Tools of Japan
boxy30
Not sure if these have been shown before, but I was not familiar with them at all. While placing an order at Harry Epstein, I was browsing the IPS pliers and bought these on a whim. They are unique (to me) in that the middle slip joint is unassisted, but the two outer joins are spring assisted. The angle seems handy and the quality is typically great IPS.
I’ve had the 200mm version of these and really enjoy using them.
boxy30
Picked up the Ko-ken locking wobble extension, and a few Tone offset double box ratcheting wrenches that I was curious to try (made in Taiwan).
One thing that wasn’t mentioned before on the locking wobble extension is that the locking mechanism locks the socket in wobble-mode - you’d need to pull the lock collar to push the socket into fix-mode. I like that.
Reed Prince
Northern Virginia USA
My Soft Touch Neo pliers have a similar slip joint. They came in handy again last week.
rick carpenter
Huntsville, East Texas
I have the SF-200 Toji pliers, same as @boxy30, with baby **** brown handles that I bought a while back. I told folks here I bought the SF-165 pair but actually took a look at the labeling just now for the first time. They've easily replaced my western water pump pliers except for round plumbing fittings where my v-jaw crescents and channellocks rule.
Bryan/College Station, Texas
I just watched this review of the some of the newer Koken tools. It was nice to see someone show off and explain the tool a little bit more than just reading about it on the website. The locking wobble extensions and stud tools peaked my interest.
Stumbled upon some of these videos the other day. I got one of the Koken 169-10 trim clip removal tools because of that. I didn't know they existed and can't wait to use it!
Ultradog MN
Twin Cities
Am going through an old box that is full of mostly junky tools. Getting rid of a bunch of stuff. I know these locking pliers have been around here for a long time but I dont remember when or how they got here.
Was going to toss them into the give away pile but now think I will throw them into the tool box on one of my tractors.
Steel_Rain
Truecraft was a big importer of Japanese tools in the 80s&90’s from what I’ve gathered. I have a set a low use SAE ratcheting wrenches from them and these are great:
OE was TOP tools Japan, good stuff.
I’d hold onto those locking pliers too. 👍
rick carpenter
Latest arrivals...
Kakuri cork handle 9-1/2" ryoba, and Kakuri 10" universal cut kataba blade
0.7mm Staedtler 925-35-07 and 0.7mm Zebra M-701 mechanical pencils, Vessel bit holder, Uni leads holder, and Shinwa square (I know...).
The new ryoba is going to make me re-position my saw till. Ooof. I'm not sure why I'm collecting more and more mechanical pencils but I am. This is my second Vessel bit holder, I like the way they securely hold bits. The Shinwa square is made in PRC but I've seen it used plenty of times in Japanese carpentry and joinery yootoobes.
NitroExpress
Texas
I’m putting together a small box (Toyo ST350) of Japanese tools. In trying to keep up with weight and space savings I decided to go with hex bits and a driver handle. What I didn’t realize is that the Japanese don’t seem to do much in the way of basic hex driver handles. I’m not a huge fan of the ball type drive handles so the Vessell 900rt pictured above was what I thought would be ok, despite not wanting a ratcheting handle. I’ll have to say that I’m pretty unimpressed with the design of this Vessel. Bit retention is not good and the bit holder and mechanism seem like cheap plastic (black plastic bits are shedding of in my hands just handling it).
My current go-to handles that I like are PBSwiss, Felo, Gedore and Snap On. The search continues….
^ Check the "Battle of the Bit Ratchets" thread and ask @Dave455 what he's using for a driver handle for those bits.
And @Ohio Andy - both of those guys have tried out different models of those gizmos - they're pretty well-versed on them.
I use a cordless Makita myself... a bit large for that Toyo box. ;)
Steel_Rain
Thank you for confirming this. The Amazon reviews for this are awful and I've avoided it for that reason. This appears to be a re-brand?
I associated Vessel with only top quality items so this isn't invited. :ROFLMAO:
NitroExpress
Texas
Thanks for the info. The thread is about bit ratchets and I’m just looking for a made in Japan screwdriver style bit holder. This is a bit of a silly rabbit hole I’ve gone down….
