Put stuff away. Did some research on an AtomStack A5 20w laser engraver/cutter I got yesterday, apparently still in the original box and not ever assembled? Not sure, and not sure its all there yet, but it was essentially included in a $20 bulk buy from the same estate I got the 3D printer from.
Assuming it is all there I'll be picking up LightBurn or LaserGRBL to run this thing so now 2 learning projects. 3D printing and LightBurn?
cannuck
Rural SK
Started clearing what was originally to have been my welder parking spot in corner of workshop. There is a tool and manual shelving unit beside my toolbox that covers 1/3 of the bay (3' gap and each end of 2 x full wall workbenches) that resulted in this becoming a junk collection niche in front of breaker pannel. Had to move shelving 2" that meant completely emptying and this will become home to 211 and plasma with top side my additive manufacturing (i.e. 3D print) bay.
dwasifar
More coworkers asked for pencil cups and I wanted to make something different, so after a multiple step glue-up, I present the triangle:
I made five blanks, each of them came out striped slightly differently just by random chance. Not sure whether I like this or it's too busy.
TurnipTruck
Southcentral Alaska
I spent the day just outside the shop, investigating the condition of a pair of free flathead marine engines from the 1940’s and gleaning some spares from them for my 1954 Chris Craft. The starboard engine didn’t fight me at all, while the port side took every opportunity to be obstinate. It’s like one was assembled with antiseize and proper torquing, while the other was jammed together with an impact and hosed down with salt water for forty years.
(Or maybe that side hatch was left open since the 80’s). Even the lifting eye was rusted away on that side.
Holy **** these are heavy!
I had to sling them off the trailer to collect the oil and my poor tractor squatted hard. Black and thick, but NO water!
Boat manufacturers ran their inboard engines flywheel-forward for lower CG/better prop angles, so this is the “front” of the engine (aft) with the cam gear on the left and an idler on the right driving a fourth gear on the distributor, while the output adapter to the transmission bolted to the crankshaft snout at the bottom. Amazing condition considering the boat was driven onto a trailer and abandoned in the woods forty years ago.
Look at the thickness of that cast iron oil pan. That boat had an entire TON of iron in it.
kaehlin
East Lansing, MI
Finished the refresh of my daughter's bike. Final steps were chain cleaning, derailleur adjustment, rear brake adjustment, test ride and a few more tweaks of the front brakes. I think the pivots on the brakes could have used a lube, and they were not springing back to a consistent position. Next time I will do it a bit differently, but it shined up pretty nicely.eyffpse - Imgur.jpg
aka Larry
Eastern, NC
I ordered a new water temp gauge for my F-150 last week. I asked Chat GPT the radiator hose size for the adapter to mount the sender. When I got ready to install the adapter I noticed it looked quite small compared to the hose. The adapter was for a 1.5" hose and turns out I need one for a 1.75" hose. A.I. fails again. :rolleyes: I decided installing the adapter was likely the easiest part, so I ordered a new one (at three times the price for the larger size!) and proceeded with the rest of the installation. Fortunately I found an easily accessible gromment on the firewall (adjacent to the throttle cable) to route the sender's wiring into to the cab. I didn't want to pay the Autometer price for their A-pillar gauage pod, but it was the only one molded to fit correctly so I bought one. I got it all connected and working except for connectiong the temp sender. New hose adapter is supposed to arrive today so I hope to get it buttoned up tonight.water_gauge.jpg
bmwrd0
Beaver Fever Oregon
Pulled the spindle from the Dalton, as I clean and scrape glop paint. Spindle bearings are in great shape, thankfully. There are no spare parts for these, so I need to be careful when disassembling, making sure nothing gets misplaced, and hoping that everything is in good shape.
You can really see just how dirty this thing is in that picture
Beerhippie
Far NE Oregon
That looks familiar....
Wrench97
Southeastern Pa
Which motor? Some of the Ford manifolds have a plug on one side of the intake you can use for the sender.
Beerhippie
Far NE Oregon
A fine morning of fixing forklift damage. An easy fifteen-minute job.
Pro tip one: Forklift always wins.
I'll have to straighten and flatten that metal trim:
The red angle corner protector is barely hanging on, so it'll get some love, too. Amazingly, the SS rub panel is holding up just fine, but it has to come off, too, as the metal trim has been pulled up from beneath it.
I'll use roofing tacks to anchor the metal trim back down. Screws give the forklift too much purchase and aren't easy to remove once bent all the hell and gone.
