Shelter for my hobbies
Overboost44
MD
Back just before Covid, I had all of my plans done and permits approved to add a detached garage to my home. The original garage was turned into a bedroom, so I had lived without one for 13 years. We all know what happened to the prices and cost of construction, so I held off.
Time has come again. I am 8 weeks! into the permitting phase. This time it will be attached with a mudroom and it will be 2 bays 32'x26' with a 6'x18' mudroom in between. One bay will have a second floor over top. One 35' tall tree needs to be removed.
I am posting now, so I can maybe benefit from all of the knowledge here. A very good friend is a builder and has done the drawings for me. He has also provided me with his subcontractors that he has worked with over the 25 years. Good start. I will GC this myself to keep costs down so I can outfit it properly.
There can be no changes to the foot print. The minor changes will be that the wall on the left will be 4', between the doors will be 3' and the right will be 7'. I am not sure if I should center the dormers on the roof or over the center of the roll-up doors. Input welcome. No scale here so pay no attention to the siding difference in the dormers ;) There will be 14' ceiling and a 2-post in bay #1 with storage above. The room above bay #2 will be a hang-out or office.
To start closer to where I am now... I have learned that the excavation contractor does not plan to put stone in the footer trenches and he has done plenty of houses around here. No concrete forms either. Trench will be cut 8" wider than the required 24"x 8" x8" footers 30" deep. Does that sound familiar to anyone? Climate zone 4. I will lay #4 rebar on 3" chairs in the footers. I am just thinking it would save a lot of concrete if there were forms.
I plan 6" of compacted stone under the slab for the garage. Slab will be 5" maybe 4000 psi but that is probably overkill. I will have 2" foam on the stone and a 10 mil Stego wrap on that. Slab will have #4 rebar on 2" or 2.5" chairs. Pex (probably from Blue Ridge or Uponor) will be tied into the rebar for future radiant heating.
For the mudroom, I plan to have the same base but with a 4" slab. It will need to have ventilation so that needs to worked out. I do not like the "floating footing" that he put in there and I will instead have it tied in to the front and back walls as well as the mudroom block.
Have planned for rockwool throughout and will likely go with 1 mini-split with 3 zones. 24k for the main, 9k for upstairs, 6k for mudroom.
That is all for now. Munch on that. I will get into more details soon. Open to your thoughts.
Garage Perspective.pngGarage interior .pngGarage 1st fl.pngGarage 2nd fl.pngGarage Framing plan.pngGarage Trusses.pngGarage Foundation.pngGarage Roof.png
AC-WC
NE, Indiana
My opinion-center the dormers over the doors.
For the 2 post lift leave a blank spot of rebar where the column/bolts will go. It's preferable for the bolts not to hit the rebar. I followed Bendpak concrete guidelines for my retrofit and many other GJ folks do as well. They have 'new' construction instructions in the same guideline.
BurtEggley
just make sure your drainage and soil where you will build is perfect before doing anything else. So many people overlook those in a rush, thinking it will be "good enough," then have to remediate it later.
O
Overboost44
MD
Got the rebar covered. Also have to make sure the relief cuts will fall in the right place. I figure (but open to opinions) one 10' from the right side heading left and one 20'. Would I need one to dissect from front to back on an essentially 25' slab? If so, down the middle at 12.5' will not work as that is where the lift will be. Appreciate the thoughts on the dormers also. I am leaning that way.
Noted. I am thinking it is worth $500-$800 to have stones put in under the footers. This contractor has put several houses in the neighborhood, the thing is, they are new so there is no real history on how they will fare over time. Roof water will be run out to a culvert from the downspouts but heavy rains may not drain well. It is a low spot now but only because of the large tree and I feel that it will be graded out and be just fine.
Codyboy
S.E. TEXAS
The left front mandoor (DO2) has no protection. I would also make it a 3-0 wide.
Me, I would have the new garage roof extend all the way over the mudroom area as opposed to extending the house roof over the mudroom area.
Definitely center the dormers over the doors.
10 ft wide doors instead of 9 ft or just one 18 ft door
O
Overboost44
MD
Good point about the man-door having no roof. I will try to figure out the roof design.
Across the front I would do 3.5' wall, 10' door, 3.5 ' wall, 10' door, 5' wall. Dormers over the doors. If you need the 7' on the right, then 3' wall, 10' door, 2.5' wall, 10' door, 6.5 wall (same space as your 7' was with 6" less door per side)
I agree with Codyboy. Two 10’ wide doors or one 18 footer.
