REED R Series. Post your Reed date stamps.
DCRUTT
Rochester, NY
I have an old Reed 104 that I picked up years ago for $10 at a garage sale. I’m cleaning it up to mount it on my new workbench, and am curious to know how old it is. There are two sets of numbers on both the static and dynamic jaws. A 234 that’s easy to read, as well as a very faint either 312 or 812. Any thoughts? BTW, first post, and what an awesome forum!IMG_0649.jpeg
Looks to me like 318 or 718 ( if upside down). That would fall in line better with the patent dates.
harleyrider
Just picked up a Reed 204 1/2 R in the last week. After complete disassembly and careful cleaning, under all the crud I found a really beautiful, clean vise with > 50% original paint and a wonderful patina. Features found on this vise pertinent to this thread include:
  • 5/53 date codes on left (non-logo) side of jaws (1/4" height)
  • hockey puck spindle
  • 4 bolt swivel base w/ single pawl bolt locking mechanism
  • forged welded jaws (non-removable)
  • threaded split spindle collar w/ set screw
  • forged spindle nut w/ split dowel pin & adjustment screw
  • Spindle screw & slide lubrication ports
Edited to add: shortly after I originally posted this I found & was able to purchase, a beautiful set of Reed copper soft jaw covers to fit this vise. This doubles the utility of what is now my favorite bench vise.
Some photos:
DCRUTT
Rochester, NY
  • forged spindle nut w/ dowel pin & adjustment screw
Here's few photos:
Great information.
I wish more people would update this thread with the same type of info.
harleyrider
Picked up another Reed this week. It’s a 104 1/2 in OK condition. Actually most of the vise is pretty straight & decent and it works as it should. The big downer is the slide, which some former user thought could be used as an anvil. The damage actually cracked the slide on the inside. Lucky it was cheap, or I wouldn’t have bothered with it. Vise is pretty filthy yet but I can see quite a bit of black paint beneath the grime. Not sure what my plans are for this one yet.
Here are the features & numbers on this vise.
  • 2/35 date code on left (non-logo) side of dynamic jaw (1/4”height) — 91 years old
  • # 1958 stamped (1/8” height) on top of vise body behind static jaw. Not sure what this is.
  • 4 1/2” jaws — forge welded, knurling nearly worn smooth
  • meatball spindle
  • standard spindle collar w/ set screw
  • cast spindle nut w/ simple dowel pin
  • weight ~ 55 lbs.
Some photos below
HR
jspam
1928 Reed 203 1/2 vise? Just inherited this very old 203 1/2 vise. I believe it was manufactured in 1928. It definitely has seen a few things by the looks of it. The slide is especially banged up.
There is a stamp that says "6 28" the the left of a diamond shaped stamp with a 6 in the middle of it. There is also a "104" stamped in a couple of locations. Interesting as well there are a plethora of smaller "5" stamped randomly on the top by the jaws. Must have been someone's tool mark maybe? Please let me know if I am incorrect on the date. I didn't want to be overly destructive trying to find markings and stopped when I found these ones.
It was rusty and partially covered in very bad black paint. I removed the black paint and tried to keep the underlying paint the best I could. Very rusty so I cleaned it using a soft wire brush and Evaporust. Cleaned, redipped and left the Evaporust on to dry for an aged but somewhat protective finish. This seems to work well.
It was missing the swivel lock nut/handle and cast nut thing. I made cast curved wedge nut using an old cast t handle I ground to shape. I just put an old square head bolt to lock it down. Looks age appropriate.
Lubed the bottom of nut with thick grease, and used white lithium on the other moving bits.
I like the patina but didn't want a rusty tool. I will leave it like this and it will probably see light use. I am planning on rebuilding an old bench and mounting on there once my tool shed gets built. It seems to work great, especially when you consider it's nearly a century old.
harleyrider
Okay, I recently picked up another Reed 204 1/2 R a couple weeks ago. I previously posted it up with some initial photos here:
Since then I stripped away all the crappy red paint, down to bare metal. Turns out there was really a pretty nice vise beneath that peeling mess. Everything is straight & clean, with all evidence indicating very light use over its lifetime. The only issue at all is that the static jaw insert appears to have a small bead of weld added on the top. It’s nicely done and will have no effect on use of the vise. Not sure why someone welded it; does not look like it was ever loose.
