Spiral air compressor inlet baffle
Ike Carlson
Wisconsin
I brought home an old compressor that belonged to my uncle. The tank was rusted through so we stripped it down and saved the motor and compressor. The compressor has spiral baffles inside the intake filters! It’s a pretty quiet unit when running. I am currently cleaning the heads, valves, and ports to remove carbon and make sure everything is good to go. Most of the fittings and bolts didn’t even feel tight.
Here is a picture of the baffle under the filter screen.
I don’t have any info on the compressor other than a stamped number.
This is the compressor.
I measured the cylinder bores and stroke and the displacement is about 10 cfm at 700 rpm.
Has anyone seen/used these spiral baffles before? Not sure how restrictive they are, but they seem to be quite effective for noise.
Does anyone know who made the pump???
Sumboodie
AK
Tank would have had a date, but I'd guess it's in the area of 80 years old.
There's a bit that comes up searching for PAR compressors, but mostly seems other folks trying to get info too.
Don't know why, but 1940s in my mind is like 50 years... I actually grabbed a calculator to check my math cause my brain was thinking... that can't be. I mean 1990s was 15-20 years ago, tops... right?
I
Ike Carlson
Wisconsin
I hear ya. I am turning 39 today and it feels like the 90’s were just a few years ago!!!
