What are you doing with you "Hot Deals" Durham Instrument Cart?
tool_scrounge
Southern California
For those who were able to buy one or more of the $79 Durham LIC-243644-2-95 Low Profile Instrument Cart, what are you doing with it?
For reference:
This is my project for the cart:
I do not like messy tools like bench grinders, cut-off saws, buffers or belt grinders that are hard to clean up after in my cramped shop. So the plan is to mount them to the cart and wheel it outside to do the messy projects as needed. This is possible in Southern California as the weather is usually pretty nice. It also saves space as I will mount the less used tools to the bottom shelf.
One issue though - the concrete outside my shop is slopped down. Enough that I need to make sure it is locked in place when taken out and get some help moving the heavily loaded cart up into the shop.
First is to add a Vestil pedal floor lock to the cart. The mounting holes are already in the cart for it. I had a 4" spare one so I need a spacer block to mount it to the cart.
To add another bit of safety, I ordered a pair of Grilla Grills All-Terrain Wheel Chocks ($11.89). Nice smaller size compared to ones for cars. Smells a bit of the early Harbor Freight showrooms though.
https://www.grillagrills.com/product/4000057
There is the issue of moving the fully laden cart back up into the shop. My solution was to find a tiny 120VAC winch with remote. I needed one small enough to mount under the bottom shelf of the card to not use shelf space for tools. An ATV winch from Harbor Freight would have worked, but they are 12V so a battery would have been needed. Also, they usually do not have a remote control pendent. Fortunately I found a tiny used Dayton 1000lb winch off of Ebay that works nicely.
One down side of the winch is low duty cycle. At full load, it is rated for 20 seconds of use every 20 minutes - a 1.6% duty cycle. Realistically my load is less and so from the calculations the duty cycle is more like 50 seconds every 20 minutes. Which should be enough. But this being the Garage Journal, lets add a 120V cooling fan. I had most of the parts in the junk pile. For the sake of overkill, I spent $2 on Ebay to buy finger guards including UPS shipping. How someone makes money on a transaction like this when your business is in California I have no idea.
The next part is power distribution. A power strip would work, but I had a APC 1U rack mount power distribution module in the junk pile. I really like that it comes with a ~20' heavy duty integral power cord and cable management brackets on the back. I will mount this in the end of the cart just under the top shelf. I need to get some child proof plugs for the unused outlet or make a shield to keep dust out of the plug area.
Brandon_oma#692
North West corner of Illinois
Moving material around the shop. Roll over extension cords, air hoses, and anti fatigue mats well even loaded.
Cut blanks on the right. Inspection tools on the left. Also a pair of Kurt vises I pulled off the mill to run some big parts.
Cycle time for first op is 3.5 minutes. Load a new one in and hit go. Check some dimensions and walk over to put it in the other lathe and hit go while the next is running.
Complete parts after second op on the big lathe.
Push the cart to the door outside to load. Old carts rolled like **** and were bigger. Made good movable tables but carried all the parts bins to the door then outside to load.
Bought 5. Wish I would have bought 10.
1Bad55Chevy
What is this green organizer thing?
Brandon_oma#692
Silicone trays from Menard's. Cheaper than harbor freight. Both are the "same" I have both.
They were in the deals thread cheaper online before but still a deal at current price. FYI 4 per carton with 2 cartons per overpack carton. I got 6 so they took 2 out and sent the cartons to the store.
https://www.menards.com/main/tools/...t-3-piece/81588/p-1642874352553294-c-9189.htm
Harbor freight is all separate items.
PS the boxes make good sacrificial covers for the carts lol. shown on the cart on the right.
drokihazan
Wishing I got one, mostly. I kept checking to see if it would restock a third time. Have still checked every day, haha. I really wanted one, bummer to miss out.
SlotlessMan
NW WI
Nice mod list!
Mine is being used as a portable workbench. Love it!
Debating on getting wheels locks.
rust in the eye
Chicagoland
Brandon_oma#692
$79 for that cart???
"Currently unavailable"
Me thinks a few here were able to exploit an error, so Senor Bezos took it in the pants on this one. For that, Bravo!
It gets better. Volume price breaks. I paid $297 total for 5 carts. They came in and out of stock several times. First posted on Jan 22nd I didn't order till Jan 30th.
They could not have shipped them for $300. Mexico to Texas to Illinois.
I think somebody missed a decimal and it was supposed to be 750-800 delivered each. Amazon business price was 75 each I think.
finn
The UP, God's country
For reference:
Needs mag wheels, a loud muffler, and a radical paint job.
A Ricer cart!
Hooterville
Finally my cart arrived today! ...after 6 weeks. At 3 weeks it was delivered to the wrong address in Urbana IL, then I convinced CEVA to pick it up from the homeowner (they did) and CEVA created a new tracker and shipped it to me in CA. It has quite a few war wounds from shipping 2x. CEVA said it was a data entry error, and I commend them for taking accountability and retrieving it.
Net cost to me is $26! Amazon gave me $20 when I informed them it shipped to the wrong address and today they kicked in $37 gift card to covers my cost for paint and labor (and then some). You will be glad to hear I was very nice to Amazon and simply asked "whatever you can do to offset the cost for me to paint it would be greatly appreciated".
Immediate Mods: I decided the best method to prevent movement is the floor lock similar to @tool_scrounge . I may make an adapter for the floor lock so I can quickly install/remove with a pin for those days where I need more ground clearance (i.e. to get to my side yard there is a 4.5" drop from pavers to a cement pad).
Intended use: I have a very crowded garage and this cart will hold my stools for working on motorcycles (sometimes with my twin sons) and a few favorite chairs for having a beverage and talking about motorcycles. Note: at my age, a comfortable chair is a big deal! When I find one, I snag it, and put it on a well-made heavy duty instrument cart!
Aileron
outside
I got a cart also and have been watching for another (at that price). I originally also thought it was a pricing mistake or maybe blems but they went out of stock and came back at the same price. You would have thought when it was restocked someone would have caught a price mistake or they would have cancelled the orders. You couldnt buy the castors shipped alone that price.
