Save your time & effort by changing just the outlet for a new one. They are cheap enough.The little screw that holds the faceplate to the electrical outlet looks broken off inside the outlet. I guess it was a plastic screw? I’d prefer to extract that screw so I can put a new faceplate on. Suggestions?
This is a very good suggestion.Save your time & effort by changing just the outlet for a new one. They are cheap enough.
Sheesh...Make sure you use this tool! Easier to hold while swapping out the wires...plus safety in case you leave it powered.
Just turn the main breaker off if you can't figure out what circuit it's on. There's absolutely no reason to do it while it's energized.Make sure you use this tool! Easier to hold while swapping out the wires...plus safety in case you leave it powered.
I'm not so sure that isn't actually a great idea if you were tying them in all day longMake sure you use this tool! Easier to hold while swapping out the wires...plus safety in case you leave it powered.
I've worked in many buildings with tons of computers running. Electrical panel not marked, and the owner wouldn't permit the main turned off. Plus they wouldn't pay me to come in on Sunday to do it when the office is largely empty. So for one desk outlet that needed replacing, this tool would have come in handy.Just turn the main breaker off if you can't figure out what circuit it's on. There's absolutely no reason to do it while it's energized.
It's more of a homeowner/DIY tool for the occasional problem. Or folks with arthritis - holding a small weird shaped receptacle is difficult. But this thing might actually help.I'm not so sure that isn't actually a great idea if you were tying them in all day long
My brother has tried to get me to give him this tool, and he works on alot more 115v jobs than I do. So there seems to be a place for it.Sheesh...
I will never need one but if you think it is a worthy device then buy it and enjoy it.I've worked in many buildings with tons of computers running. Electrical panel not marked, and the owner wouldn't permit the main turned off. Plus they wouldn't pay me to come in on Sunday to do it when the office is largely empty. So for one desk outlet that needed replacing, this tool would have come in handy.
There is no such thing as 115v system.....It's been 120/240v since the mid 1930sMy brother has tried to get me to give him this tool, and he works on alot more 115v jobs than I do. So there seems to be a place for it.
Potato, potatoe!There is no such thing as 115v system.....It's been 120/240v since the mid 1930s
Accuracy is important!Potato, potatoe!![]()
Bolded for emphasis and ironyAccuracy is important!
I shows your level of knowledge and competence.![]()
It can be funny when someone else does it thoughJust turn the main breaker off if you can't figure out what circuit it's on. There's absolutely no reason to do it while it's energized.
I feel like there certain things that if you have to ask, then you probably don't have any business attempting yourselfIn the time this thread has taken to write the comments the receptacle could have been replaced & tools put away.![]()
In the spirit of GJ, the OP should buy a Faceplate Broken Screw Removal Kit. Preferably, by Snap-On. With Teal Blue handles.
In the spirit of GJ, the OP should buy a Faceplate Broken Screw Removal Kit. Preferably, by Snap-On. With orange handles.
FIFY. Only $2779 on eBay, they're the really super rare collectable ones... Orange is so yesterday.
I prefer saving my money, and therefore go for the HF Pittsburgh model....FIFY. Only $2779 on eBay, they're the really super rare collectable ones... Orange is so yesterday.
X2 ^In the time this thread has taken to write the comments the receptacle could have been replaced & tools put away.![]()
Perhaps true. But sometimes you just have to take the time to fix things that never should have broken. You have to show your stuff who the boss is. Otherwise the revolution will spread.I feel like there certain things that if you have to ask, then you probably don't have any business attempting yourself
Imagine the reaction of the next homeowner who discovered that some amateur electrician globed a big load of JB Weld onto the back of a faceplate and pushed it onto the wall and receptacle box.use either Duct Tape or JB Weld
I hope your kidding....I would drill out the screw and then get one of those clip on nuts and a longer screw for the cover plate. Super glue and a regular nut would work too
Sorry! Internet is not always conductive to sarcasm.Imagine the reaction of the next homeowner who discovered that some amateur electrician globed a big load of JB Weld onto the back of a faceplate and pushed it onto the wall and receptacle box
Of course I reacted to your funny post. I should have added an emoticon to indicate my mood.Sorry! Internet is not always conductive to sarcasm.![]()
How about suggesting that the O.P. remove the receptacle. Mount it in his cross slide drill press vise and carefully drill out the broken plastic screw with a tiny left hand bit. If the screw doesn’t pop out doing that, just tap the hole for the next biggest thread size and put it all back together with a bigger machine screw. ???Sorry! Internet is not always conductive to sarcasm.![]()
That would be a serious mistake. Much better to put the JB Weld in the screw hole, let it dry, then drill an appropriate size hole in the cured JB weld.Imagine the reaction of the next homeowner who discovered that some amateur electrician globed a big load of JB Weld onto the back of a faceplate and pushed it onto the wall and receptacle box.
