v7guy
I've never tackled something like this before so I'm kinda just muddling my way through it with the threads i've read here. Lots of good info. Thought I would try to contribute to the body of knowledge already here.
I started out with this
I was encouraged when I saw it cause I've seen way worse rehabbed here... little did I know!
I started blasting it with some PB and letting it soak for a few days. I've never dealt with anything this rusty before other than the typical exhaust manifolds and motor mounts we all run into. I tried to loosen up the swivels to no avail and figured I should probably try to disassemble it.
With that in mind I set out to loosen up the allen head bolts that held the retainer plate on. I got enough of the paint off to get a small allen head wrench in and wiggled it back and forth a few times, seemed like it was coming loose... ended up twisting them all off.
the screw did come out though with no drama, oh, the little victories.
I cleaned up the key on the dynamic jaw and discovered I was probably just "reading" some pitting. Doesn't seem to be any date on this thing... other than a clearly stamped 1 on the very end.
So after having it mentioned several times and reading about it repeatedly I figured I try removing the rust with a bath.
Got some rebar and some copper wire, a plastic tub and some washing soda. The result was this little bath.
Never done this before so I was pleased to see it working like the write ups had shown in my searches. I hooked the neg from my battery charger to the swivel base next to one of the bolt holes.
1hr in
4hrs in
24hrs in
the results where pretty encouraging... This is after a quick rinse and a little scrubbing with a hand held wire bristle brush.
it obviously needed more time, so last night I stuck it back in the bath. This time I clamped the negative onto the body of the vise with the thought that the current would flow through it better and get the gunk that's left off. I'm hoping this will help free up the swivel base and allow me to get it apart.
thought about adding to my "identify this vise thread", but figured this would work better and be more "searchable" for someone else in the future.
1hr in
4hrs in
24hrs in
