Growing up - American and Swiss
Bondhus and Eklind
I had been aware for some years of Bondhus. Their “ball hex” drivers were well known from the outset, and a local shop had a big display of them.
Over the years I acquired a good deal of Bondhus, and came to value it’s quality. Although this post is about regular hex keys, I should mention that I’ve found the Bondhus T handle hex keys to be about the best overall. I like the drivers too, but the handles on the smaller sizes are ridiculously small.
So, needing some long hex keys, ideally ball tipped, I set out to get some Bondhus, but found some Eklind on a deal so tried them.
That was a good purchase. Those Eklind sets have lived in my main box ( in fact survived two changes of box ) for decades and have withstood a lot of use. I think the Bondhus would have done so too.
It’s perhaps a little unfair of me to discuss Bondhus and Eklind in the same paragraph, since I know they are competitors, but from my side of the pond the products are very similar.
They are both incredibly well designed, both very well made, both from very good materials, and both with good quality control. I also have to say that both represent incredibly good value.
Even in the U.K. these tools are priced comparably to tools sourced much closer to home, so there’s really little excuse not to own these.
If you live in the U.S. - there’s no excuse whatsoever!
Bondhus / Eklind are best for value, good for overall quality.
I slightly prefer Bondhus for T Handles, and Eklind for regular keys, but that’s just a slight preference!
P.B. Baumann / PB Swiss.
About that time, I bought a set of ball hex drivers, used, from a local shop. They were from the, then unknown, manufacturer - P.B.Baumann.
These drivers were typically Swiss (something about the style and finish you get to recognise) and obviously of the highest quality, but I only realised how good with use. I used these drivers an awful lot, and they just didn’t show any wear, I couldn’t believe it.
I eventually found their U.K. importer and started buying their regular hex keys. The difference in quality between these and anything else was considerable. They were stronger, better fitting, better finished, and seemed almost not to wear.
I’d use one key of my own for assembly work in preference to the boxes of mid grade keys I was supplied and I was never let down.
I’ve heard people on this forum describe PB Swiss as a “boutique brand”, obviously thinking that their selling point is their coloured keys, or suchlike.
To do so is to totally misunderstand the product. For a start, they’re not a “brand” they’re a manufacturer - a distinction lost on many.
Their selling point is their quality - evident on close examination, or prolonged use, but they are much more.
Max Baumann, the “big cheese” at PB, told me that they carried out extensive research to find what their customers wanted.
One of the things their customers didn’t want was bent keys - so a PB key will deform elastically to it’s limit, and spring back to it’s original shape. Bent beyond that, it will break, but it won’t deform!
PB keys are also designed to flex by a comparable amount when they reach the limiting torque for a typical fastener. When you get used to using them in assembly you find this is true, and I can assemble 4mm x 0.7 cap screws with a PB hex key just as accurately (probably more so) than some monkey with a torque screwdriver.
Their biggest strength though, is their ability to withstand high repetitive loads. I once had an assembly task that involved inserting button head screws. That had to be torqued up quite tight, but couldn’t be accessed by a regular driver, it had to be a ball tip.
We were eating through Wera bits at a shocking rate, and Wiha drivers did little better. We switched to PB and completed the job (hundreds of units) with no further breakages. They are that good.
So, PB Swiss are best for overall quality (and finish) but also very good for the quality of their fit, and the selection available.
They offer short or long keys, standard or ball ended, and I think were the first to offer both the coloured keys, and the short / 100 degree offset.
Somebody will no doubt point out that in some numpty’s hex key test they didn’t take any more of an overload than the next best. Well, firstly they’re not designed to, and secondly, I couldn’t care less - that’s not how I use my tools.
