Bryan/College Station, Texas
brandonsmash
For security cameras available on Amazon I'd use the Eufy 340.
The 2-pack is presently on sale for $380. It's not an amazing hair-on-fire deal but it's the lowest I've seen, and it's basically the same price as piecing out each part of the kit.
For that you get 2 cameras and a Homebase setup. Video is stored on the Homebase and can be streamed remotely but it does NOT use a cloud service (unless you want to pay extra for it, but that's optional).
I have 2 of these: One at my home and one at my work. Image quality is pretty solid and they do have motion-activated night lights (which are so bright I had to turn them down on the home cameras).
Saw this on the YouTube "Tools &Twisties". I'm going to try them out at this price. I have a z series Koken ratchet that I don't think will be replaced by this though. I'm hoping that Koken will bring their knurling, non comfort grip, to the 72 zeal line eventually.
Madjik Man
Dealing with the pain in the **** 10mm allen head drain plug bolt on my Tacoma's front diff. The MFer won't budge. I tried tapping it with a hammer, cursing at it, praying and all the other garage techniques.
So I'm looking into heat. I don't have a torch and was looking at induction heaters. Came across the popular Amazon brand and saw this one is the lowest price ever. 50% off. ($129 as of this post)
I'm reluctant to buy it based on the reddit discussions about them and I won't drop $500 on a tool I'll (hopefully) barely use.
But for those interested:
Edit, not sure why my link just says "Amazon.com" with no thumbnail. The product is:
Solary Magnetic Induction Heater - 1100W 110V Handheld Bolt Removal Tool with 12 Coils
Pexto
A while back I had the same problem on my old Tundra. I eventually got it out with a hex bit in a cordless impact, penetrating oil, and a lot of patience. Maybe give that a try? Details here: https://www.garagejournal.com/forum/threads/lowes-deals-sales-clearance.526796/page-12#post-10920659
Apologies for the thread drift!
2manytools
Mt Pleasant, MI
I have swapped some of my 4runner plugs over to Lexus style, where it is a hex top so you can use a socket. For all the smart :poop: Toyota does, not sure why they chose hex plugs.
Nekit
I have a similar one I bought a few years ago. I’ve only used it a few times, so far very happy with it. I was in the same boat about spending lots of money on something I’ll use once a year. I know one of the biggest problems with them failing is people pressing the button and cranking them on from several minutes till they burn up. I always read the instructions and I think it says something like 10 seconds at a time. You can heat the bolt in steps till it gets hot enough.
Madjik Man
I read that on Reddit. Another poster said that he’s taken hundreds of these apart and it’s all cheap electronics. One being the tiny fan built into the handle- which probably doesn’t work well - hence the need to only cycle it 10 seconds at a time.
Lastly I saw a review for this specific one that says it’s 15” long, 22” long with a coil in it. And 3” in diameter. That seems really cumbersome to try and maneuver in an automotive setting.
Pinne
I have one of these, it seems to work OK. The length isn't that big a deal as you can just bend the coils to whatever shape you need. It might be a pain if using it in an engine bay. But I am mostly dealing with stuck bolts when they're on the underside of a car - so I have plenty of room to maneuver from underneath.
Haven't used any other induction heaters so I can't compare, the expensive ones are probably faster but for my uses I'll keep the extra $300 and wait a minute or two.
jayemm
up high down low
Yup. I have a Lexus drain plug just waiting to be installed… once I get this fawking Allen head bolt out.
Maybe try something like this and try loosening when the pan is still hot from hard driving. Amazon and others sell them.
ETA -- my mistake, thought you were referring to oil pan bolt.
ETA2 --- just noticed I linked the SAE set. There's a metric set also.
Madjik Man
Never seen anything like that. I'm going to try heat (buddy is bringing over an oxy acetylene torch) and hitting it with a hammer.
I don't know if the front diff gets hot from driving without the 4wd/transfer case engaged.
But last resort before bringing it to someone who can possibly weld a nut to it is to try the extractor set from Harbor Freight:
j3rf
@Madjik Man
I've had excellent success with the Proto version of the Mac RBRT/Grip Edge RPT hex sockets on Subaru differential hex bolts. Clean out the rust and corrosion with a wire brush and pocket screwdriver, pound the bit home with a small hammer. Along with a long 3/8 ratchet, no heat required.
Chuckster in NJ
Hunterdon County NJ
@Madjik Man
Before you start "hammering" remember………… KROIL is your best friend! ;)
iflyatiger
iflyatiger
