Between 705 & 1200 SQ/FT Double Bee Garage (28x40 stick framed, 12ft ceiling with 10/12 pitch floored attic)
R
robb1887
That is the most time that I have ever spent on a thread with 38 posts! Very detailed and well done. I got into this because I am not too far from you if I am guessing right. My beginnings started out like you. Years of drawings and plans that covid wiped out with lumber prices that quadrupled. I am now ready and hope mine does not take as long as yours. Look forward to the final few pics and stories to come.
I am prepping for a 26x40 attached garage. You provided some things that I look forward to, others that I don't, and yet more that I had not considered. Overall, your Double Bee garage is close to what I will be doing. I have the same siding but in white to match my house. Loft space but over only 1/2. Lift, 12/12 roof, 9' walls. I could learn a lot from you on your epic electric journey. I would not be prepared for an $8k quote.
Thank you. I got a lot of insight from this community in my planning and definitely wanted to put some of it back in. Kent Island is about 4 hours north of me.
Not sure if you are 26 wide and 40 deep or 26 deep and 40 wide, but if its the later I would highly suggest trying to squeeze in that 2 ft. It sounds like you're doing car mechanical work as well and a car on a lift and a workbench in front makes for very little working room front to back for say engine hoists, rolling tools and material around, or what not to manuver in. I stood in my Uncles 24' deep garage and immedately agreed that 24' is just not enough as he had warned for my planned work. Material/labor wise its negligable as you're ripping sheets down at 26' vs just slapping them on at 28'
Overboost44
MD
I guessed wrong about your location. Regardless, I read your post to my wife because I said "listen to this, this is our situation. I appreciate your response also. We can learn a lot from others...
40w x 26d is correct. Where I actual have a problem is OA height. At 28'w I will be a foot higher than I am allowed. Have to keep the 12/12 pitch to match the house. I may be able to get a variance but what I am planning to combat the lack of depth is to have 7' of workshop space along the side where the lift is. I do realize that the 2' would be negligible cost, but I started out at 28'wx24d' and realized quickly that would be a mistake. I am trying to avoid having steel i-beams put in and I believe 28' would put me over the span where I could do it with wood.
I am a car guy and that will be the primary use, wrenching on cars. Love your clown shoe. Looks really well done.
R
robb1887
Yea, at 28' you'd need to upgrade to either Steel beams or IJT's I looked at both WAY back. I am definitely glad I have no HOA issues and my county is unconderned on height requirements. My desires to match the house as close to what I did was my own desire. I had friends early on trying to get me to build a steel building.
I ended up going with a pair of steel beams, for future gantry crane dreams with a 25'ish cross hung beam and rolling trolleys to get nearly every corner of the shop space for heavy lifting.
Swanny1953
Lucas, TX
I had a similar issue with the roofline being too high on the last addition. The architect solves that by having 2 roof lines - 3/12 for the first section on either side and 8/12 in the middle to match the existing roof slope. I think it turned out great. Pics are in my build thread in my sig below. .
R
robb1887
3/11- the upstairs HVAC ceiling cassette was able to be final hooked up with the ceiling finished painting which was amazing news. I lucked out as we did not plan that the louvers pointed AWAY from the staircase to keep the space conditioned better.
3/13- Not a lot picture worthy tonight other than the first set of lights are hung and the 3 110V ceiling outlets. And moving the temp string downstairs for more light.
The 8ft fixture is slightly out of position as I wait for some extension wiring to arrive to lengthen the lead a foot or two. I'm 3D printing the first wire clip to snap all the wiring to the fixtures for final install.
3/14- A lot of priming today thanks to some help from a friend. Upstairs and bay 1 completely ready for top coat. First 5 gallon of primer was tapped. Bay 2 and 3 were started with the remains of the primer already poured before calling it a day.
3/15- I finally broke down and bought an 18" roller setup, no I didnt want to spray. I had previously been working on a 10" roller as I already had it but a project this size... I needed to do something. Bay 1 got its first of two top coats, cut in Bay 3 primer and got most exposed garage door framing primed.
3/21- Almost done with priming. Bay 2 ceiling and maybe 10% of the walls remain. Thanks for the help from a neighbor. Bay 1 ceiling ready for lights tomorrow so I can move all the obstructions into the center of Bay 1 to make life easier. Bay 3 nearly fully primed. Ceiling paint was dead, needed another 5 gallons. The primer was almost dead and would need another gallon. Then lots and LOTS of wall paint (about 12.5 gallons).
3/22- I ran out of primer for the fresh drywall wans was ~100sqft short. Bummer. Bay 2 & 3 ceiling were primed and cut in for top coat. Bay 1 lights were installed. I need to modify the box covers to accept a wire pass through and will do that after move in for all my tools to be readily available.
3/23- Bay 2 & 3 got their first top coat and the upstairs corners were all cut in for top coat
3/24- I finished with ceiling paint finally. The 2nd coats were only a 10% (but much needed) added value to clean up the last bits of variances you could see through the primer and first coat. I also started on the first top coat of walls upstairs, and particularly the stair's wall/knee wall to get that finished to put the railings back up.
Which one has the 2nd top coat?!
3/25- downstairs "entry circuit" and bay 1 lights went up to the ceiling again
3/29- downstairs lights are all on the ceiling. I have some extra clips to install 20/20 hindsight and the modified box covers to still figure out and install.
April was Crazy... so I didnt get any shop work done.
5/10- I started cutting in corners and hung the second row of lights upstairs and put in the ceiling outlets
5/17- I finished cutting in all the corners for rolling the walls
5/18- The downstairs first full coat was done
I think that night I just sat in the space and looked at white walls grinning as I could actually "feel" like I was getting close to being done. The bare drywall to first top coat transformation was a big morale boost.
5/19- I applied the 2nd full vertical wall coat upstairs and downstairs so I could start putting in outlet circuits, and a bit upstairs on the rafter "walls" as it was the last bit left of that 5gallon bucket, the paint extention handle on the floor marked where the paint ran out to pick up the next time. A 2nd coat of white paint really doesnt do justice in pictures but it was apparent in person.
It also was the beginning of the outlet/switch/blank saga of electrical. I ended up with 47 120V duplex plugs and 2 welder/plasma plugs for initial install. I have 2 outstanding plugs for the lifts that the plug style is TBD and are waiting that.
5/24- marked another miles stone for DBG HQ, all the interior wall/ceiling paint was DONE. All the surfaces had 2 coats of top and a coat of primer.
5/27- This date marked the "initial" final electrical install which really is just all the plug outlets, missing a few cover plates, and left the known current 220V hardwire boxes open as well as the in wall EMT for A/V cables.
It also meant that the "late added" attic kick wall lights were powered now as they were in hindsight tied into the 20A outlet circuits
5/31- I am my own worst enemy at this point for getting stuff done before move in, delaying my move in. I decided last minute to add CMU block coating to the inside as well for consistency and ease of future cleaning & "curb appeal". This directly affected ability to paint and apply trim, as I'm only one guy. But it came out great in hindsight and I'm glad I did it
Before and after with trim "thrown on"
R
robb1887
Updates back to 3/11 are updated in the post prior... the build thread is current. We'll see if I get anything done this weekend as my house upper HVAC went out so we're in emergency work protocols there.
runit
Raleigh NC
What a space! Truly a labor of love and it shows.
And a 3rd gen 4Runner with a M coupe!
I'm following this for sure!
R
robb1887
Home HVAC is back to normal operation, with minimal exposure to hot days which was good.
Got back to some shop progress, and did and initial pressure wash of the floor to apply the densifier and sealant (Ghostshield 4500/8510) in the next weeks.
20/20 hindsight this should have been done BEFORE drywall and paint to not be as much of a headache... even insulation maybe to reduce the dust thereof but I skipped over that option too.
I would do this in future builds as to having the floor dried in and cured for the 28 days or whatnot
I unforunately have to do a split application as I have too much stuff already accumulated in the space over the last two years, so bays 2 & 3 are getting done first, then moving all my junk to get bay 1 applied.
JohnX14
Boston 'burbs
I'm not a frequent poster here, but I do want to say congrats after reading this thrugh. I can't imagine the patience it's taken for nearly 3 years. Thay may sound cynical, but it's not. I'm in construction, and have built a few personal houses and detached garages, and they go quick, mostly because of my resources and limited time. The fact that you did what you did yourself, with limited help, is fantastic. (Along with kids, wife, job, etc) I enjoyed reading this thread. Keep going strong.
R
robb1887
Doing a little more google research I made a personal determination that my floor was power troweled.
I applied the 4500 (single coat) just before our week vacation which was perfect for a cure time. The 8510 (wet on wet, 2 coats) was applied as soon as we got back to allow it to cure over the week before moving all the equipment over from bay 1 to repeat the process again.
