the carbide seat/anvil was, as is so typical, cracked off, so I simply reversed it. I have some new ones, but might as well use this one up before slapping one of those on.
And, here's where things went sideways.
The hex inside the clamping screw was almost completely stripped out.
It had just enough grip to kind of seat, but wouldn't hold the wrench to loosen. I had to grab it with a vise-grips to get it back out.
Those I don't have a replacement for. If this was a time-crucial job, I could rob it from one of the square-shank tools, but in this case, I just ordered a two pack off eBay again.
Toying with the idea of getting the later model clamp, too, that has a longer nose and a pin that hooks that center hole. Not 100% sure it's compatible- this is a long-obsolete model of bar, but I may try. There's also a later style of pin that holds that lower anvil, and helps retain the insert through that same center hole. This bar wasn't designed for it, but if I can find an appropriate size pin, I may redrill and tap for it, to add the extra security.
But, overall, it cleaned up nicely, and I have no doubts it'd do another job like I just ran, with aplomb.
Doc.
Here's what I got:
Doc.
