How to remove broken faceplate screw from outlet?
wahoowad
The little screw that holds the faceplate to the electrical outlet looks broken off inside the outlet. I guess it was a plastic screw? I’d prefer to extract that screw so I can put a new faceplate on. Suggestions?
bonneyman
Desert SW
Just turn the main breaker off if you can't figure out what circuit it's on. There's absolutely no reason to do it while it's energized.
I've worked in many buildings with tons of computers running. Electrical panel not marked, and the owner wouldn't permit the main turned off. Plus they wouldn't pay me to come in on Sunday to do it when the office is largely empty. So for one desk outlet that needed replacing, this tool would have come in handy.
I'm not so sure that isn't actually a great idea if you were tying them in all day long
It's more of a homeowner/DIY tool for the occasional problem. Or folks with arthritis - holding a small weird shaped receptacle is difficult. But this thing might actually help.
Sheesh...
My brother has tried to get me to give him this tool, and he works on alot more 115v jobs than I do. So there seems to be a place for it.
Ultradog MN
Twin Cities
I will never need one but if you think it is a worthy device then buy it and enjoy it.
JohnX14
Boston 'burbs
I've regularly heard it referred to as 110/ 220 vs. 120/ 240V over my career/ life. I think my father still occasionally calls it 110/ 220. He's been an electricain since the early '60's. (as well as a certified IAEI wiring inspector from the early '90's) We all know the power companies, codes, and license exams are based on 120/ 240. I never paid attention, but I'm sure I've said 1000X "do you have 220 there" when working on something with my crews.
mm08822
What every happened to the days where 117Vac was used........ :headscrat Can't everybody give a little?
Shiftless
East Bay SFO
In the spirit of GJ, the OP should buy a Faceplate Broken Screw Removal Kit. Preferably, by Snap-On. With orange handles.
FIFY. Only $2779 on eBay, they're the really super rare collectable ones... Orange is so yesterday.
You beat me to it. Linked to other soon to be classic postings. Go with teal handles. 😎
LOW1
ontario
I feel like there certain things that if you have to ask, then you probably don't have any business attempting yourself
Perhaps true. But sometimes you just have to take the time to fix things that never should have broken. You have to show your stuff who the boss is. Otherwise the revolution will spread.
I would drill out the screw and then get one of those clip on nuts and a longer screw for the cover plate. Super glue and a regular nut would work too
Don’t let the bastards win.
PCustoms
VT
I hope your kidding....
I'm not even sure this is possible, let alone practical when an outlet is $5
MichaelP
IL/WI border
Imagine the reaction of the next homeowner who discovered that some amateur electrician globed a big load of JB Weld onto the back of a faceplate and pushed it onto the wall and receptacle box
Sorry! Internet is not always conductive to sarcasm. ;)
It was my reaction to the crazy glue suggestion (which, I'm sure, was a joke too).
Shiftless
East Bay SFO
How about suggesting that the O.P. remove the receptacle. Mount it in his cross slide drill press vise and carefully drill out the broken plastic screw with a tiny left hand bit. If the screw doesn’t pop out doing that, just tap the hole for the next biggest thread size and put it all back together with a bigger machine screw. ???
lolaetype
North Western Arkansas
Change the receptacle, no question about that; and shut off the breaker first - no question about that either.
If you want to remove the broken plastic screw from the old receptacle heat up the end of a really small slotted screwdriver and push it into the end of the broken off screw. Wait a minute for it to cool and use the screwdriver to turn the screw out, that's counterclockwise or anticlockwise for you Brits. :)
niget2002
Josephine, TX
If it really is a plastic screw, I'd just melt it out with my soldering iron. Then I'd screw a new metal one in.
When we moved into our last house the previous owner had replaced a bunch of outlet covers with white ones, but for some reason still had the ivory screws in them. I bought a package of replacement screws off Amazon. 15 years later and I still haven't used all the screws in that set.
LOW1
ontario
Imagine the reaction of the next homeowner who discovered that some amateur electrician globed a big load of JB Weld onto the back of a faceplate and pushed it onto the wall and receptacle box.
That would be a serious mistake. Much better to put the JB Weld in the screw hole, let it dry, then drill an appropriate size hole in the cured JB weld.
A penney saved is a penny earned.
