Post your "Re-purpose" suggestions here!
jabberwoki
puyallup wa usa
Oldcarguy i love the sliding ladder i was thinking of doing the same thing VERY COOL! nice work.
Can i get some closeup pictures of this set up?
Concrete B
...and long sleeves. I guess I'm another sissy Mary who doesn't like molten metal or UV burns on her skin. :)
The only way I Get a tan on my chest on my chest is welding sans shirt. TIG only though, Im not psycho.
evintho
Santa Rosa, CA.
I've posted this before but here's my funnel drip recovery system. Scrap PVC pipe, scrap lumber, a chunk of stainless steel trench drain found in a dumpster and the bottom half of a gallon ATF jug. No muss, no fuss!:bounce:
scott37300
Wisconsin
I like that idea! It takes up a lot of wall space I don't have but if I had more wall space I would make one. Might have to thin about this a little more and see if I can come up with a space saving version! Thanks for posting the picture.
rickycobra
There are ways to compact it for instance user small pipes and making it more vertical as opposed to horizontal. The only thing I've re purposed and that I like the results of was my flat dolly I made out of scrap wood and old wheels from my child's wagon.
dirttracker18
Slate River, ON
How about one long verticle pipe with a number of 45 degree turn outs on it for funnels?
That would save you the space on the wall. As you can see I have been thinking about that one too :thumbup:
l
l/
l
l/
l
l/
l
l/
l
Ll Like that
evintho
Santa Rosa, CA.
I'm sure there's all kinds of variations you could build. This setup only sticks out a couple of inches from the wall. My compressor extends much further. I just put the shop vac in front and it pretty much hides it and makes the space usable. Note the wire tie dispensary above, hanging off the side of the cabinet.
R6 Racer
Northern Ontario Canada
Baby food jars, Peanut butter jars & juice cans!
Gives me a ton of hardware storage in a small space.
Steve
smedly
Savage, Mn
Two small ones. Key rack from a steel rake and mobile storage from a file cabinet. Keep most of power/air tools in this. Needed a handle to move it around- found one in a building being torn down. Recognize where that came from?
Joe From NY
NY
Steve
Baby food jar storage. Every time some old elderly guy dies in my neighborhood, when they clean out his basement, at the curb on garbage night you always find this exact thing, often filled with slotted screws and square nuts, all obsolute stuff.
Bear
Salem, Oregon
Picked this up at a store going out of business for $10-12 -have no idea what original use was but works great to dispense my wire,
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
That is me in a few years. Only I do not use glass jars. I like old plastic peanut butter jars. To clean out the jars squirt in some dish soap and fill 2/3 full of Hot water. Screw cap on, shake, watch the lid blow off... :spit:
Hot water heats air, raises pressure, =Boom :shocking:
It does get the jars clean, you just have to leave the lid on loose to vent the pressure. :thumbup:
The rack may have been used to dispense wire, tubing, chain, rope, etc.
daveroy
Omaha NE
Looks like a handicap stall hand rail to me...
R6 Racer
Not a square nut, slotted bolt or screw in the lot!
BUT! :wtf: thanks for the "old /elderly guy reference!
JK
Steve
LWW
SF Bay
The next thing I would have to overcome in reverse is the motor now running upside down (assuming the bit is drilling downward). Some trimmers have weighted fuel pickups like chainsaws allowing them to run in ANY position, but I don't think this one does, so I could just rotate the gearbox 90 degrees and that way it would be sticking out to the left or right depending on forward or reverse drilling.
Add another project to the list!
Actually, I think I have that exact Ryobi trimmer and tiller attachment. Just drill additional holes in the tiller attachment to accommodate the release plug. You should be able to rotate the tiller attachment and keep the motor upright.
AZAV8
Mesa, AZ
Steve
I don't use baby food jars anymore as they are usually glass. Drop the glass on the concrete floor it breaks. I only use the plastic peanut butter jars nowadays, as they don't break when they slip from my old fumbly fingers.
Phil
frozen_bohemian
Plastic Bucket List
Plastic Buckets
Bolt Bucket is made from plastic buckets nested together and fitted with dividers. I have one for nuts and bolts, one for screws, and one for electrical parts.
frozen_bohemian
Nut and Bolt Storage
Painted coffee cans and baby formula cans on a dedicated shelf system to store the tons of nuts and bolts I have acquired over the years.
I used to "dumpster dive" when the field guys would finish up a big job and dump all the extra bolts and such to clean out their gang boxes. I was not unusual to bring home a couple of buckets of new nuts and bolts at a time.
All my neighbors come here before going off to the hardware store!
you can also see the roll of brown paper on a spindle, this has proved to be a great idea for keeping that roll of paper handy.
bchee
Texas
I'm using the metal frame from one of those big plastic tanks to store my scrap stuff.
The scrap stuff will later be repurposed for other stuff. (for example I'm going to use the wood to build my workbench)
There is also metal bars in there, which were window security bars that were taken down.
lilredex
Toronto
Baby food jar storage. Every time some old elderly guy dies in my neighborhood, when they clean out his basement, at the curb on garbage night you always find this exact thing, often filled with SLOTTED SCREWS AND SQUARE NUTS, all obsolete stuff.
Save those for jobs where you know you will never need to remove them. Just this weekend, I used a few making a heat shield for over a catalytic converter. They can be used up, if you remember you have them.
Joe From NY
NY
Yeah, i guess i could use them as sacrificial stuff, when it is going to be put together once and for all. Good idea.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
The square nuts are sometimes helpful as a semi-captive nut when they are installed so they cannot turn when the bolt/screw is tightened.
I also have a few square sockets (8-point).
Eljefe640
Austin, TX
l
l/
l
l/
l
l/
l
l/
l
Ll Like that
I really like that idea. I'm going to give that a shot. I'll report back on how it works...
NOTABLAZER
No pics at the moment but I got an older wire car battery display rack from the store I work at when they were remodeling the place. I cut some pieces of cardboard to go across the shelves and now I have a nice rack to store quarts of oil and other chemicals that I stock in the garage.
Joe From NY
NY
Just picture these bed frames cut up, bolted, and welded into 50 different things around the house, shop, and yard.
ctfortner
TN
Oh, havent finished this one yet, will update it when I do. Got a free iced tea stainless jug, its going to easily become my new charcoal starter with a few plasma holes in it :bounce: Here you can see its potential, its made just like them, only larger and stainless
bchee
Texas
I'm thinking about having a baby so I can buy baby food jars and Similac bottles.
mcdtommy23
Detroit Michigan
I know where that came from LOL. Watch the seam at the bottom. We had quite a few with bad welds - started leaking suddenly.:thumbup:
