Garage lighting upgrade- before and after
AC-WC
NE, Indiana
Please keep us updated on the longevity of these lights. I've read some not good reports from fellow GJ members about warranty support. Agree with the 5k/5k it's a huge change.
P
PapaBuilds
Will do! I doubt they'll warranty mine. I spliced and extended the daisy chain wires to get more of a spread on them
rwilly
maple valley wa
The Barrina lights I put in my garage are starting to fail at a rapid rate after 5 years. I’m currently looking for another, longer lasting brand.
The Barrinas are nice and bright when they are working, they were also inexpensive, but I want a longer lasting option. I hope you have better luck.
P
PapaBuilds
Here's hoping, they weren't too much work so if I get 5 years out of them I'd call it a success.
rwilly
maple valley wa
Doing the math.
I have 15 sticks running the length of my garage, if I have to replace all 15 every 4-5 years at a cost of $200.00, that comes to roughly $4.00 a month.
Is that considered good?
P
PapaBuilds
Doing the math.
I've got 6 in mine, obviously I don't WANT to replace them. But IF they go out in 4-5 years I dont think that's too bad.
R07AG
Wisconsin
Looks really good! I hear good and bad about Barrina so I'm curious how your experience turns out.
I did something similar last year with Harbor Freight lights and it's hard to think about how I was able to work before them.
OccupantRJ
Eastern North Carolina
Just yesterday I added a HF light over a darker area of my materials storage building to brighten things up a bit. There is an $18 coupon for them at the moment.IMG_1734.jpeg
P
PapaBuilds
Thats how I feel. I'll never be able to have sub-par lighting again!
duneslider
Riverton, Utah
Just for reference, I have had Barrina lights in my garage for almost 5 years. They get turned on at some point everyday and they are on a timer to auto turn off at midnight. So, they have a lot of hours and are going strong, just as good as some other "name brand" led lights in other areas of my house. At this point, if they do die I would be fine buying the same ones again.
OccupantRJ
I just happened to catch a shop video today where the guy says he gets about 3 to 5 years out of them because they gradually dim. First time I heard of the brand was on GJ yesterday.
duneslider
Riverton, Utah
I went and checked my Amazon history and I ordered my lights Nov 7, 2021 and had them put up as soon as they came. I have no noticeable dimming and none have died yet either. Mine are on virtually everyday from about 5pm until midnight and longer on weekends. I don't expect them to last forever but the way they are installed it would be super simple to replace them and just take slightly longer than a screw in bulb to swap out. It appears I can still buy the same ones.
I have also purchased barrina led grow lights and in the late winter early spring we have those on 24/7 for several months, those only have 2 seasons but zero issues there either.
P
PapaBuilds
I had the same thought. Plug and play really.
Rst277
Winnipeg, Manitoba, Canada
I still like using/converting florescent fixtures to by pass LED tubes. then when a bulb fails all you do is replace it .
Fluorescent fixtures can be bought used for very cheap .
Do you have a specific bypass LED tube that you use? I'm considering getting some for my farm shop but the variety available is pretty overwhelming. I would be fine getting some from amazon or home depot / Rona.
BillK
Beautiful Southern Maryland
Thats what I did in my business. My fixtures are all solid mounted with emt and it was very easy to do the ballast bypass. So far the 8ft led's I bought have been fine and I think its been about 4 years.
BillK
These are what I used. I got them because my local electric supply house had them and I preferred to get them locally. Not the cheapest but they have been working fine for at least 4 years ? Maybe 5 ? They are on from 6:30 AM to 4:30 PM Mon- Fri
The Cobbler
no, everything I've bought was from Habitat from Humanity and also Princess auto on clearance . they have served me well . all have had zero failures except for a lot of 2' tubes I got from Habitat . 1 in 3 fail almost immediately but the ones that don't fail quickly seem to last. there's been a handful of them on probably 30-40 hrs per week for 2 yrs and keep working. the others have been on the same for 4&1/2 years and no failures probably 30 to 40 tubes in total
FFRKing
Peck, Kansas
I have converted probably 500 light fixtures to ballast bypass LED T8 bulbs. The most common bulb I have used was this, and the one I prefer. I have one facility that is a 24/7 building with probably 150 2 bulb fixtures already converted and the oldest ones are about 5 1/2 years old with zero replacements. I'm converting mostly T12 fluorescent and some T8. Probably have over 300 left to convert when the ballasts die. Problem is you have to buy a case of 20 thru Grainger. We don't have that issue at work.
Home Depot offers a fixture already set up for this bulb for $38.
I currently have T5HO in my 30x50 shop but will install these in the soon to be built 30x60 addition. I have only lost 2 of 36 T5HO bulbs in 11 years.
Chris
Steve W.
Southwest oHIo
I did that last Fall.
Was browsing Craigslist, found a guy who deals in warehouse overstocks and dealer closeouts. PIcked up two boxes of Sylvania 'bulbs', 25 in each box. 4' fluorescent replacements, ballast bypass, 4100K, 2200 lumens. Took a few evenings to change all 16 troffer fixtures in the shop. Had to keep careful track of which ones I had done each evening, as there was virtually no difference in the appearance. Inspection of the fluorescents that came out show exactly the same specs, so the light is the same. The only difference(s) so far are that if the shop is on the cooler side in the winter, the lights are at full brightness NOW, the other difference is that the meter is not spinning quite so quickly.
Used 32 of the new 'bulbs' in the shop, another 12 in the garage attached to the house, and another 2 in the shed on the back porch. That leaves 4 spares, in the event of any failure.
Oh, I hadn't mentioned the icing on the cake. The 16 troffer fixtures in the shop were all FREE. Got them from work when they were replacing fluorescents with LEDs. Saved them the hassle of a trip to the dump with them, and even helped the 2nd-shift electrician change them out.
The sprinkles on the icing? My new Sylvania LEDs were $1 each. Yep, 50 tubes that usually sell for $10-14 per tube, for $50. :cool:
kbuhagiar
Escondido, CA
You ****.:LOL:
