Garage lighting upgrade- before and after
AC-WC
NE, Indiana
Please keep us updated on the longevity of these lights. I've read some not good reports from fellow GJ members about warranty support. Agree with the 5k/5k it's a huge change.
P
PapaBuilds
Will do! I doubt they'll warranty mine. I spliced and extended the daisy chain wires to get more of a spread on them
rwilly
maple valley wa
The Barrina lights I put in my garage are starting to fail at a rapid rate after 5 years. I’m currently looking for another, longer lasting brand.
The Barrinas are nice and bright when they are working, they were also inexpensive, but I want a longer lasting option. I hope you have better luck.
P
PapaBuilds
Here's hoping, they weren't too much work so if I get 5 years out of them I'd call it a success.
rwilly
maple valley wa
Doing the math.
I have 15 sticks running the length of my garage, if I have to replace all 15 every 4-5 years at a cost of $200.00, that comes to roughly $4.00 a month.
Is that considered good?
P
PapaBuilds
Doing the math.
I've got 6 in mine, obviously I don't WANT to replace them. But IF they go out in 4-5 years I dont think that's too bad.
R07AG
Wisconsin
Looks really good! I hear good and bad about Barrina so I'm curious how your experience turns out.
I did something similar last year with Harbor Freight lights and it's hard to think about how I was able to work before them.
OccupantRJ
Eastern North Carolina
Just yesterday I added a HF light over a darker area of my materials storage building to brighten things up a bit. There is an $18 coupon for them at the moment.IMG_1734.jpeg
P
PapaBuilds
Thats how I feel. I'll never be able to have sub-par lighting again!
duneslider
Riverton, Utah
Just for reference, I have had Barrina lights in my garage for almost 5 years. They get turned on at some point everyday and they are on a timer to auto turn off at midnight. So, they have a lot of hours and are going strong, just as good as some other "name brand" led lights in other areas of my house. At this point, if they do die I would be fine buying the same ones again.
OccupantRJ
I just happened to catch a shop video today where the guy says he gets about 3 to 5 years out of them because they gradually dim. First time I heard of the brand was on GJ yesterday.
duneslider
Riverton, Utah
I went and checked my Amazon history and I ordered my lights Nov 7, 2021 and had them put up as soon as they came. I have no noticeable dimming and none have died yet either. Mine are on virtually everyday from about 5pm until midnight and longer on weekends. I don't expect them to last forever but the way they are installed it would be super simple to replace them and just take slightly longer than a screw in bulb to swap out. It appears I can still buy the same ones.
I have also purchased barrina led grow lights and in the late winter early spring we have those on 24/7 for several months, those only have 2 seasons but zero issues there either.
P
PapaBuilds
I had the same thought. Plug and play really.
Rst277
Winnipeg, Manitoba, Canada
I still like using/converting florescent fixtures to by pass LED tubes. then when a bulb fails all you do is replace it .
Fluorescent fixtures can be bought used for very cheap .
Do you have a specific bypass LED tube that you use? I'm considering getting some for my farm shop but the variety available is pretty overwhelming. I would be fine getting some from amazon or home depot / Rona.
BillK
Beautiful Southern Maryland
Thats what I did in my business. My fixtures are all solid mounted with emt and it was very easy to do the ballast bypass. So far the 8ft led's I bought have been fine and I think its been about 4 years.
BillK
These are what I used. I got them because my local electric supply house had them and I preferred to get them locally. Not the cheapest but they have been working fine for at least 4 years ? Maybe 5 ? They are on from 6:30 AM to 4:30 PM Mon- Fri
The Cobbler
no, everything I've bought was from Habitat from Humanity and also Princess auto on clearance . they have served me well . all have had zero failures except for a lot of 2' tubes I got from Habitat . 1 in 3 fail almost immediately but the ones that don't fail quickly seem to last. there's been a handful of them on probably 30-40 hrs per week for 2 yrs and keep working. the others have been on the same for 4&1/2 years and no failures probably 30 to 40 tubes in total
FFRKing
Peck, Kansas
I have converted probably 500 light fixtures to ballast bypass LED T8 bulbs. The most common bulb I have used was this, and the one I prefer. I have one facility that is a 24/7 building with probably 150 2 bulb fixtures already converted and the oldest ones are about 5 1/2 years old with zero replacements. I'm converting mostly T12 fluorescent and some T8. Probably have over 300 left to convert when the ballasts die. Problem is you have to buy a case of 20 thru Grainger. We don't have that issue at work.
Home Depot offers a fixture already set up for this bulb for $38.
I currently have T5HO in my 30x50 shop but will install these in the soon to be built 30x60 addition. I have only lost 2 of 36 T5HO bulbs in 11 years.
Chris