The 4500 (1:1 dilution) was sprayed on and subsequently rolled with the 3/8 microfiber roller to even everything out. (~1.5gal of solution)
The 8510 was sprayed on, then wet coated shortly after, then rolled over in both directions. The finish had a slight sheen a few hours later but I'm hoping its going to dull back out. (nearly 2 full gallons)
I'm not sure if because I am power troweled AND conditioned that the absorption rate is so slow, but the "minute or two" on the label was not seen for my application of either product. It did seem to soak/evaporate better at the edges that are likely significantly warmer due to heat soak than the middle of the slab. I also did zero of the testing suggested as I am up against a deadline for move in. Ambient temps were 74°F-ish during application and a dehum running at 55%.
The sweep prior to the 8510 already showed significantly less dusting which was my biggest dissatisfaction so far with my pad.
Friday night/Saturday will move all the equipment for washing/degreasing bay 1 with a target to apply the 4500 on Sunday the 12th, and 8510 the night of the 18th.
R
robb1887
I missed responding here, but thanks! It's definitely gotten to the point I am tired of working ON the shop and not just working IN the shop. I'm getting really close.
Small update was I finally pulled the trigger on the first of two Chamberlain RJO101 jackshaft openers. I wanted to ensure I didnt need to modify anything else before trimming out around that area. This turned out to be a good plan since I had not accounted for the deadbolt lock wiring when I prewired the lower door sensors and wall switch. I was able to shimmy it into the gaps of the drywall to the door framing and should cover with the trim no issue at least.
It was amazing how much faster these style are to install vs the conventional hanging belt driven track units. I had the first installed in an evening after work, the pre-wiring of course helped a to as well.
I still need to solder the sensor wiring permanent and route that with some wire keepers better, but its operational for the moment which is the important part as when I treat the last bay I would have "painted myself into a corner" if i couldnt access the space through the single man door.
R
robb1887
The 25th is my "soft open" when I'm having a bunch of co-workers over for a cookout which is QUICKYLY approaching.
The last 1/3rd of floor was prepped and 4500 primed over the weekend after moving everything out of the way.
All clean:
4500 down, I know it looks crazy different.
I also painted to trim I had on hand to get put up
Monday was a day off which resulted in a good bit of first floor trim going on, which really helps finish the space. Its not my best effort but more a function vs time cost to get it installed. I put a bit of boric acid dust behind the trim since I didnt get it in the stud bays to help with some passive pest control.
My DIY ignorance put this pass through box too low, so we got fancy here a bit:
And the detail around the south wall 2x6 bottom plate added some work:
Timeline from here to the 25th:
Misc trim work between now and the weekend, basic filler (white) will go in the finish nail holes, but no additional paint.
Caulk the top trim joint to the wall soon
Saturday night will be the 8510 application on Bay 1.
Sikaflex 1C application in the expansion joints Monday
Likely burn a day off work next week to move a majority of the stuff on the 3 trimmed out wall that will be finished at that point.
Any idea's on best pactice for the trim to CMU stem wall? More caulk?
I hope to have enough of the garage stuff moved into the shop by the end of the month to park the daily drivers inside, which will be a crazy milestone
R
robb1887
Door trim and south wall trim (sans above big bay doors) done. I advise against being lazy and not going to my bench sander in the attached garage to take a smidge of the left side of it for the clearance of the door trim and attempting to do it on your table saw in the space.
The west jackshaft opener was also snagged on an Amazon with a coupon and installed. Everything I could find online for residental use made it seem that the cost of the liftmasters for the "benefits" didnt meet my neads so I stuck with the cheaper units that for all intents and purposes from what I could find are nearly identical. I thought I messed something up during limit setting but turns out it's important to not mix up your pre-wire door sensor and door button wiring. I had to sort through that with the wire they supplied for the door button to check continuity. Its amazing when it's wired correctly it works correctly.
It's amazing at how much a bit of caulking can change the "finished" feel of the trim.
I did end up caulking the lower edge to the CMU with the same Alex Fast Dry. I used a painter tape boundary on the top of the CMU to get a decent radius with a "craft stick" and not get the wipe away into all the pores of the CMU which came off nice with the tape removed wet.
Preps for the application of Sikaflex 1C SL are underway. I have 2ea 28 ish feet of 1/8" saw relief cuts. The big box store 3/8" backer rod was a nightmare to get into place. I ended up sourcing some Amazon 1/4" stuff which is going a bit easier, but still time consuming.