  • 4/65 date codes on right (logo) side of jaws (1/4" height)
It’s a beautiful vise and I’m not sure how I’ll refinish it (if I refinish it at all). Some photos:
HR
SoCal Vise
Sorting through photos the other day found this fun pic of a little #103 R I did last year. Made the mistake of choosing metallic turquoise haha.
Dated 1246. First year of the puck meatball I believe.
harleyrider
I’ve posted info & photos of each of these Reed 204 1/2 R’s earlier in this thread but thought I’d throw up a few photos of them together, each fitted with original Reed copper or brass jaw covers that I managed to luck into since I acquired both vises. One has original paint & a nice patina; the other is in the white after I removed the ugly non-original red paint.
Anyway, here they are.
HR
Mr. Wonderful
HR
VERY nice!!
harleyrider
I found this 6” swivel jaw vise for sale online. I can’t see any maker’s name or number markings in the limited photos the owner posted with the exception that I think I can see three numbers in the red circle in the last photo, although I can’t discern what they are. I asked about the function of the swivel jaw, and the owner was clueless as to what that even meant. That makes me think the swivel jaw has not been used for a long time. It doesn’t look welded or damaged so possibly could be freed up w/ some work. Overall vise is in decent condition with no obvious signs of gross abuse.
My questions: Any idea who made this? My limited search foo here didn’t turn up much. Also, any idea of value in its current condition?
Thanks for any info you can offer!
HR
ldg397
College Station, TX
Had really good luck with Reeds lately found a 105R and a 1041/2R.
The 105R has some issues needs an handle and split nut is three pieces instead of two but don’t think that will hurt it. The slide is pretty beat up near the jaw as someone beat on a few things while clamped. Seems to still slide pretty good all in all is good usable shape but paid probably too much but it was widow and don’t see the 105 and 106’s as much. It also has smooth jaws which I liked a lot.
The 1041/2 on the other was really rusty but jaws looked perfect but as I am cleaning it up noticed some white patches which had me worried but they wire wheeled off eventually and has some more scars up on top once I got it clean but everything else is in perfect shape. Dated to 1946.IMG_5848.jpeg
harveyduncan
Recently acquired reed 104. Included home made stand, 2 3” Williams c clamps and 2 thick coats of paint. Noticed the 532 stamp immediately, but after reading angrybeavers post decided to carefully strip and look for other numbers. Also because the pat pending made me assume earlier than 32? Anyway lo and behold there it was 113 on both January 1913 one month after a patent was granted.
Other notable markings- under the dynamic jaw stamped “O.K.F. N” no idea on that one. Also what appears to be remnants of the original light grey paint. Good times. IMG_8798.jpegIMG_8795.jpegIMG_8793.jpegIMG_8794.jpegIMG_8790.jpegIMG_8796.jpegIMG_8720.jpeg
AMJ6
I am a rookie restoring my second Reed 204 1/2 R, date code 9/53. This vice is a working shop vice, my issue is I have found wear on the handlescrew on the threaded side(pics attached)and the center bolt threads and where it screws into the centerbody. Any repair suggestions would be greatly appreciated.20260728_165809.jpg20260728_165839.jpg20260728_165743.jpg
drivesitfar
AMJ: you might post the pics with your questions about the with issues on the vise repair 101 thread in vintage section.
Depending on your fabrication skills or friends that have some will determine the repair.
Good luck!!
AMJ6
Good luck!!
thanks for the info.
harleyrider
Picked up a nice Reed 204R last night. It’s another one with crappy red paint applied over the original grey. I got it completely disassembled and overall it’s in very good condition. Everything is straight & clean, with all evidence indicating very light use over its lifetime. Jaws are still crisp and other than a few minor grinder hits on the static jaw, the vice appears nearly new. Not bad for over 70 years old. 😜
I cleaned & wirewheeled all of the small parts & the spindle. Then I’ll strip the paint layers from the static jaw, dynamic jaw, & swivel base down to bare metal and decide if I’ll repaint it or, like I usually do, just leave it in the white.
  • 11/55 date codes on right (logo) sides of both jaws (1/4" height)
  • serrated forged welded jaws (non-removable)
Hopefully I’ll get this one finished up by tomorrow.
Well, it took a few days longer to get back to this but here’s how it cleaned up. Really a diamond in the rough for its age:
Think I’m going to give this one to a friend of mine who showed an interest and said he currently doesn’t have a bench vise.
HR
ETA, I ate lunch with my bud the other day and gave him this vise. He was ecstatic! He’s going to bolt it onto his welding table. It’ll outlast him & me!
