Tire Plug kits
gtae07
Fayetteville, GA
I've used the Slime kits a few times and they've never caused issues. They've certainly saved my **** a couple times. Still running on one right now that I put in last November. The tires are almost at the end of tread life so it just needs to hold a couple more months.
Beerhippie
Far NE Oregon
I have a kit that came with a offroad jack I bought. Now I'm thinking it needs some metal-handle tools. Putting a steel rod through my palm is a new experience I can just skip.
I put mine in a cheap tool roll. Takes up much less space than a blow-mold case.
Hakeem
Chicago
I’ve used the Safety Seal plugs probably 50-60x. Most of those were on semi trucks or trailer tires. A few needed two plugs but all seemed to hold fine, and this is on tires inflated to 100+ psi, bearing thousands and thousands of pounds.
Admittedly I don’t think we’ve ever plugged a steer tire, only the drive tires, so a blowout would be one tire out of eight. But again - never heard of an issue.
I remember @bwringer sharing a unique type of plug that twisted on the inside of the tire to seal the inside & out .. please refresh my memory on the brand if you see this, good sir
KnurledNut
n/a
Its not nearly dramatic as its made out to be. I had it happen a few months ago and it was obvious the handle was breaking before the steel even separated. It also bent. I had on gloves so not a big deal anyway plus its blunt, not sharp. I ended up clamping the rod in vise grips and finishing the job.
Jtels85
Perhaps a bit overkill, but I recently purchased this set from Amazon for $30. I used it just one time when my wife came home with a large screw in her right rear tire. The reamer tool is stout! Much better quality than the cheap $4 unit sold at most brick and mortar stores.
rlitman
Long Island
If you're really a tightwad on space, you could always loosen the allen, take the needle and reamer out of their sockets and stow them, the allen and some plug cords inside the hollow handles. ;) Me, I just have everything in a small bag.
For those that didn't notice, the metal handled kit in the post above differs from the Safety Seal kit, in that the needle is about 2" shorter, and the ropes are correspondingly shorter as well. I actually prefer these shorter needle and shorter rope kits, but YMMV.
Firebrick43
West central Indiana
I now use Tech permacure plugs as they vulcanize instead of just hoping the brown goo holds. I have had a few regular plugs get slow leaks over the years.
NUTTSGT
Northern Central Ohio
I bought a Slime tire plug kit solely because my SIL had a thing for flat tires for a bit and I was getting phone calls for assistance. Since I bought the kit, I don't think I have gotten one call.
....and the spammer that brought this thread back is gone.
bwringer
Indianapolis
That would be the Nealey plugs. They're installed a little differently, don't need glue, and IMHO they work somewhat better than the usual gummy rope worms.
I've installed dozens in motorcycle tires over the years, and car tires too.
When you remove the tire, you find a knot firmly stuck to the inside of the tire. It takes a substantial effort to pull it off from the inside with good pliers.
Not every puncture is pluggable, of course. Obviously tire damage has a significant random component. The only failures I've ever seen are when the puncture is too large or in the sidewall, etc. and even in these cases you can often get it to seal enough to limp home with a slow leak.
KnurledNut
n/a
Is the screwdriver insert tool built well? I looked into those years ago but never pulled the trigger because I wasn't sold on the durability of the tools for truck tire applications. The strings themselves seem well made.
bwringer
Indianapolis
Yes, it's very strong and well-made. It's also not very large because it doesn't need to be, so not a lot of force is ever needed.
Read through the instructions on the website and you'll start to get an idea of how the kit works a little differently and why.
There's no nonsense with reaming, for example. Just move the tool around to bend any wires out of the way.
And the strings are skinnier, but they're installed such that you end up with four thicknesses of sting in the hole and not two, and there's a knot on the inside. So they confirm better in irregular punctures, and cannot come out.
Under_Pressure
NE Wisconsin
Count me as a fan of Nealy as well. Bought one of the long sets for heavy duty tires at a farm show many years ago. You can just cut the strings in half and only insert the tool halfway for thinner passenger car and similar tires. I've since ordered a couple more kits, because it's not much more money to buy a whole new kit with a new tool than buy plug refills. Have used them on a number of highway tires and have never had one not work perfectly (if the tire was repairable at all) and last until the tire was wore out.
