cvcman
I have a Chicago phnematic 1/2”drive but it doesn’t seem to have a lot of power
Don’t want to spent a ton of money
Whacha think
Whacha think
same here. I bought a nearly new still with stickers on it from a pawn shop for $50 ( had to go back on my posts to see what I paid )I have an Ingersoll Rand 231C and love it;
231C is probably the most durable choice, they are the energizer bunny of impacts. They definitely are not the most powerful however. They used them in tear down cell for the reman engines in the factory for years and years without issues, even though they were being thrown around.I have an Ingersoll Rand 231C and love it; I haven't found anything it can't do yet. As long as I'm in the shop I'll use it instead of the high torque Milwaukee. They run about $130-150 but I've seen them on Scamazon for around $100.00 before.
I've always referred to it as the small block Chevy of impacts; it's been around a long time, basically unchanged, for a reason. There are definitely more powerful options out there, but with the OP not wanting to spend much money, I don't know of a better option for the price even though I'm sure there are plenty that I have no experience with.231C is probably the most durable choice, they are the energizer bunny of impacts. They definitely are not the most powerful however. They used them in tear down cell for the reman engines in the factory for years and years without issues, even though they were being thrown around.
Give it a little more time....I'm actually happy to see the thread hasn't turned to the latest & greatest battery option(yet anyway)![]()
Agreed. I wonder if the OP's wrench needs cleaning, lube, or some other service.Chicago pneumatic makes some powerful impact wrenches.
Maybe go to 1/2” hose ?
It doesn’t seem to tighten lugs to anymore than 100fp
And sometime struggles to remove
I’ve had it for years
I’ll try to get the model off it
I bought the 2135 around 2006. It's been a great gun.2235TiMax is a beast
A 3/8 should be plenty if it isn't too long. Mine runs off of 50' of 3/8 hose just fine. I did upgrade to 1/4" high flow fittings a few months ago because of Garage Journal. That made a difference but not as much as I thought it would after reading about how great they are. It might be time for a rebuild of the impact, it might be easier to replace it.Maybe go to 1/2” hose ?
Full disclosure: I don't use air tools. Wouldn't have a clue as to which "brand" is better than another.That said... once you go cordless, well...
So I notice my CP impact says 90psi max
I’ve had it for years and always let it run on full air not regulated down .. so like 140 psi
Wonder if this is hurting it
make sure there's no obstruction in the air inlet, screen with gunk, etc. Use lots of air tool oil and low air, spin just a little and let it set for a day or 2. Maybe the air motor need a clean out. Check that the trigger is giving full air.I have a Chicago phnematic 1/2”drive but it doesn’t seem to have a lot of power
Whacha think
WHICH "Chicago phnematic"? How old? The improvement in air-impact wrenches since the 1970s is phenomenal. If you're dealing with a "Chicago Phegmatic" CP 734, you're in for a real treat.I have a Chicago phnematic 1/2”drive but it doesn’t seem to have a lot of power
Whacha think
Oh, please. The 231 is enormously outdated. They--along with the CP 734--were industry standards...a lifetime ago. Now they're antiques: Durable but weak. They don't make enough power to hurt themselves. About the equivalent to a top-notch modern 3/8" air impact wrench.I/R 231's have always been the best you can get
I have 135 psi in the tank, which equates to about 90 psi at the wrench, when the wrench IS RUNNING.So I notice my CP impact says 90psi max
Unless you need an air hammer.Full disclosure: I don't use air tools. Wouldn't have a clue as to which "brand" is better than another.
I just watch sales flows and trends.
AIR TOOLS are going the way of the wagon wheel - pawn shops almost can't give 'em away. (same with pipe wrenches.)
Battery-powered tools is where the market is going.
IF I was in the market for one, pawn shop would be the first place I'd look.
90 psi means dynamic pressure, i.e when the tool is running free speed. Your 140 psi with hose and fittings is likely getting you less than 90 when the tool is running free speed.So I notice my CP impact says 90psi max