I ended up getting a 29oz single tube vice 3 10oz tubes (for about the same price for less material, as 2 10oz are stated to do exactly my needs I did not want a shortage) and a ZIPsystem 29oz gun to apply it. And now I own a 29oz caulk gun. I have yet to apply them but seems like it should work out fine.
I was able to land the mill and lathe after the caulking of the "baseboard".
I'm not sure the bandsaw is staying there, I just wanted it out of the way for the time being and freeing up my dolly.
My 25th deadline and the lack of Sika down already has pushed that to the 27th likely has I had other responsibilities take too much time on the 20th.
R
robb1887
Well the "soft open" went well, here's how it looked the night before hand
I ended up getting the Sikaflex 1C SL down the days to follow
The false sense of security one of the 29oz tubes would be sufficient was just by the sheer size of the thing
and ended up scraping the first of two flush last night after letting it fully cure
The Monday post party was spent moving stuff back out of the packed attached garage into the shop. Safe for some trim above the garage doors, the windows, floor joist accesses, and the stair case and the control joints, down stairs is pretty much done and I'm wanting to get the dailys inside
R
robb1887
The clown shoe looks nicely done.
Thanks. It's getting there. I'm definitely ready to stop working on the shop and working IN the shop, specificially on it and the Roady I have as a Coupe test mule. Almost there.
The Coupe has been around for 13ish years, its about to get a 6 speed swap and a new rear end ratio and extra clutch in the LSD along with a twinsdisc clutch and new flywheel to better handled the Eurosport Twinscrew supercharger. A boost motor in the future along with some other projects.
R
robb1887
This past weekend had one very specific goal. Get the daily's into the attached garage. Here in VA the summers can get pretty brutal 100+ heat index days, crazy amounts of sun with high humidity and with loading and unloading two small kids regularly, I was over driveway parking.
Long story short, the weekend was a success.
I had tried to stuff them in with the workbench and other stuff about a year ago, but essentially one set of doors on one car was never going to be viable, so we had to wait until now. The largest hurtle to the move it was my 11ft long HF box workbench I built off someone's similar build on this site many years ago. It was welded together with a 1.5" topper of OSB and steel. Luckily my neighbor has a 12ft long trailer.
First order of business was to make the overall weight manageable. Cue all of the drawers getting unloaded.
I luckily had a scrap piece of OSB (who doenst) that made a usable ramp over the drop gates for the HF furniture dollies. They got a 4x6 block on top and a ratchet strap to keep them all together to get over the hump on the ramp. I mentioned those 100+ degree heat index, of course it was feeling like 104 I believe this afternoon. With the help of a few ratchet straps, the floor jack and some solo muscle, the bench loaded pretty easily.
Since I had all the extra trailer footprint I decided to load the welder/plasma cart, tool cart, and the 20T press as well to move to the shop.
Gravity definitely helps unloading, again with the floor jack to get the dolly castors over the OSB lip.
The previously "gigantic" bench in the small garage, now almost looks too small.
We had made good progress on Saturday
Sunday side quests and schedule pressure pretty much nixed any more photo progress, but the tan cabinet in the above, some bulk materials, my cardboard box and wood scrapes collection also migrated over the Sunday/Monday. I will say that the side entrance garage with an 8ft wide door with little swing room is not ideal... also the shear size of vehicles today vs what there were 25 years ago likely doesn't help but boy do I wish they were 9ft wide now with a little more width in the garage in general. The center support pole also makes it impossible to back either car in as the rear door would interfere which is disappointing as the garage doors must be open to access either hatch.
Next on the list is flooring upstairs to get the air compressor moved as well and start installing more organized parts storage. I'm shopping Rigid vinyl plank due to service expectation/requirements, ease of installation, durability, easy to clean/maintain, and cost. I was originally looking at lighter options but most of the friends I asked said their lighter flooring looked dirty ALL the time, which made me second guess the lighter floor for better light reflection in a shop environment.
The 4 I'm looking at now are these (from lightest to darkest):
1.
2.
3.
4.
The plan for this space is to have storage along the knee walls in the slide out tote style possibly, and a 4x8 packaging/3D scanning table close to the camera and another 2-ish of the storage racks seen far. Next to the 4x8 table on the north wall will also likely have an electrical soldering/wiring work space to keep it out of the "messy" shop downstairs.
I apparently can't add a poll to existing posts, but opinions on flooring are welcomed. I am currently leaning toward 3 visually and for the simplicity that enough is available at a convient box store to pick it up at one stop. 4 is the 2nd runner up for "darker hides dirt" but would required an additional store pick up which is a bit out of the way, but managable.
