Selecting the Correct Size Pilot Drill Bit
Wamsutta
Amarillo, Texas
School me on selecting the correct size pilot bit for a 3/16 hole in mild steel 10 Gauge.
I center punched the location of the hole and went straight to a 3/16 drill bit. Final hole drifted off center.
Apparently, a center punch dimple is not enough.
The drill bit was a brand new black Milwaukee 135 degree split point.
Beerhippie
Far NE Oregon
My usual go-to is a 1/8".
For sheet metal, a step bit works much better than a twist drill. Less tendency to wander off the punch and leaves a much cleaner and rounder hole. Also no tendency to "lift" the metal when it goes through.
MJD1
I prefer screw machine length ( stubby) bits for situations where a deep hole isnt necessary.
mikey03
I honestly don’t know when I’m supposed to drill a pilot hole and when I’m not.
material
size of hole
type of fastener
i think those three things are what decides but idk which are supposed to and which not
alfadan
Augusta, ks
For that small of a bit in sheet metal, a pilot is unnecessary. I only use a pilot in stock at least 1/2 inch thick and bits 1/2 and up.
For sheet metal, a step bit is the best option, and safer.
alfadan
Augusta, ks
Also, choosing a too big pilot size is usually worse than no pilot at all. It lets the drill wobble around, making odd shaped oversize holes and even damge the cutting edge.
PCustoms
VT
Yeah, they don't walk like drill bits do sometimes. So quick a pop a self tapper through, pull it back out, then run the drill bit through. Works pretty good in my experience.
I guess. Personally of find them to be one of the more frustrating fasteners.
Not going to work well on thicker steel, So I always grab a punch...
Willie Makeit
I've always used the rule of thumb of: 1/2 the size of the finished hole ... in your case, finish hole size is 3/16 ... pilot hole size would be 3/32
PoorUB
Fargo, ND
material
size of hole
type of fastener
You forgot type of machine and HP. I worked at a machine shop and we would drill 2" holes in plate steel with a HSS bit and no pilot hole, but then a super rigid machine and 15 HP you can do it!
A pilot hole is necessary with lower HP tools, perhaps a hand drill. I usually would drill a pilot hole roughly the same size as the web of the finished drill bit size.
dnschmidt
Phoenix, AZ
The answer are Turbo bits (ASTRO) or what Norseman call Vortex bits. Both are basically miniature step drill bits. Problem solved. You can get individual Vortex bits from Epstein and the price is right.
dr_clyde
Holland, MI
This right here.
AEAdam
SE PA
The answer you seek is called "step up". Some materials are ok with your making multiple steps, some will want to work harden. Materials like Titanium need you to take a pretty big bite (big step up). Split point bits are good, better than not, but don't center cut amazingly well.
My answer would be a #40 pilot then I think you could step up to 3/16".
The better answer is it doesn't matter as much if your bits are sharp, and you've got the right cutting fluid, speeds and feeds.
I think 10 ga is like .13? That's sheet metal. Final hole may not be round and may be undersized. If you want a clearance hole, you may be better off with a #10 drill. Or drill 3/16" and ream 3/16"
tarbellb
Oregon
I'm convinced 90% of the people on this forum have never actually fabricated anything or turned a wrench in their life.
The theoretical scenarios in the thread are fantastic
Yup
At least we aren't seeing the copy paste from Ai..... yet
Lorydr
Piqua, oHIo
I tend to start with a 1/8" or close bit, for a pilot. Then I step up 2 or 3X to almost the final size, then punch through with the final size, then the final size hole seems to be cleaner.
I need to start using my step bits more.
Then a quick de-burring, with a much larger bit, at low speed & feed, for a half a second.
I think the proper step-bit (broad interval) can fairly de-burr most common holes quickly.
Nick Rivers
USA
Since your drill drifted, use a center punch then use a 142 degree Spot Drill. This will be a larger drill bit angle for your 135 split point and give you a nice dimple. You can use that single spot drill for most of your pilot holes if you have a set of 135 degree drill bits.
Avoid center drills. Center drills are ground at 60 degrees to drill turning stock for lathe centers.
The Cobbler
for a hole that small, I would center punch & then center drill or use a 1/16 bit to get a better divot . make sure your 3/16 is sharp ( and properly sharpened) slow rpms until it has seated
AEAdam
SE PA
where I work we drill millions of holes. Many millions are 3/16”. We typically pilot #40. We’ve done a lot of testing and a lot of studies on drill bit wear, & how to get the most life and on hole quality.
There is absolutely science to the choice/step up. We test all that stuff. But it could very well be that #40 bits are cheap and 3/16” are not as. So the industrial use of pilots and their specific sizes could be more about cost than quality.
