Almost certainly, so the real question is how much does your hate for it make up for owning less ladders? If you don't use it often, then maybe you'll be happy enough with it (like I am)....Will I hate it?
yes, but they are heavier.Are those similar to Little Giant Ladders? I have one of those and it works great but heavy as hell
A person’a body weight should help keep a ladder in place, and weight should only be an issue if you are mounting the ladder from a high location, since a person’s weight would not be there on the ladder to stabilize the ladder.Mine is a Little Giant.
Heavy?, of course. It can’t be beat for working above staircases. Also, once it’s set up, the weight and the stiffness when you are on level surfaces gives you a lot of confidence when you are up in the air.
Do you know anyone who has been seriously injured or killed by falling off a ladder? I do.![]()
This is my favorite 3 step ladder(also make a 2 step one)
Replaces a fold up step stool
More foot cover area and has built in grab bar and tool tray fold to a fairly thin profile
Little Giant Ladders Folding Step, 3 Steps, 375 lb Load Capacity, 36 in Overall Height, Aluminum, Silver 11903 | Zoro
Order Little Giant Ladders Folding Step, 3 Steps, 375 lb Load Capacity, 36 in Overall Height, Aluminum, Silver, 11903 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.www.zoro.com
| Old tread on top, new mockups below. | Acetone wiped, masked for spray adhesive. |
| Overall shot. | Close-up of the new treads. |
I have a conventional 6 foot fiberglass step ladder. I also have a 3 step step stool kept in the kitchen and used to access upper cabinets. (Upper cabinets run all the way to the 8 foot ceiling)I have never felt insecure on the Hailo step ladders when climbing from the floor, and Hailo step ladders can be carried around with a pinky finger.
Great for that and also if you need to work above a staircase.The only places they shine is if you need to get a big ladder into an elevator or back of a van.
The work platform greatly increases the utility of the collapsing ladders.If you get the Gorilla or Little Giant ladder, make sure you get the work platform and the set of wheels. The LG work platform will fit on the Gorilla ladder. I use it on my 6 foot step ladder and multi ladder. Like others have said the multi ladder is heavy.
Work Platform Aluminum Platform For Ladders and Scaffolding https://www.lowes.com/pd/Little-Giant-Ladders-Platform-for-Ladders-Or-Scaffolds/999968823
I found 2 of them. One on CL and another one at a building reuse type store. Both were $20 or less each.The work platform greatly increases the utility of the collapsing ladders.
I found one in the clearance section of Lowe’s a while back. Don’t recall what I paid, but I consider it a score, whatever it cost.