The thread is about everything-under-the-sun-related-to-1/4-inch-hex-drive-bits-and-drivers. It sort of grew a life of its own.
Don't even try to read through the thread.
Just post the question, because they'll see it there. They won't see your question in this thread.
And if my memory serves me correctly, I think that Dave's favored driver is a ratcheting Snap-on, but I could be mistaken there.
NitroExpress
Texas
It does state that the bits and handle are “made in Japan”, however I’m unsure if Vessel actually make the handle. The bits appear to be typical Vessel quality, but the bit holder is pretty bad. The Japanese hex bit world is…. “Weird”.
FIFY
It's not just the Japanese - the entire planet has gone bonkers cranking out "the ideal" bit driver. There's a new one on the market every day it seems.
Every time I go up to O'Reilly's Auto Parts, they've got another new "bit driver" widget on display. Every time.
Dave455
Sussex, England
Oh no, I think I must be deleloping a reputation…!
To quote James Garner “What would a man want with a reputation”?
The important thing to bear in mind is that origins of a bit driver don’t really matter for hand operated / C6 bits.
For power / E6 bits it makes a huge difference. You have to use a Japanese tool with a Japanese bit (or they don’t fit) and it’s best to use a U.S. or European spec bit with the same spec tool, or they have a lot of slop.
But for hand bits, you can use what you like.
In honesty, my favourite non ratcheting bit driver (and we all need one) is probably the PB 186 M.
You do need the magnetic version, but subject to that, these are pretty faultless. The whole tool is durable, but particularly the handle - no useless (but cheap) soft finishes. The bit retention is superb, and they are inexpensive.
For ratcheting, I must admit I prefer the hard handle Snap On. The ratchet is smooth, but most importantly the handles are durable. That is so important.
I like the short version, so handy, but also the ergonomic T handles, if you have space.
The PB Swiss are also superb, and the new ratchets are buttery smooth. Probably better than the Snap On. But.. they only come in soft finish handles now, which suit maybe 10 % of my tasks! The older sprag clutch tools are lovely, and the cross handle are nice too.
And I think honourable mention has to be made of the Facom. A lovely smooth ratchet. Little back drag. Durable handle. And overall very nice to use. Reasonably priced this side of the pond.
If you wanted Japanese then Vessel make a selection. I only have the yellow Powergrip model. It’s o.k. but let down by the plastic bit retainer which doesn’t feel durable.
CGarage
United States/Switzerland
I agree with @Dave455
My own thoughts:
Vessel makes a clear handled ratcheting screwdriver with the bit magazine inside the handle.
This is the best ratcheting screwdriver I have ever used.
I own the Facom ratcheting screwdriver pictured. It’s a work of art to behold but it is BIG.
I think the Snap-On ratcheting screwdrivers are nice but I prefer the Vessel. I think the Snap-On / Williams equivalent is more durable for automotive environments with fluid contamination etc etc being a possibility.
cherrybomb
Near Madison Wi.
I know these have been posted several times over the years (Looking at your @Dave455 ) ...
BUT....I finally convinced myself to buy them:
I dunno ya'll...these might be, "the one". Best grips ever, beautiful finishing and extremely solid build quality. It's the Japanese version of the SO hard handle, just much more pruuuudy. :ROFLMAO:
Nice tools,as you get older and lose a bit of grip,the bolsters are a nice feature
2barevo
are those PB Swiss ratcheting screwdrivers discontinued? I could only find the 8510 which is a different style and not the clear handle.
Dave455
Sussex, England
Sadly they are.
I’m not exactly sure why, as they were a superb design. They were the only bit drivers that used, essentially, the multicraft handle. They also had a “toothless” sprag clutch ratchet.
In fairness, the ratchets on the 8510 are also superb. They are buttery smooth and a delight to use. The downside of the 8510 is the soft Santoprene handle. Sure, some folks might like them, but they are pretty useless for anything I might want to do.
