Replace Two Step Ladders for Fold Up
DesertG
I have a 6 ft step ladder with 10ft reach and an 8ft step ladder with a 12 ft reach. I would like to replace both with one Gorilla Ladder. Will I hate it?
ecotec
I think that the previous posters have already covered the subject very well.
Regular step ladders are way more convenient for the majority of the time.
The weight difference seems huge.
My SIL has one, and we were working on something on the house, so shoes off. The uncomfortable foot rails were awful compared to a normal ladder. I tried it again later w my boots on, still not something I'd want to stand on all day.
Dad was an early adopter of those in the 70s. Never learned to like it😆, barely tolerated using it. If trek to get the regular A frame ladder any time.
I have a fiberglass, aluminum and wood tripod in increasing heights.
neophyte
Pennsylvannia
If you want to replace the two strp ladders because of weight or convenience, maybe try the Hailo step ladders, which are usually fairly lightweight, but in many cases, still rated for 300lbs.
Apparently Hailo now makes a step ladder with extendable legs so it can serve as a 3, 4, or 5 stepped ladder. (I have no experience with this).
The regular ladders are pretty good as well.
Depending on the number of steps, the weight usually runs between 10-22lbs per ladder.
Aa for the Little Giant Multipurpose ladders and clones, I would probably recommend fiberglass, since it gives the extra electrical safety.
(Werner’s version is usually less expensive than the Little Giant fiberglass version).
One thing about Little Giant ladders, is while that pack up shorter than regular ladders, the actual ladders are otherwise bulky and heavy.
65ranchero
Danville, VT left NJ forever
This is my favorite 3 step ladder(also make a 2 step one)
Replaces a fold up step stool
More foot cover area and has built in grab bar and tool tray fold to a fairly thin profile
Shiftless
East Bay SFO
Mine is a Little Giant.
Heavy?, of course. It can’t be beat for working above staircases. Also, once it’s set up, the weight and the stiffness when you are on level surfaces gives you a lot of confidence when you are up in the air.
Do you know anyone who has been seriously injured or killed by falling off a ladder? I do.😞
neophyte
Pennsylvannia
A person’a body weight should help keep a ladder in place, and weight should only be an issue if you are mounting the ladder from a high location, since a person’s weight would not be there on the ladder to stabilize the ladder.
I have never felt insecure on the Hailo step ladders when climbing from the floor, and Hailo step ladders can be carried around with a pinky finger.
rharman
SoCal
I love that little 3-step ladder. It is rock solid. Have had one since 2010. Late 2024, I finally had to replace the treads. Used an outdoor rubber mat from Lowe's.
Also, the Flip 'n Lite. I have a 5' and a 6' version - since 2007. My favorite for general use around the house. For bigger jobs, the Little Giant M22' comes out.
Old tread on top, new mockups below.
Acetone wiped, masked for spray adhesive.
Overall shot.
Close-up of the new treads.
Shiftless
East Bay SFO
I have a conventional 6 foot fiberglass step ladder. I also have a 3 step step stool kept in the kitchen and used to access upper cabinets. (Upper cabinets run all the way to the 8 foot ceiling)
My heavy old Little Giant makes up into a 9 foot A-frame ladder when both halves are fully extended. That’s where the extra weight pays off… sometimes reaching out over the side and not feeling off balance. I also have outriggers and work platforms that attach. Handy place for a bucket or a tray with tools. It’s strong enough so that a guy can stand on it rather than standing on the rungs.
The Little Giant has equal capacity rungs in both sides so you can climb up either side or even have 2 people standing on it at the same time.
willf650
If you seldom use a ladder and want only one they are ok.
I find them super heavy and difficult to set up. They also hurt my feet after a while compared to a regular step ladder.
The only places they shine is if you need to get a big ladder into an elevator or back of a van.
Captain Spaulding
Southern Indiana
I have a 6ft platform ladder, an 8ft step ladder, a 10ft platform ladder as well as an 8ft. little Giant. I use them all, and consider the LG a different tool, not a replacement for any of the others
sparky 1971
Central Iowa
Gorilla makes more than one ladder so it's a guess as to which one is the topic. I have the Werner version of a Little Giant that extends to an 8 or 9' step ladder and I don't know how long of a straight ladder and there's no effing way that heavy finger pinching SOB would be my one and only ladder, I don't care how many things it can do. I've probably had it 12 years and used it four times, each time was a light above stairs. As far as stepladders go, I have two 2', three 4', three 6' three 8', two 10' and a 12'. Extension ladders: 20', two 24', 28', and a 32'. When I shut the business down I'll keep one of each step ladder up to an 8' and the 20' extension ladder. The rest, including the Little Giant wannabe, can go to the dump.
rharman
SoCal
Great for that and also if you need to work above a staircase.
One of our smoke detectors is on the ceiling above the stairs. My M22 Little Giant will reach but I have to have one side fully extended as it rests on the middle landing. It's a long ways up there! We also have a bank of 5 windows along that wall so the Little Giant got used all along the stairs when I was installing blinds.
danski0224
Near Naperville, IL
The Little Giant ladder can be positioned so you can face a wall, and be right in front of the wall.
Much safer than leaning a regular ladder against the wall- but there are regular A frame ladders that are made to be leaned against a wall, which is a fairly recent design.
Little Giant used to make a "regular" fiberglass version, and it was heavier than the best rated aluminum version. They make a fiberglass one marketed towards municipal customers now.
A commercial jobsite will not allow aluminum ladders. Some will only allow "podium" A frame ladders now.
finn
The UP, God's country
I have a Little Giant and a 5’ or 6’ aluminum step latter at the Az house. 90% of the time we use the lightweight aluminum latter.
I have an old steel fold up latter in Mi, along with an assortment of step and extension ladders.
The folding ladder gets used mostly as a work platform, or a dedicated staircase to climb to the top of the boiler /compressor/ electrical/ well tank / water heater utility room, where it’s been for the last year or two.
The most frequently used ladder is another lightweight 5’ aluminum stepladder. The least frequently used is a 32’ extension ladder.
I hate heights, and ladders in general.
captain14
vavet
Ashland, VA
I have had mine for 20+ years. saving storage space and ease of transport are the big advantages.
it’s heavy, it’s awkward to adjusted exactly how young want it. Mine maxes out at just under 8 foot as a stepladder, so using it in a house with 8 foot ceilings is tricky.
finn
If you get the Gorilla or Little Giant ladder, make sure you get the work platform and the set of wheels. The LG work platform will fit on the Gorilla ladder. I use it on my 6 foot step ladder and multi ladder. Like others have said the multi ladder is heavy.
Work Platform Aluminum Platform For Ladders and Scaffolding https://www.lowes.com/pd/Little-Giant-Ladders-Platform-for-Ladders-Or-Scaffolds/999968823
The work platform greatly increases the utility of the collapsing ladders.
I found one in the clearance section of Lowe’s a while back. Don’t recall what I paid, but I consider it a score, whatever it cost.
captain14
I found 2 of them. One on CL and another one at a building reuse type store. Both were $20 or less each.
Gmonkee
A 6' aluminum step ladder and a 12' alu extension ladder get me by. Both quite lightweight and easy to use.
I have used the other type and found the joints need to be kept lubed and clean, otherwise they get hard to release later on. I struggled with one a friend had years ago. Two were difficult on good days. Horrible if they got dirt in them.
Before this I made my own ladders from steel bedframe. I still have one that will last a few decades more than myself. It is used as a scaffolding stand now.
Common in Mexico for people to build thier own. Mine were heavy and I was glad to watch them go as I replaced them.