Pro tip two: When driving roofing tacks, hold them like this:
not like this:
It's amazing how much difference hitting fingers flat vs on edge makes in pain and injury.
Forklift vs. 1/4" lag bolt?
Forklift wins. I'll have to replace those with 5" bolts as the holes are torn out.
Trim metal flattisher, rub and corner protectors reinstalled. Time to hang rubber.
An hour-and-a-half after starting my "fifteen-minute job"....
I like this silicone door seal. It's very easy to work with and has an adhesive strip on the back to hold it in place while I nail it off. The bottom with the SS plate will probably be left with nothing but the adhesive for now. No way I'm driving roofing tacks through that.
The other side doesn't take as much of a beating--not sure why.
I have a few pieces of that rigid seal. I'll get on it after lunch when the door is in the shade.
Wrench97
Southeastern Pa
not like this:
You should see what 12 can do in one night.......
2001ZR2
Kansas City
I may have triggered the apocalypse...at least in a GJ sense. I wanted spray weeds around my house and....
1. I knew where the sprayer and chemicals should be in my garage.
2. They items were where I thought and the bottles had sufficient levels for spraying tonight
3. The sprayer pumped up and didn't leak.
4. Nozzle wasn't clogged with last years chemicals.
These are the signs of the days because normally 2 hours looking and moving stuff to find those items. And things worked like they should because I didn't neglect my sprayer.
If its not the end times it was strange and scary.
GrayFlattop
Chicago
T&S Brass "Eterna" line. I've replaced damned near every faucet in the brewery and pub with them. Easy to source, inexpensive parts--and dead easy to service. I can interchange between ceramic and gasketed valve cartridges--handy as ceramic cartridges don't last long with our city water.
I’ll look into that, thx. For the main kitchen, I’ve had good luck with Symmons units.
All of our domestic water runs through a 4 x 20 1 micron carbon block filter. That tends to keep a lot of crud, rust etc. out of the cartridges. Water lines for the sillcocks bypass the filter, of course.
slomaro3.4
More work on the egg last night, ground out the crack and I'm going to fill everything with refractory cement hopefully tonight. My goal is smoked wings on Friday. The coating was slow going even with diamond dremel grinding stones.
micromind
Fernley, Nevada, about 30 miles east of Reno.
Put a old stock handle on my vintage Pexto ball peen. Then, like an *******, I grabbed the head after I ground down what was left of the wedge, checking to see if it was nice and tight. Nice burn to my paw now…. Brainless. 🤪
you're not the only one who has done that.......lol.
micromind
Got the damned make-up-air unit up and running. Funny how trying to run a motor wired for 115V on 230V trips the motor protector every time.
Now to figure out how it gets 230 from a single-pole breaker--the only one I can locate marked MAU. Good thing I always test for voltage before touching a bare wire, but the lock-out rendered it safe.
You have what we call a high-leg delta service.
It's 3 phase and there's 240 between any two phases.
There's 120 from 2 of the phases to neutral but the 3rd phase is 208 to neutral.
The open slot you put the single pole brakes on was the high leg; 208 to neutral.
If there's an open slot that's not the high-leg, you can use it and connect the motor for 115 volts. If it were me, I would connect the motor for 230 volts and use a 2 pole breaker with the high leg and one of the 120 phases, provided the controller (starter) is 2 pole.
If you use the high leg, technically the 2 pole breaker needs to be 240 volts and not 120/240. The reason is because a 120/240 breaker is designed to safely open either pole at 120 to neutral or 240 with both poles. The high leg is 208 to neutral so if it's a solid fault and there's enough available fault current from the PUCO, the breaker might blow up.
Seriously, of all the 2 pole breakers I've seen used with the high leg, I bet less than 10% of them were 240, the rest were basic standard 120/240 models. Never a problem.
aka Larry
Eastern, NC
This is why I've always installed a coolant temp gauge in one of the by-pass coolant lines that are always fed.
I like to say the OEM 'gauge' tells you how cold the engine is, and the aftermarket gauge tells you how hot it is.
I'm never looking at the temp gauge when the engine is not up to operating temp anyway.
Beerhippie
Far NE Oregon
You pretty much nailed it. Unfortunately, I'm pretty sure that isn't the problem, as when I measured the output of the motor control contactor, it was 230-240. I have a feeling the 120V breaker is for the controls and there is another 2-pole for the higher voltage--in a different breaker box. Not very code if so.
Fortunately, the lock-out on the device shuts down both legs--I check with a VOM before touching any wires.