The 8510 is currently being replaced by the 38510 and I think that’s probably a much better handle.
Ohio Andy
Columbus, Ohio
Sadly they are.
I have a couple of the PB Swiss with a "clear" handle that are NOT ratcheting. One is similar to the 6510.20, so similar to the link below but with the hard handle. I really like it. Frankly, I did not even know that they offered one that was ratcheting. I think that people made fun of me here when I mentioned that it was difficult to use it without "sniffing" it because it smells like vanilla.
You can get a different in the handle design (I really like these as well) in all sorts of colors (black, green, red, blue, purple, and yellow).
I have one of these in my hand right now and yes, it still smells like vanilla.
Most of my "soft handle" stuff is the older design, and they work great. The drivers that i have with the newer updated handle design, well, I like the new design. I considered replacing what I have and then the craziness left me and I opted to make do with the older design.
00 Scrub
What's the current tariff/shipping situation these days? Is it worth it to use something like Blackship? I vaguely remember folks using Amazon.jp direct to the US didn't have to pay tariffs?
I might have to use something like Blackship since not all the items I want are available to ship to the US.
Thanks
moemc
Using Amazon.jp wont get around tariffs when tariffs are active. Amazon will either add it in during checkout, or you'll have to pay it during package clearance.
moemc
Tried my hand at making a lightbox sign with the Koken sticker design I traced a month or 2 back. The yellow one had some flaws so I decided to do-over, but I changed the color to keep it interesting. It almost looks white in pics, but it’s a nice turquoise. It’s 300mm wide.
Outahere
Idaho
Latest arrivals...
............. I'm not sure why I'm collecting more and more mechanical pencils but I am. .........
I definitely own more mechanical pencils than I really need. You might find this short video interesting:
YesIHaveAHammer
I've been impressed with the innovations and wide range of pliers coming out of Japan. Designs or variations that are either unique, more commonly available, or originated there. This isn't even getting into precision and craft pliers.
Sharing for your interest, and would be happy to hear more. Links instead of photos, and one example each I'm afraid, or I'd be here forever. Different brands often have their own models for a given type, or a manufacturer may have different variations or sizes. Thanks to all who shared their picks here over the years, I will link to some which I bookmarked.
Japanese linesman - with a slimmer head, and commonly available in smaller sizes.
e.g. Tsunoda PW, Keiba FCC-118
posted here
Linesman with cable shears
e.g. Fujiya 5060
Semi long nose plier, heavy duty - big, aggressive teeth, no cutter
Merry Y75
posted here and here
Extra long slip joint plier
IPS HLS-300
Angled blade diagonal cutter - halfway between a normal one and an end cutter.
e.g. Fujiya 50A
Cable tie tightening and flush cutter
Tsunoda KBN
posted here and many other times
Round cut nipper for cable ties - for shortening
Merry JG695
Screw removal pliers
e.g. Engineer PZ-54, Merry ZA185
posted here
Nail in tyre removal pliers
Merry 2500T
posted here
Disconnect plier
e.g. Merry HS175C
posted here
Interchangeable tip snap ring plier
e.g. Merry JC175B & HC175B
posted here
Clip removal pliers
e.g. Merry JR60, JR66Y, JR80
Relay pliers
KTC AD201
Tiny plier set - linesman, long nose, and diagonal cutters 70mm (3") long
Keiba BT-010
posted here
66HertzClone
Long Valley, NJ
Sadly they are.
As much as I like this tool, I hate it, I find that my grip on the tool results in changing the ratcheting action direction, over an over again......drives me nuts.
bongkar_YES_pasang_NO
Indonesia
posted here
e.g. Fujiya 5060
Merry Y75
IPS HLS-300
e.g. Fujiya 50A
Tsunoda KBN
Merry JG695
posted here
Merry 2500T
posted here
Disconnect plier
e.g. Merry HS175C
posted here
posted here
Clip removal pliers
Relay pliers
KTC AD201
Keiba BT-010
posted here
can you recommend me japanese pliers for electrical installation?
maybe something similar to Knipex 13 96 200