NUTTSGT
Knot ? A knot of what ? Like a broken belt ?
:dunno:
ericg
From their website
How does the repair work?​
Thread the strong rubber treated repair cord through the eye of the sturdy inserting needle. Run the inserting tool all the way into the handle. Turn the handle 1 1/2 revolutions and withdraw it until the tip of the tool just clears the face of the tire and cut the tool free. That's it! By turning the tool and pulling the repair back through the hole, we have formed a circular, knot like patch on the inside of the tire, you have both PLUGGED THE HOLE AND PATCHED THE INSIDE. Air pressure tends to make the repair even more snug. On tires driven at high speed the heat causes the repair to melt or "cure" into the puncture and adhere to the casing of the tire.​
mervyn
Missouri
I've got whatever cheap kit they sell. Never had a plastic handle break. Never used glue either. So there. :beer:
wafrederick
Holton,Mi
Stay away from the kits that use the rawhide plugs. The rawhides do not seal very well and leak. Although I never used them, have pulled them out easily with pliers replacing them with the rubber ones. VIM has one you use on an air hammer now.
zimman
Mark Twain National Forest
I plugged a lawn mower tire today. Just a cheap kit from Autozone.
As a tire guy for a few decades I've patched and plugged hundreds of tires and intertubes. I just get the cheap stuff because eventually you'll break one, especially on a 10ply, laying on your back under the truck. LMAO
And, the rubber cement helps with the insert and the longevity.
Zim
IndyGarage
Indy
I've had about 75 tires since 1986 that I've plugged and never leaked. In fact, I can't ever remember having one leak. So honestly I think all the folks that don't want you to plug a tire are just Nervous Nellies.
I generally try to use Safety seal because the tools that come in their kit are a little more sturdy, but I've used all manner of rope plugs and never had a problem with any of them.
I did not have good results from the Stop and Go tire plug kit that supposedly plugs the tire from the inside - about 50% failure rate on those.
If I'm not mistaken Discount Tire is in the business of selling tires - no surprise there. Breaking news: A furnace guy told me I needed a new furnace immediately - that was 23 years ago, and the last time his company entered my house...
quoting my own from last summer.
I said I had never had a tire plug fail - which was true, but apparently it happened sometime in the last six months.
I was visiting my friend John last fall, and he had a nail in a tire on his pickup, which I plugged with one of my safety seal plugs, and sealed just fine. A few weeks ago, his son was telling me that he had borrowed the truck and that plugged tire failed on him and he had to buy a new tire. He said it was because of the plug. I've never had one fail before that, so I guess it was bound to happen sometime. Still a 30 year record is pretty good. We did ride one of his four wheelers with a plug that I put in about 3 years ago.
BonzoHansen
After our insurance company told us we had to stop plugging tires -- more precisely, they told us our liability coverage was void on tires not repaired according to RMA standards (which requires dismount, inspection, and both a plug and patch),
its the inspection part that is key. I cant even remember how many tires i opened up with an innocuous looking injury from the outside only to open the tier and find a gouged/damaged sidewall (including run flat damage), which is a disaster waiting to happen.
With a proper plug/patch, unless the plug installer really reamed the **** out of it, they were typically repairable. But the INS CO might say otherwise. I got out of that business before that kind of liability notice became a bigger issue.
Jeepster04
I've had the Safety Seal kit for many years but I've only used it twice. No complaints! Both tires are still going.
Its important to not drive on a flat tire THEN plug it.
Dig Doug
I bought a cheaper kit for my Can Am the Hardware was good ….
( I liked the little zipper bag that came w/ the kit ) Smitty built was the brand
Gave it away !
but
The Plugs Absolutely Sucked !
so If anyone has issues
Just buy replacement Safety Seal plugs
That is the most Important Part of the kit
sk farmer
nd
+1 on the nealey
i have used hundreds over the years. i am constantly on gravel roads with debris and the nearest tire shop is 15 miles away and of course not open on weekends or after 5. i keep several kits and refills on hand at all times.
my issue with the safety seal? why on earth would you shove a reamer the size of a pencil through a hole the size of needle causing more damage?
i rarely have to enlarge a hole for a nealey and larger holes get a longer string or a second string.
hailwood1965
I'm convinced most threads here are from guys who own a lot of tools, a collection if you will.
