Between 265 & 485 SQ/FT Mesa Garage
TMorrow
Four Corners
Started my garage last Fall. It's 20' x 26' I'll be using it primarily as a woodworking shop.
T
TMorrow
Four Corners
This past winter was pretty mild for us here. I was able to get the floor poured in November and then carry on through the rest of winter with the build.
LXCam
Very nice OP. What R value are you shooting for?, R40 or higher. Thats a ton of effort and reduced floor space to compensate for 3-4 months of oven temps.
And how are you going to deal with the attic space?
T
TMorrow
Four Corners
Thanks.
The walls will be 12" thick plus another inch of plaster on the inside and outside. The light clay straw will give an R-value of around 1.75 per inch. The clay in the mixture adds thermal mass as well. The Larsen truss framing eliminates most all thermal bridging and sound transmission.
The ceiling will be six inches of Rockwool about R 21. I'm just planning to be able to easily heat it in the winter and keep it around 80 or so in the summer without AC. I did similar construction on our house but 14" walls and R36 in the Ceiling and it stays very comfortable year round.
As far as reduced floor space I just designed from the inside out.
T
TMorrow
Four Corners
The last couple of months I've been working on the light straw clay infill. The straw is ran through the barrel mixer with a clay slip which is a mixer of the native clay and water. This coats the straw with the slip. The straw is then packed into the wall cavity using sheets of OSB temporarily attached to the wall framing. After a couple of hours the forms can come off. Once dray this clay coated straw mass forms a surprisingly firm wall.IMG_3.jpgIMG_4.jpgIMG_5.jpgIMG_6.jpg
T
TMorrow
Four Corners
These are some antique windows that came out of a house in Delta, Colorado. The house was built around the turn of the century. I bought the sashes, then built the frames in my new shop! So nice to be building indoors again. Even in an incomplete shop.IMG_20260603_143523629.jpgIMG_20260603_143501216_HDR.jpg
T
TMorrow
Four Corners
I got the ceiling insulated. I used recycled denim between the purlins. It's rated at R13, on that I put 1" foam board that has an R4, So a total of R17 in the ceiling. We had some days of 95 degrees and it stays pleasantly cool in here now.
Andx0r
What a cool shop! I like the recycled windows.
Stepping out of the shop into that view every day would be a treat too.
T
TMorrow
Four Corners
I've also got the finish coat of plaster on the walls, the ceiling is sheetrocked, taped and I have about half of it skim coated with a product called Fresco Harmony. The walls are a lime plaster of one part lime, three parts sand, and yellow and red iron oxide for color.
