YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 498
I have toe plates and am trying to understand how to DIY adjust the toe on my car. My car service information states:
Rear total toe-in: 2 +/- 2 mm (0.08 +/- 0.08 in)
Front total toe-in: 0 +/- 2 mm (0 +/- 0.08 in)
How do I get a measurement down to 1 mm increments with a measuring tape?
Let me take the rear as an example
If I'm understanding correctly, using the toe plates, I can measure values A and B. I want toe in, so I want A < B.
Total Toe = A - B
Let's say when I calculate the total toe, I am not within the stated specification of 2 +/- 2 mm (0.08 +/- 0.08 in). Lets say I get 5 mm, under the assumption I could gets this type of measurement with a measuring tape. How do I know which tire(s) to bring in inwards or outwards? Tire C or Tire D?
I do not believe there's a way of knowing which one to change, because all I know is the total toe, and don't know where it is coming from? I could have one of three situations:
Tire D is perfectly parallel with the Forward direction, while Tire C is angled slightly in a toe-in state (1) or toe-out state (2)
Tire C is perfectly parallel with the forward direction, while Tire D is angled toe-in state (3) or toe-out state (4) direction.
Neither Tire C nor Tire D is perfectly parallel (options 5-8):
(1) Tire C is toe-in, Tire D is parallel with Forward
(2) Tire C is toe-out, Tire D is parallel with Forward
(3) Tire C is parallel with Forward, Tire D is toe-in
(4) Tire C is parallel with Forward, Tire D is toe-out
(5) Tire C is toe-in, Tire D is toe-in
(6) Tire C is toe-in, Tire D is toe-out
(7) Tire C is toe-out, Tire D is toe-in
(8) Tire C is toe-out, Tire D is toe-out
Given my measurement of 5 mm, I can cross off Option (5). But other than that, there doesn't appear to be much I can deduce.
Now if I could create a line with a piece of string that is perfectly parallel with the forward direction, I could deduce if each tire is toe in or toe out, and by how much, but how is this possible to do? From there I could figure out which of the 8 possible situations I am in, and determine which tire(s) to bring toe in/out. Wouldn't my piece of string be off by a few degrees of being true parallel with the forward direction, impacting the accuracy?
