Duty cycle on air compressor requirement, automatic drain valves for outdoor environments
clinto
Statham, Ga.
Two major questions in this thread:
  1. How much duty cycle do I need for my intended uses (described below)?
  2. How to drain moisture from my unusual air distribution system?
Duty cycle
So, I rarely use air tools anymore. I have cordless impacts and various hand tools.
But, I've always enjoyed paint work and have always wanted to do more of it. I've painted a fair amount of equipment and components and plan on painting my M35A2, my '65 fastback and my parent's Chevelle. I also have a pretty nice sandblast cabinet, that like all of them is pretty thirsty.
My 5hp, 60 gallon single stage Ingersoll Rand from 1991 is wearing out. I know I need more volume, but what I can't decide on his how much duty cycle. I plan on buying a 7.5hp, 230V single phase, 80 gallon compressor as an upgrade. There are many different units on the market, with duty cycles ranging from 60% to 100%. I feel like I need a 100% duty cycle, because I strongly doubt a sandblast cabinet is going to allow even a big unit like I'm describing to stay off long enough to cool off. Most of the units I've looked at barely hit my sandblaster minimum (21 cfm @ 80 psi). The Northern tool unit is 26 cfm @ 90 psi w/ 60% duty cycle, the Quincy is 24.3 cfm @ 90 psi w/100% duty cycle, the Industrial Air is 22 cfm @ 100 psi with an 80% duty cycle and the T30 is 24.3 cfm @ 90 psi with a 100% duty cycle.
So, for painting cars, and running a sandblaster, using an 80 gallon tank, what is the consensus? Do I need a 100% duty cycle or can I get away with less?
I don't wanna' blow $3-4K on a compressor and then burn it up by outrunning it's duty cycle.
Air system drain
So, I recently fulfilled a lifetime goal of building a shop for my antiques. I built a 30'x40' w/ 14' walls and 12'x12' insulated doors with a side awning for my stuff. It's so nice having everything indoors and I can't wait to be able to do all the projects I've never been able to do, like paint projects. I haven't done a build thread because I ran out of money and want to wait until I finish the interior to post up my build. But I do need help with my air system.
While I was laying the infrastructure out, I ran a 1" air line from my house garage, all the way back to the shop slab, and beyond the slab back to a small 12'x16' shed I use for the yardwork equipment and eventually my air compressor. I haven't wired the shed yet, so the compressor is still in the house garage, piping the air back to the shop. The house is the lowest elevation, the shop is in the middle and the shed sits at the highest elevation. Eventually, once the compressor is in the shed, it'll send air down to the shop, and then down to the house garage, so I can air up tires without having to drive back to the shop. Where the line is underground, it's sch40 PVC. Where it comes out of the ground, it's 1" black pipe and I'll be using the Rapid Air aluminum pipe in the shop and garage. There will not any PVC in the system that isn't underground.
Since the lowest point in the air line is where it turns 90° and comes out of the ground before going into the garage, it collected some water and got into the tools. I modified the 90° by adding a tee and a manual valve, as I was in the middle of a job and needed to fix the problem.
Soon I'll be finishing this up and I want to add an automatic drain at the lowest point, which is underground. I figured I'd put it in a valve / irrigation box with gravel in order to dissipate the water / air.
What kind of a drain valve should I be using? A mechanical, non-electric seems appealing for simplicity's sake, but I have also read a fair amount of complaints online about bad reliability, clogging, etc. Are there drain valves with a timer that are heavy duty enough for this application (outdoors, inside a valve box, where moisture and other environmental hazards will be present)? Any recommendations? Has anyone else built a system like this?
Some pictures:
Things I've painted:
The shop:
Sandblast cabinet and compressor.
I just checked and I do have the 1/4" nozzle. So at a minimum, I need 21cfm @ 80psi.
C
clinto
Statham, Ga.
Do you live in a climate where ambient temperatures drop below freezing?
Very rarely. I live near Athens, Ga., about an hour east of Atlanta.
Our coldest month is January, with an average low of 33°F.
