DaveAndStuff
No spud-wrench fans?
They definitely have their uses, but care is needed..No spud-wrench fans?
Yes, you’re right.As far as I can see, the European brands only do angle wrenches in midget thin sizes. I wonder why that would be.
Beta 73 up to 14mm.
Stahlwille "Electric 12" up to 14mm.
Facom 34 up to 17mm.
After looking at the video above, it looks like the crowsfoot would tackle the vast majority of scenarios, while being more compact to store, and more flexible when used with different extensions/ratchets etc.
Here's a comparison of an 8mm and 10mm 30/60° angle wrench and a Facom 15/75° 9mm.As far as I can see, the European brands only do angle wrenches in midget thin sizes. I wonder why that would be.
I guess that must be a model 34?a Facom 15/75° 9mm.
Notice how much thinner the head is and shorter the shank.
Yes, #34.I guess that must be a model 34?
It doesn't look as thin as the 3mm given in the spec. It looks chunkier overall than the Stahlwille/Hazet type which are also 3mm in that size.
I don't know how detailed you want to take this, but under "5. Box points" spline is also an option of aerospace wrenches.An enumeration of all attributes (I can think of) that may be used to describe any particular type.
- Number of sizes on one wrench
- Single, with different end variants
- Twin, with same end variant
- Length
- Standard
- Stubby
- Midget
- Long
- Extra long
- End type
- Open
- Box
- Flare nut - standard, flanged
- Socket
- Lateral head angle
- Flat / straight
- Angled
- Step offset - shallow, deep
- Right angle (only for socket ends)
- Flex / hinged
- Box points
- 12 point
- 6 point
- 6 point with grip feature
- Open end rotational angle
- Standard
- Offset (different at each end)
- Open end special feature
- Grip
- Speed ratcheting
- Thickness
- Standard
- Thin
- Thick heavy duty
- Ratcheting
- None
- Single direction
- Switchable
- Handle type
- Straight
- Obstruction
- Slogging / striking
I think Snap on does a really great job of this or they did. I’ve heard some here complain about newer versions of what I have. If the joint is well machined and the pivot bolt is high strength and torqued correctly, there really should be a lot of spreading going on.They can make them as tight as they want but with use, the yoke will spread and result in a floppy head. same issue that eventually befalls any flex head tool.
Maybe there for machine shop tool spindles to lock and unlock bits of larger sizesI understand different shapes and angles of wrenches for access but the wrench I've never understood is the "engineer" wrench. Short handle, thick head, shallow open end. Used examples always have hammer marks on them and deformed jaws on the open end, in the small sizes, say under 1", they're ridiculously proportioned.
I know there are plenty of people that will disagree with me; that's fine, I don't care. I have found that the least useful wrench is the long flex head ratcheting wrench. I don't care for any flex head ratchet wrench I've ever used but the long ones are the worst. Every other type of wrench I've used or own has had it's place even though it might not come out of the box very often but the long flex ratchet wrenches might as well be in the dumpster.
