What’s a decent 1/2”air impact ?
cvcman
Syracuse NY
I have a Chicago phnematic 1/2”drive but it doesn’t seem to have a lot of power
Don’t want to spent a ton of money
Whacha think
sparky 1971
Central Iowa
I have an Ingersoll Rand 231C and love it; I haven't found anything it can't do yet. As long as I'm in the shop I'll use it instead of the high torque Milwaukee. They run about $130-150 but I've seen them on Scamazon for around $100.00 before.
mikedodge
I have both the cheap and better Campbell Hausfelds. I knew someone who used to use the better type on semi trucks. Don't know what the current ones are like.
Firebrick43
West central Indiana
231C is probably the most durable choice, they are the energizer bunny of impacts. They definitely are not the most powerful however. They used them in tear down cell for the reman engines in the factory for years and years without issues, even though they were being thrown around.
:thumbup:
2235TiMax is much more powerful (and lighter) than my 231C. Its as or more powerful than the ingersol 261 3/4" impact.
I have not used the astro thor.
sparky 1971
Central Iowa
I've always referred to it as the small block Chevy of impacts; it's been around a long time, basically unchanged, for a reason. There are definitely more powerful options out there, but with the OP not wanting to spend much money, I don't know of a better option for the price even though I'm sure there are plenty that I have no experience with.
C
cvcman
Syracuse NY
Maybe go to 1/2” hose ?
It doesn’t seem to tighten lugs to anymore than 100fp
And sometime struggles to remove
I’ve had it for years
I’ll try to get the model off it
Hakeem
Chicago
Try high flow fittings/couplers. If you want to go a step further, a 1/2” hose with an adapter + high flow fittings will unleash any air tool.
I have the compact HF gun that’s been relabeled by Capri, Hazet and others and I love it. It’s small and smooth, really a delight to use. Not the regular Earthquake that comes in like 6 colors, but this one that only comes in green:
As much as I love Astro in general, the Thor gun is not one of their best products. It’s heavy, ergonomics are not great, and the forward/reverse selector Is finicky. Also the power has been underwhelming for me. Yeah it’s more powerful than my HF but not as much as I would have expected.
Once my HF wears out I’d probably go with the the IR 2231 or the Aircat, whatever their top model is. Probably leaning towards the IR bc I’ve heard mixed reviews on the Aircats durability
sparky 1971
Central Iowa
A 3/8 should be plenty if it isn't too long. Mine runs off of 50' of 3/8 hose just fine. I did upgrade to 1/4" high flow fittings a few months ago because of Garage Journal. That made a difference but not as much as I thought it would after reading about how great they are. It might be time for a rebuild of the impact, it might be easier to replace it.
bwringer
Indianapolis
Agreed on the Harbor Freight earthquake ST.
Bang for the buck ($119) is off the charts, and it's on the shelf at any HF, no waiting, in a color you like.
Your old Chicago Pneumatic may or may not be worth saving. They made a lot of ****, and a lot of good stuff as well. But air tools have just plain gotten a lot better in the last several years.
That said... once you go cordless, well...
Full disclosure: I don't use air tools. Wouldn't have a clue as to which "brand" is better than another.
I just watch sales flows and trends.
AIR TOOLS are going the way of the wagon wheel - pawn shops almost can't give 'em away. (same with pipe wrenches.)
Battery-powered tools is where the market is going.
IF I was in the market for one, pawn shop would be the first place I'd look.
C
cvcman
Syracuse NY
So I notice my CP impact says 90psi max
I’ve had it for years and always let it run on full air not regulated down .. so like 140 psi
Wonder if this is hurting it
jsaw
Geneva, N.Y.
140 is probably Your static pressure. You need to connect a gage at the impact and measure the pressure while pulling the trigger and make sure the working pressure is 90 psi.
rooster59
Land of the Pines
Whacha think
make sure there's no obstruction in the air inlet, screen with gunk, etc. Use lots of air tool oil and low air, spin just a little and let it set for a day or 2. Maybe the air motor need a clean out. Check that the trigger is giving full air.