I would say that each year, we do have a few cold snaps where it gets down into the high teens for a few days. Wind chill can be lower. I occasionally have to cover outdoor spigots, just to be on the safe side.
larry4406
Northern Virginia
Love that old Dodge!
Dad had a Navy surplus just like it. Slant 6. Granny gear with 1st non-synchro!
Look into continuous run compressors for long durations of blasting.
The pvc airlines underground would be a concern for me.
C
clinto
Statham, Ga.
Thanks. That's my buddy's truck. We bought it as a parts truck for his other crewcab USAF W200 and ended up putting it back together as a driver. It was a Slant 6, NP435 / NP208 (I think, can't remember). I love those things.
Underground PVC:
I'm not thrilled about it either. But I had to cover a run of almost 250' from the house to the shop to the shed and I couldn't come up with a better solution. Especially considering there were a couple of bends and several elevation changes.
I have a skid steer with a 48" trencher, I did all of this myself. I ensured the trenches were clean, and had no rocks or debris. I checked the system for leaks before burying and most of it is at least 24" deep, with the bulk of it being 24"-42" deep. The system has been in use now for about a year without issue (other than my mistake of not implementing a drain at the low point).
If the PVC fails, I'll have to reconsider the entire system. Perhaps a small 110V compressor in the garage for the occasional tires and a new line running from the shed to the shop.
I have been listening to the compressor for 20+ years, so once it's in the shed, it's never coming back to the shop. I wanna' hear the music, not the compressor. So if the delivery system fails, I'll have to bury something new to pipe air from the shed to the shop (approximately 90').
The PVC is totally buried, anywhere there's a vertical pipe coming out of the ground, it's black iron or galvanized pipe. I know several people who have piped air with PVC and had it last for years. I wouldn't do it because of the explosion risk, but I figured with it insulated on all sides by dirt and deep underground, it'd be ok. Worst case was that if it fails underground, I abandon it and replace it with something better.
We'll see if my chance pays off.
Other Power Wagon shots:
larry4406
Northern Virginia
I used RapidAir between my barn and house. It’s rated for direct burial and even encapsulated in concrete.
I hope to move my compressor to the barn this year and finally energize it.
C
clinto
Statham, Ga.
So, didn't get much traction on this thread, but I did want to update it.
Yesterday, a T30 popped up on Marketplace at a good deal. It had an IR aftercooler and an IR refrigerated drier with it for a pretty low price. I went and looked at it and no rust came out of the tank, it filled up very quickly, sounded healthy, so I handed over the cash. Both units are older, I recognize that. I suspect I won't get many years out of the aftercooler. The compressor I'm not worried about as much. I can rebuild the pump and replace or repair the motor if need be. I checked the tank religiously for cracks and looked inside it with a borescope and it looked good.
It's a 5hp unit. I really wanted a 7.5 unit, but they seem to come up for sale extremely infrequently. I've been watching Marketplace and Craigslist like a hawk. It's a 242-5N.
I really hope this is enough. I occasionally paint cars, but the bigger thing is my sandblast cabinet. It's such an air hog. A shop I worked at in a prior life had a 7.5hp, 80 gallon T30 and it was so awesome it would shut off while you were blasting. It was crazy.
I do have a question about the air drier - (and I'll start a separate thread for this, as I doubt many will see it here) - should I pipe the shed where the compressor lives to only send air through the drier when I'm painting or blasting (to try and conserve the life of the drier) or should I just run the air through it all the time?
Shoreline_
Springfield, MA
I would try to run air through it all the time because your piping will have wet air or condensed water in it you'll have to purge before you can get dry air out that piping. It won't matter if that unit runs all the time. It works just like a window ac but instead of room air it's compressed air.
Beerhippie
Far NE Oregon
Same air dryer we use here at the brewery. I have several remote air reservoirs (surge tanks) and they never accumulate any water.
The idea of running compressed air through PVC gives me the willies--well, actually scares the hell out of me. The Rapidaire suggestion above is the right way to do it. Rapidaire (PEX/Al/PEX) will not produce shrapnel if it does burst for some reason (backhoe, driving over the buried line with your M35, etc) and is totally corrosion-proof.
