bugnut
Central Ohio
Started and shuffled the power equipment around. The endoscope arrived, opened the garage door, fired up the old ford tractor went looking for a gas leak. When running does not leak, when shut off the residual pressure creates a leak. It is confirmed olives are working. So its down to something with the floats or the gaskets. It'll be coming off, again for another review.
Then worked on the baja and where to install the ballast in the front, while protecting the wiring and workings. Thinking pea gravel in bags, like on a canopy. More head scratching....
aka Larry
Eastern, NC
Last year I bought a cheap little 12V dual-piston compressor to air back up after off-roading in the Jeep. I used it a couple of times, and it worked well, but I had a thought that it sure would be nice if it was cordless.
I had an idea that I could buy a 20V Dewalt battery to 12V adapter and somehow make it work packaging-wise. I bought the adapter about 6 months ago and finally had a chance to mess with it yesterday.
I ended up attaching the battery adapter on one side by securing it to the compressor body with a hose clamp. I routed the wires around the end to the other side and attached the 12V converter to opposite side with zip ties. I added a plug to have it either be powered off the Dewalt 20V battery or switch it to a different plug to off the Jeep's battery if needed. I think it turned out pretty well and didn't cost much.
Cheesy1
In front if my garage, but close enough. Yesterday my old Ford with 220k miles got an alternator.
Today it got the steering gearset tightened up. Goes a lot straighter down the road.
Dressed 6.0, but it’s been a dang reliable truck in the 15 years and 180k miles I’ve had it.
Beerhippie
Far NE Oregon
****. Lumber yard sold me one stick that's a foot short. I didn't notice 'til I'd made the first two cuts. So I get to drive up to Joseph with fuel at $5/gal.
Anyway, that's thirty of thirty-two cut. Cut one more, then cut sixty-four 3" X 1 1/2" X 3/4" pads to go on the ends. My goal is to have all of them ready to install tomorrow.
Fordguy1964
Houston County, Alabama
Nice! I have a 63 hardtop waiting to be restored.
Cool. The best thing I ever did was to join the Fairlane Club of America. The information alone is worth the price of membership. Also having access to tons of people who have parts hordes comes in handy when restoring cars that have few sources of restoration parts.
Beerhippie
Far NE Oregon
This is going to take a while:
Mind-numbingly interesting....
I was able to use a block on our crappy miter saw table to set the cut for the (now) sixty blocks I need. I cut two of the surveyor's stakes (we had a bundle for reasons I don't ken) at a time, so only thirty cuts:
I also realized that I didn't need the last set--no trip to Joseph--because the pad for this table is too small for them to work:
Four pair, ready to be installed:
Ran to the hardware store and counted out 112 carriage bolts, nuts and washers. Fun.
Ultradog MN
Twin Cities
I reorganized the back end of my shop yesterday and today.
I built the materials rack a year ago and for some reason thought it would be nice between the lathe and mill.
Wrong!
So I slid the lathe over about 5" - to the right in the photo - and swapped the mill and materials rack.
That gave me enough room to put the milling cabinet below the window.
I made the feet for under the mill last week so now I can slip the pallet jack under it real easy to move it again if needed.
Two bonus points:
I now I have a place to store the pallet jack when I'm not using the mill and a out of the way place to put the trash can.
Always trying to use the real estate in here more efficiently.
ctandc72
VA
Pressure washed the Silverado frame with the big pressure washer. Found another piece I need to order / cut / weld in. Got things ready to do a diff / trans fluid change on my wife's daily driver Camaro SS, and then spent a few minutes cutting / buffing the 22 year old paint on my daily driver
Plenty of chips, scratches etc (it's a year round driver) but not bad.
rsparks64
Hill Country Texas
I think you need a license to do endoscopies with that endoscope. :bounce:
kaymccampbell
Upstate New York
Cleaned, flung, put away. Burned, painted, assembled, glittered another herd of decorations. I think I've got stock to finish out the year. That should pay for the new lid, alignment cam, and other upgrades, with money for more materials. Hung up my little cowbell that Judy gave me.
The improved lid, magnetic material clips, and the visual and web alert for job completion have definitely improved the Burner experience. I'm able to get more done in a day.
rollinlower
Rogersville TN
its sunday so the wife is up doing laundry telling me to take it easy today so im sitting at the desk going through the engine bay wiring harness tracing and fixing wires and pulling the ones out that i wont be using because with manual windows you dont need ac or computer wiring lol.IMG_8144.jpeg
