Is this a pressure relief valve?
bw77
Upstate NY
The short piece to the right of the drain valve, under the pressure switch ****** - is that a pressure relief valve?
It doesn't look like any that are currently sold.
If not, is it a cleanout? Looks like pvc.
larry4406
Northern Virginia
Sumboodie
AK
No... well aside from it'll probably blow before copper pipes do being it's plastic.
Just redid mine, was a mess. Temp job, but still.
bw77
Upstate NY
The pressure switch was not working right and the pressure approached 100psi before I shut it off.
The plastic plug did not blow out. I need to replace it with a 75psi prv.
larry4406
Northern Virginia
The pressure switches are often mounted on a 1/4" NPT long ******. Those get plugged with crud.
Always clean/replace the ****** when you are having pressure switch issues. You appear to replaced the ****** and the switch already.
I have our pressure switch adjusted for 50 psi cut in and 70 psi cutoff. My PRV does not weep (not sure its setting now that I think about it).
The Cobbler
It looks like a cold start valve/ they are used in hard to start air compressors and let pressure bypass till something like 10 psi to relieve load on the compressor until everything gets spinning at full rpm. yours looks like a water system?
PCustoms
VT
I've never seen a pressure reducing valve on a well pump...
Adjust (or replace) your cutoff switch and verify tank bladder is all you need
22-W
That is a Cycle Stop valve. Also known as a mechanical constant pressure valve. I have used many. It makes you able to use a much smaller tank than normal, and still get enough pump run time, plus constant pressure.
PCustoms
VT
Really?
Looks a hell of a lot like the standard brass fitting that you get for any standard pressure tank...
Here's mine:
Sumboodie
AK
I replaced the pvc plug with a 75psi pressure relief valve, and I replaced the drain valve which was dripping.
Make sure your switch is shutting the pump around 60psi.
100 psi relief valves are also common.
Sumboodie
AK
Yes, works well. I bought it like 4 years ago, finally got around to installing it.
22-W
Sometimes they take a little bit of adjusting to make them work correctly, but they are foolproof once they are going. And power issues don’t affect them like they do on VFD’s, etc.
Sumboodie
AK
It has made the shower much nicer. Before was constantly varying temperature, depending if the pressure was getting down near 40 or was near 60.
Also the pump would cycle probably 3-4 times while the washer was filling.
I'd recommend it to anyone with a well. Other option is sizing the tank correctly, but a 120 gallon tank is about $850, and takes alot of space. And still wouldn't have even pressure.
With the CSV, the pump stays running while water is being used.
My tank is a "20 gallon", but it's really only ~5 gallon capacity. Was barely enough to flush the toilet and wash my hands without the pump coming on.
22-W
Even a 4.5 gallon tank will work good with that valve. The pressure will be more constant with a smaller tank. But I use a 20 gallon tank like you most of the time if there is room for it. Easier to set up than a smaller tank tank without a base. The biggest downfall is the increased back pressure between the pump and CSV. No problem as long as the pipes and equipment are in good shape.