If you've ever seen a PVC pipe that has burst under pressure, you will think twice about walking anywhere near where that pipe is buried.
C
clinto
Statham, Ga.
I have (seen PVC fail). At a former place of employment. Too long of a story to type out. They didn't listen to me and got what they paid for.
Now, in my case, the only place I used it was buried to get from the house to the shop. And I have a 48" trencher on my compact tracked loader. I buried it as deeeeeep as the trencher would go. Like the bar turned literally straight down. So I'd say that the most shallow section is maybe 36". It transitions to black iron pipe at the vertical so all of the PVC is as far away (deep) as possible. It's now been in operation for almost a year without issue. But we'll see how long I get. I'm almost 51 so I need it to last another 21-30 years.
But if it fails, I'm not sure what I'll do. It's about 300' from the house to the shop to the shed. I guess if it fails, I'll redo it in RapidAir. I don't know what else to do. There's now so much infrastructure buried that I'm running out of places I can safely trench without getting so far away that I'm adding a lot of material to the equation. I have the power going to the shop, air, water, fiber for the internet, irrigation, etc.
I worried myself sick when I was doing this on what to do. I'm a perfectionist and would have preferred to use something like RapidAir or galvanized or black pipe, but I did this on the shoestringiest of budgets and I had access to several hundred feet of Sch40 and have tons of friends who've gotten away with it for decades. So I took the gamble. I live alone and don't have kids and my cat is indoor only. If it takes off my foot, I'll let ya'll know.
strutaeng
Dallas, TX
5 HP should be fine for the spray gun. Do you already own a paint gun? If not, look into the various types of spray guns and their specs.
HVLP models generally consume the most air, with true HVLP around 13-16 CFM, and the atomization on some models may not the best for high solids clears, and/or fluid output lower than other guns (ie, very "slow" guns.) They claim material savings, but for the hobbyist, probably wouldn't matter just painting 1 or 2 vehicles. For base coat spraying metals, I think is where of these are great.
Look into Reduced Pressure (RP), sometimes called "compliant", Transtec, OP or some other proprietary name. These typically operate at slightly higher pressures but excel at atomization and put out good amount of material, all with about 9-12 CFM consumption.
LVLP is yet another type with even lower CFM consumption (6-9 CFM), but I believe the consensus is that those are even slower and smaller fan pattern. You have plenty of air that I don't think you even have to consider these.
Some paint guns don't even say what type they are, but you can tell by looking at the CFM consumption.
C
clinto
Statham, Ga.
Why not pair your old compressor with this newer one if/when you need more?
Considered that. I think my old unit probably needs a refresh. It's really old (early-mid '90s) and seems like it has to run longer in order to refill the tank and it seems to create more water. I think it has to run all the time and therefore runs hot and creates more condensate.
I guess I need to look and see what a ring and gasket set costs for my unit.
Yes, I have several guns.
Multiples of the Harbor Freight HVLP, which I think are fantastic. You wouldn't believe the kind of results I've gotten out of a $10 gun. 6 CFM @ 40 PSI
I have a Harbor Freight Black Widow HTE, which I just bought and am still learning, but so far it's a big step up. 11.8 CFM @ 35 PSI
Finally, I have an Iwata LPH400-LVX 1.4mm for my "I really don't wanna' screw this up" jobs. 9.8 CFM @ 16 psi
I prefer a slow gun, as I don't have enough experience to really throw paint and clear down at high speed / volume.
I have extremely limited experience with paint, but I really enjoy doing it. I've always suffered from not having a facility so I couldn't take on bigger jobs. I had nowhere with climate control, and nowhere to have a vehicle taken apart in bare metal or primer. Now that I have sufficient space, I want to create a paint booth area where I can manage the environment (temperature, humidity, dust, etc.) and
I have painted some stuff in the past that came out really good. I'm trying to get better, as I have a couple of cars I'd like to do full paint jobs on. But I have a long way to go on gun setup, technique, etc.
I painted this for my buddy several years ago.