Wine-o1
IL
Another vote for the IR 231C. I used it professionally for 8 1/2 years then sold it to my neighbor when I left the field and it’s still going strong. The only thing I ever had to do to it was replace the small O-ring for the trigger. It was trouble free and did everything I needed it to.
Steve_P
231 is a good gun, but it's not 1980 anymore and there are lots of other options today with more power for a lower price.
The obvious answer is to watch a few of the TTC videos and decide based on your budget.
Schurkey
Whacha think
WHICH "Chicago phnematic"? How old? The improvement in air-impact wrenches since the 1970s is phenomenal. If you're dealing with a "Chicago Phegmatic" CP 734, you're in for a real treat.
I/R 231's have always been the best you can get
Oh, please. The 231 is enormously outdated. They--along with the CP 734--were industry standards...a lifetime ago. Now they're antiques: Durable but weak. They don't make enough power to hurt themselves. About the equivalent to a top-notch modern 3/8" air impact wrench.
I have 135 psi in the tank, which equates to about 90 psi at the wrench, when the wrench IS RUNNING.
True story: I was trying to remove an oxygen sensor on a 4.2L six-popper Trailblazer, going through the fender-well with my impact wrench, a short extension, and a deepwell, six-point impact socket. Had no luck--wouldn't come out. This impact was once a class act, the most-powerful 1/2" impact at my former employer--it made "company supplied" 1/2" impacts from CP and IR look sickly. It was "used" when I bought it from The Mac Man, it was no spring chicken by this time. But it had been losing power over the last few months. I called The Snap-On Man, met him at his next stop, and "replaced" my elderly Snap-On IM510B with a new MG725.
Got back home, and was pulling the whip-hose off the '510B to install it on the '725. I happened to look into the air inlet fitting on the '510B, and discovered that the screen in the handle was about 1/3 plugged with debris. I cleaned the screen, put the whip-hose back on the '510B, and the '725 went out-of-warranty sitting in the bottom drawer of my toolbox.
I eventually sold the '510B years later, on Craigslist. This was a silly move, because I'd come to appreciate having a "beater" impact wrench along with the very-powerful "new" MG725. I bought an IM6100 off of eBay for dirt-cheap, put a new vinyl cover and a new cushy handle skin on it. The thing looks and works like new. I only take the '725 out for the REALLY tough jobs.
So, that in effect is my recommendation: Verify the inlet screen on your CP, and if it's plugging, clean it out. Maybe some light solvent in the air motor to free-up potentially gummy vanes, followed by genuine air-tool oil. But if that doesn't get you the power you need, find an old Snap-On IM510 or newer, perhaps a IM6100 or 6500HD (very similar tools, the '6500 is just a lightly reworked '6100.) Any one of Snap-On's (not Blue-Point) 1/2" impact line-up newer than the IM5 (NOT recommended) should be low dollars for a fairly-stout air impact wrench. Give it some lovin'--I bet you'll be pleased.
jblnut
In the Middle of MN
I’ll give the GJ answer and say it may be time to step into the 1” world and upgrade plumbing to 3/4”. Or a setup like this with an 80gal tank feeding the 3/4” airline and impact. This $125 Vevor 1” impact puts out close to 2,000ft/lbs measured with a fat guy on a long pipe not being able to tighten a big nut any more than the gun did. Sure is nicer than listening to the 185cfm trailer compressor rattling away outside.
Do some YouTube’ing on the Torque Test Channel and you’ll find something you like in your price range.
Marlin
Unless you need an air hammer.
Marlin
90 psi means dynamic pressure, i.e when the tool is running free speed. Your 140 psi with hose and fittings is likely getting you less than 90 when the tool is running free speed.
driftpin
A found in the gutter I-R 231C, in Miami:
and a short distance away, a 3/4" deep impact socket.
Before this I had a Builder's Square (A K Mart line, I believe) 1/2" drive which did OK for the tire/wheel changes for which I used it. The 231C works for my needs these days, just maintaining my fleet of personal things. I have a Saylor-Beall 705 upright feeding it and my other pneumatics.