Also, 30” seems little shallow for the footings.
John
Everyone likes 10' wide doors. I can change them but just questioning why? Is 9' not wide enough?
30" is required by the county for frost depth. I figure they would be conservative. This is why I posted the plans and requested input. I still have time to change things. Thanks all.
logical
Northern fringe of the Motor City Suburbs
I suppose that all depends on what you park there. My F-150 with towing mirrors is only a few inches per side less than 9' and that left bay is really tight to the stairway wall.
AC-WC
NE, Indiana
Suggest you review with the concrete guy. Sometimes they like to cut the reliefs the day after vs the trowel/wet seam during the pour. If they do the day after cut it will be much easier to layout the column locations and then confirm reliefs are minimum 8" from the columns.
O
Overboost44
MD
Understood. Never say never, but that left bay should be for my wife's vehicle whatever that is or will be, but the won't have anything that size. Then again she said she would never drive my F350 and she ended up loving it. That was then, now the largest thing she would drive would be the size of an Explorer, 4Runner, etc. I do get your point though and will really consider the 10' doors with the wall dimensions that you stated.
Will discuss with the concrete guy in advance. Thanks.
7echo
coastal Georgia
Unless your home has dormers I would not build them. If you want the light get some Velux skylights. The dormers are a nice architectural touch but add complexity to the framing, roofing, and insulation.
O
Overboost44
MD
Understood. I have 5 Velux skylights on the home now. 4 that open and 1 that is fixed. Never had a problem with any of them.
That said, the dormer will add space to the room above Bay 2. That is important to me. With a 12:12 pitch roof, I will lose 8' in depth due to 4' knee wall. The other over Bay 1 is just for a symmetrical appearance. My existing upstairs room on the other end of the house has 2 skylights and with the knee wall it just feels small. I would like to have an 8' wide dormer over Bay 2, but architecturally that would just not look right.
CraigStu
Blacksburg, Va
Maybe I missed it but why are the garage doors not centered? To me it takes a really nice traditional cape cod exterior and makes it look weird. I'd center the doors and then center the dormers over them. I'd move the man door up onto the small landing so it would have a bit of roof over it.
Codyboy
S.E. TEXAS
This.
My F150 also has tow mirrors ( un-extended normal driving ) is 8.91' wide and 9.41' extended position.
OP you have an F350 (same width cab as F150) you say? Not sure if dually or single RW) Are you not going to park in garage or at least put it on the lift occasionally?
O
Overboost44
MD
I want 7' (essentially 6'4") on the right side because the lift will be in that right bay and I want room for work benches/toolboxes. Don't want to have to squeeze by the lift. Worth consideration to put the man-door up there, but will need steps to go to the garage floor. That would alleviate the concern to get it under a roof. I really don't see the man door getting used to often but definitely want a door near the front so I don't have to roll-up the garage doors when I get visitors. Appreciate your ideas.
This.
I don't have an F350 anymore and won't be getting one again. Used to have it for racing and towing trailers. Either way, I am still considering the 10' doors whereby otherwise I had not considered them at all.
O
Overboost44
MD
Thoughts on this? Received a quote for the excavation work:
Dig footers
Pour footings
Cut topsoil out of inside for slab
Stockpile topsoil for final grade
Cut new driveway (~ 1,000 sq ft)
1 load of RC6 for driveway base
Backfill foundation once block is done.
Under slab-Use material that I purchase (stone), he will spread and plate tamp it.
Final grade once everything is done.
$5000 plus discount for cash
CraigStu
Blacksburg, Va
I understand what you are saying about work benches on the right wall but, it would drive me crazy looking at those unequal outer wall sections. If you go w/ the 10ft doors how about offsetting the lift enough away from the wall to get benches there and drive closer to the left edge of the door opening?
O
Overboost44
MD
I get it. My wife has a hard time with it also. Your idea is really not bad.
It could be 5', 10, 2', 10', 5' or 4.5', 10', 3', 10', 4.5'. You have given me some thinking to do.
bad_idea
Pasquotank, NC
I did two 9x9 doors on my 30x40x12 detached. Really wish I had went with 10' wide doors. 9' is just wide enough to fit a car trailer into with ~3" on each side. That extra foot would make it easier fitting trailers and larger trucks (F250 range) into the building.
