Todd's & Other Patent Nippers
OK, starting a new thread, don't see anything dedicated to these on the vintage side. I mentioned back in May that I found a pair of Todd's Patent nippers, but didn't post pictures. Looking at the various posts here and elsewhere talking about the varied history of these, a maker thread seemed inappropriate, especially since mine don't have an apparent maker name on them.
The history of these nippers is interesting, patented way back in 1876 or so, made by a few people, but continued to be made, crediting the patent, for a long time afterwards. four.cycle's list of manufacturers has two who made Todd's patent nippers, including Hotchkiss and Henry B. Todd / Meriden.
These were advertised as electrical wire nippers in 1891, which was a surprise to me. I had assumed carpenters or farrier's nippers prior. I read on Progress... that ironworkers used them to cut rebar.
Anywhere, here the are, as recovered from an antique mall in Paso Robles, CA, at 15" long, about 5/16" jaw capacity, with the legs bent/ twisted in opposite directions.
The blades were rusty, and I could not see the seams between the jaw and the blade.
They are sporting the Todd's Patent phrase, and a hex stamp with an A inside
Fast forward a couple of months, and I've cleaned them up a bit. The jaws got dunked unto a beaker of Evaporust, and then polished on the 3M 220 radial bristle brush. Then I tried to remove the jaws to clean and sharpen them. 3 of the 4 screws came loose easily with my Grace gunsmith screwdriver, the 4th cammed out under hand strength. ****. Time to take desperate measures. These are 10-24 thread screws (so fairly modern mfg, newer than the patent.) But they had a taller head design, so I knew I could not replace them like for like easily. So its off to the screw loosening arsenal. PB blaster, nothing doing. Heat, nothing doing. PB blaster chased by heat, heat chased by PB blaster (epic fail, lotsa smoke, not sure anything stayed on the metal. heat followed by paraffin. My heat was only a propane torch, so I wasn't expecting miracle right away. I left the opposite screw and opposite jaw installed. After 2-3 heat and wax cycles, I tried the impact driver (whack w hammer version). Put a 3/8 - 1/4" adapter, a 1/4" socket, and a stout flat head hex bit, and whacked. Third whack the bit started twisting the tip. Back to the heat / wax cycles. This time I dug out a Makita hex drive flat head impact bit, and repeated the whacking. After the third hit, I swore it had moved, so hit it 2x, definitely rotated. Puled the driver up, dropped the impact bit, and it rolled under something, lost 15 minutes looking, gave up. Got out a regular screwdriver, and it twisted by hand. Victory. When I pulled it out, there was WAX!!!! on the threads. Also found wax on the other one that was previously loosened.
Next step was to drive the blades out of the jaws. Couple of taps with a punch and a ball pein hammer, they moved a bit, so moved to the arbor press, and pushed them the rest of the way out. Cleaned the blades up, fairly dull. Started by removing the paint / jappaning stuck to the blade, then took to the power sharpener. After a moment, it was obvious that the center of the blades was worn down more than the ends, so took some work. It was obvious these had seen more usage than was visible when they were rusty. I tried to sharpen both top and bottom equally to keep the cutting edges centered, but missed by a bit, will fix that when they next need sharpening.. Cleaned paint, rust and crud from the grooves on the jaws, one blade went in easily, the other needed to be pressed in. Readjusted the stop so the tips just contacted, will back it out a little more shortly, shown adjusted slightly open here. Found some 10g stranded wire, cut that without a concern.
Didn't completely clean up the one screw, maybe some other time. But they are ready for use. Now to clean up the KK's from earlier.
The final trick will be to bend the legs back to straight, but that will be another day, when I can clear enough space of to bring the new arbor press up off the floor.
Mintgrun
Kingston, Wa.
Those are in much better condition than my beat up old pair of 12" No. 1 Todd's patent cutters. While putting them back in the snips drawer, I found a larger pair that I forgot I'd bought. The Carew's Pat. snips are 14" long and quite a bit beefier.
It is interesting how there is a second MADE IN USA stamp buried in the deeper Todd's stamping.
Tom
R
Speaking of which, seems his site has disappeared, did I miss an announcement?
Todd / H.B. Todd, Meriden, CT / "Todd's Patent" / patent 182615 285446 / (see also Meriden)(see also Hotchkiss) / http://progress-is-fine.blogspot.com/2012/04/vanished-makes-carew-patent-cutting.html / http://alloy-artifacts.org/other-makers-p3.html#todd-patent /
Meriden / Henry B. Todd, Meriden, CT / "Todd's Patent" Meriden Cutting Nipper / patent 182615 285446 / (see also Todd's Patent)(see also Hotchkiss) / http://progress-is-fine.blogspot.com/2012/04/vanished-makes-carew-patent-cutting.html /
1891 Electrical Engineer Todd's Patent Meriden Nipper
1923 American Artisan and Hardware Record Sept 22, 1923 pp 28 Todd's Patent Cutting Nipper No....jpg
1923 American and Artisan and Hardware Record Todd's Patent Meriden Nipper
Hotchkiss / T.D. Hotchkiss Co., Deep River, CT / "Todd's Patent" Meriden Cutting Nipper / patent 182615 285446 / (see also Meriden)(see also Todd) / http://progress-is-fine.blogspot.com/2012/04/vanished-makes-carew-patent-cutting.html /
1916 Hardware Retailer T.D. Hotchkiss Todd's Patent Nipper
1921 America's Leading Manufacturers T.D. Hotchkiss Todd's Patent Nippers pp 292.jpg
1925 Hendrick's Commercial Register of the United States T.D. Hotchkiss Todd's Patent Nippers ...jpg
1025 Hendrick's Commercial Register of the U.S. T.D. Hotchkiss Todd's Patent Nipper
As mentioned in the 2025 GS thread, I have 2 pair of what I believe are Todd's patent nippers:
Mine both have the reversible jaws, and both are in decent shape, except one jaw insert on the smaller pair has a chunk missing i I suspect from being used as a hammer. Interesting to me that these were aimed at electrical wire, as with replaceable inserts, I had assumed hardened and for hard steel wire; like piano wire.
Big pair has no obvious markings, but with Phillips head screws on the jaws, likely much later production, so maybe the patent's ran out?
and the small has a stamp, but its bigger that the space available, so largely unreadable:
Taking the liberty of posting these here, as we do not have a dedicated thread for Carew.
Maybe @RTM can massage the thread title a bit? :unsure:
Carew's Patent Nippers 14 inch (patent 107334) 05/13/26
works for me! I have a serious aversion to creating new threads - it just adds more clutter and confusion.
Those Carew nippers are serious. I got a finger caught in the jaws -yeow! Small wonder they were the choice tool for ironworkers.
